Anyone else notice this as a possible cause to the drivers side wind noise?
Discussion in '3rd Gen Tundras (2022+)' started by tropro, Jan 31, 2023.
  1. Jan 31, 2023 at 6:02 PM
    tropro
    tropro [OP] New Member
    Troy
    MN
    2022 Blueprint Platinum
    My drivers side wind noise has become progressivley worse and noticed it even more this past weekend while driving over a bumpy two lane hwy. (Most noticable over 50 MPH.) I noticed a change in the wind noise with each bump leading me to think the door does not latch tight. It's been super cold here in MN this week and I found if I put my hand behind me on the driver window next to the rear window seal, I can feel a slight breeze of cold air. What's interesting, if I push the door outward from the door panel with my elbow, the wind noise gets louder. If I pull the door handle towards me as hard as I can, wind noise almost is completely gone. I thought great, problem solved, adjust the door strike. Nope, strike or latch does not look adjustable. Anyone else discover this as the possible issue that may be causing the wind noise many have complained about? So irritating!
  2. Jan 31, 2023 at 6:14 PM
    devron11
    devron11 New Member
    Ron
    Denver
    Following discussion - I have the noise and tried moving latch and strike but no adjustment is possible.
    Bigern likes this.
  3. Jan 31, 2023 at 6:18 PM
    Taco-Spike
    Two Trucks
    Place some extra tubing in the door seal and see if it helps
  4. Jan 31, 2023 at 6:21 PM
    Troyboy84
    Troyboy84 New Member
    BC Canada
    2022 SR5 TRD Offroad
    my truck will be going in for the second time tomorrow morning in an attempt to fix the drivers door/window wind noise. They’ve already replaced the putter window seal with zero success. My service people have been great but they are handcuffed by Toyota corporate. I’ll keep everyone updated if anything is resolved.
    Bigern and Cp1 like this.
  5. Jan 31, 2023 at 6:36 PM
    jsf343
    jsf343 New Member
    jeff
    soon 2023 toyota TRD pro
    Mine seems to be slowly getting worse as well, very annoying as I have pretty bad tinnitus and it’s doesn’t help that at all. As for the noise I can roll the window down just about 1/2” and mine goes away, makes me think it’s window/seal, but maybe all it’s doing is changing the airflow slightly and maybe it is the door, never even thought about that, going to look into this door possibility more.
    we need to continue to keep each other updated, I think eventually this will be figured out and resolved but we need to be our own detective and advocate unfortunately, and it’s going to take time.
    anyway good detailed discussion op and others, good info.
    Bigern and Kap1 like this.
  6. Jan 31, 2023 at 6:48 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Just picked up my 1794 from service now regarding this same issue. Wind noise and whistling at the driver side window.
    Dealer decided to do the TSB that plugs holes of the lower control arm... And ordered parts. Probably won't help but we'll see...
  7. Feb 1, 2023 at 6:13 AM
    xc_tc
    xc_tc New Member
    The air usually gets in through the door seals where door meets the body (not the window trim seal like everyone was freaking out about).
    If you want to prove your theory, put painter’s tape around the door and go for a drive.
  8. Feb 1, 2023 at 6:25 AM
    jsf343
    jsf343 New Member
    jeff
    Way to contribute, and I don’t see anyone freaking out, just offering thoughts and ideas on the problem , but whatever.
    If you read all the posts some have almost fixed the problem by having window seal replaced, some have had it almost fixed by mirror replacement, others have not had luck with either. Point is there doesn’t seem to be any one thing that fixes all, And the problem is not just isolated to the door, window or mirror.
    Bigern likes this.
  9. Feb 1, 2023 at 6:28 AM
    tropro
    Troy
    MN
    Thanks for the suggestion but this should not be my job to figure out why my 67K truck leaks fing air so bad it sounds like a 50 yr old truck! Also, not a theory but an observation. You may be correct on where it's coming from, but doesn't change the fact that it's not a problem. Not to mention, it's not up to me to sovle and correct an issue on a new truck. And I'm not freaking out, frustrated.
    Bigern, TrailKiller and in_the_mud like this.
  10. Feb 1, 2023 at 7:40 AM
    Markysharky
    Markysharky New Member
    Mines doing the same thing. The door windows seals look janky but that’s not where my noise comes from nor is it affected by the mirror position. To me it seems like the door rubber seal is too soft and not getting squished enough on the top section.
    TrailKiller likes this.
  11. Feb 1, 2023 at 9:46 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I don't believe that anyone came out and said that after dealership replaced something, the noise completely went away.
    I think closest someone said that one side was fixed but other wasn't...
    I've been watching forums but seems like nobody reported a true solution to wind noise issue yet
    Bigern likes this.
  12. Feb 1, 2023 at 10:24 AM
    jsf343
    jsf343 New Member
    jeff
    I meant the word "fixed" as a word that was part of a general statement referring to what one person or another did in their case, that's why I mentioned the other items (door, window, mirror, each of which helped that individual to one degree or another from my understanding of past posts) were they part of a bigger "fix"? no, otherwise we would not all be talking about it like we are and I thought that was understood by my last sentence.
    In any case I have edited my post with word "almost" so no more misunderstandings or somebody thinking I am misrepresenting a possible solution when there so far isn't one.
  13. Feb 1, 2023 at 6:44 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have been wondering about the bottom of the mirrors randomly falling out and damaging the camera. There is a gap under the mirror where this camera cover sits. This gap around the cover would be in the path of air rushing around the mirror. Sort of like blowing air over an open bottle. My mirrors have not jettisoned the camera cover yet and I am thinking about applying a bead of caulking into this gap mainly to secure the both covers. There might be a benefit in stopping the wind noise as well. I am hoping to do this soon. Fingers crossed!
    charlieyankee88 likes this.
