Anyone ever install puddle lights under their tundra like the 2016 tacoma limiteds had?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mssmith8, Mar 19, 2018.
  1. Mar 19, 2018 at 9:36 AM
    Mssmith8
    Mssmith8 [OP] New Member
    2018 Tumdra Limited
    I had a 2016 Tacoma Limited and it had the puddle lights under the truck and also lights in the footwells.
    Now I have 2018 Tundra Limited and those are prob the 2 features I miss most since my truck did not even come with the mirror puddle lamps. Anyone ever install puddle lights under their tundra?
  2. Mar 19, 2018 at 10:11 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Yep, super easy. Wired it to the courtesy circuit, comes on and shuts off with the interior/cargo lights. Not a very good pic:
    Kwikfish likes this.
  3. Mar 19, 2018 at 10:18 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Ill be watching this or maybe Led strips so its brighter?
    831Tun likes this.
  4. Mar 19, 2018 at 4:08 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You can definitely use brighter lights. I wanted something subtle and used 6 of the 8 lights I purchased.
  5. Mar 19, 2018 at 4:23 PM
    Mssmith8
    2018 Tumdra Limited
    So for puddle lights to go under the truck what have you guys used?
  6. Mar 19, 2018 at 4:28 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I got cheapies from ebay for less than $10. They look like these but only have 1 diode.
  7. Mar 19, 2018 at 5:26 PM
    wasabi4
    wasabi4 New Member
    Lee
    2017 Limited CM 4x4
    where do you tap into to the courtesy circuit? I'm thinking of wiring some rock lights to my switchpros.
    831Tun[QUOTED] likes this.
  8. Mar 19, 2018 at 5:45 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Under the driver side door sill. It was a very small brown wire on the 2016. I've heard the color changes in newer years. I used that as a power source and switch. Running it to the switch pros is redundant and will likely cause a problem 'cause you'd be potentially drawing current from 2 sources.
  9. Mar 19, 2018 at 5:49 PM
    wasabi4
    wasabi4 New Member
    Lee
    2017 Limited CM 4x4
    thanks!
    I am going to wire directly to it or use that wire as my "trigger" to turn on the rock lights. I'm leaning on tapping into that wire as the trigger so when it's powered, the rock lights turn on as puddle lights.
  10. Mar 19, 2018 at 5:51 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That would be MUCH better, especially with rock lights since it is a VERY small wire and I'd be worried the rock lights would pull too many amps.