  14. Feb 1, 2023 at 8:20 PM
    chrispage
    chrispage New Member
    I was talking to the service department the other day and to me it looked like the seal in the top rear of front doors was odd shaped and didn't seem to seal well. The tech told me there is rumor mill that it is the mirror design causing it. I notice it on both sides and at varying intervals, in other words it is not constant.
  15. Feb 1, 2023 at 8:24 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    If it's mirror design, then everyone would have this same whistling issue.
    Mine was whistling loud for the first couple of months, if I close mirrors when whistling stopped.
    Now it stopped whistling loud, just some wind and slight whistling noise, and closing mirrors doesn't do anything anymore. I didn't change anything but mirrors don't whistle loud anymore, not sure why
  16. Feb 2, 2023 at 5:04 PM
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    As someone who has had their first-run door seals replaced to no effect, I was intrigued by another post somewhere (and the OP here) that suggested it's an issue with the alignment of the door, specifically the forward seal that meets with the front fender. Sounds like it might be an assembly issue where the doors are misaligned (out of plumb) just enough to let air through, thus wind noise. Just guessing here, but I will try some painter's tape over that gap to see if it helps. Once it warms up.
    jsf343 likes this.
  17. Feb 2, 2023 at 5:06 PM
    jsf343
    jsf343 New Member
    jeff
    Interesting theory. I wonder if there has been less of an issue with 23’s?
  18. Feb 2, 2023 at 6:43 PM
    Troyboy84
    BC Canada
    Just got my truck back from my dealership. Opened a case for excessive wind noise, taped all the door seams to try and isolate the noise, which can be heard at the top rear, the highest and farthest back point on the drivers door. Waiting to hear their plan, assuming they will be replacing the door trim seals. They already replaced the window trim seal to no avail. Unfortunately I’m not confident the new door seals will solve the problem. Luckily I have great people working me at the dealership, so hopefully we’ll get it figured out eventually.
    CringyDad and Kap1 like this.
  19. Feb 2, 2023 at 7:01 PM
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    I had the same problem on my2017 crew max ,was driving me crazy.I went to ACE hardware and bought some self adhesive weather seal and installed it on the top part of the door and problem is now gone
    charlieyankee88 and Kap1 like this.
  20. Feb 2, 2023 at 7:05 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Did you figured out which part causes the noise after taping it?
  21. Feb 2, 2023 at 7:14 PM
    Troyboy84
    BC Canada
    no exactly, after taping all the seams along the upper part of the front and rear door, it got a little bit better. I may try taping the vertical seam between the front fender and the door.
    Kap1[QUOTED] likes this.
  22. Feb 2, 2023 at 7:26 PM
    Infernotundra17
    Martin
    Las Vegas, Nevada
    I did from the front fender to the rear end of the front door .I think it's the oem weather stripping
  23. Feb 2, 2023 at 7:30 PM
    Troyboy84
    BC Canada
    weather stripping meaning the black rubber that gets sandwiched between the door and body of the truck? That’s what I am thinking as well. I’ve read on here that some people have had it replaced and didn’t necessarily fix the problem. Weird how some trucks have excessive noise and some seem to be super quiet.
  24. Feb 2, 2023 at 8:45 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Exactly, why can't we just put two trucks side by side and study them to find out the cause
  25. Feb 2, 2023 at 10:27 PM
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    do you find yourself having to close your driver-side door harder, or need to close it a few times because it won’t latch? I do on my 2023.
    I’m just wondering if it might actually be the door seals?
  26. Feb 2, 2023 at 10:55 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Not really, my doors close just fine, I haven't noticed anything unusual.
    I tried to pull up the window trim and door during the wind noise but it didn't do anything to change it... So not sure.
    Mine whistling noise would actually stop when I would fold down the mirrors, then start again when mirrors were opened. But now mirrors have no effect... No idea why. So it's a bit of a moving target for me.
  27. Feb 3, 2023 at 1:07 AM
    FLTundra22
    FLTundra22 New Member
    St Aug, FL
    ‘22 Limited TRD Off Road 4x4 Crew Max Lunar Rock
    TRD 3” lift, 35” Nitto Trail Grapplers, BackFlip tonneau
    In the process of spending two trips already to the dealer after getting a case # going via Toyota Brand Engagement. My ‘22 has an annoying plastic-on-plastic sounding crackle/rattle that is coming from the front doors/windows. Seems to worsen with lower temps and at higher speeds on the highway + 70mph…but it can just pop up randomly on bumpier surfaces. First trip in they replaced the entire door panels on both shotgun and driver’s side and the noise described was reduced (and fixed a rattle in the driver’s side door when playing music w/ heavy bass) but that crackle/rattle is still there. If I press outwards on the glass of the window when the noise is present it goes away so thinking it’s gotta’ be the weather seals/stripping? Will be headed back in soon as they’ve received new seals but they are currently on nationwide backorder…no surprise there. I’ll update all progress as it goes…love almost everything about my new Tundra but having an ongoing rattling cheap plastic cabin noise in a $60K + truck has my eye twitching.
    CringyDad likes this.
  28. Feb 3, 2023 at 7:00 AM
    topdec
    topdec New Member
    So could it be the door weather seal being thinner on the 22s?
  29. Feb 3, 2023 at 11:04 AM
    23Tundra
    23Tundra New Member
    2023 Tundra 1794 - Stolen!
    Yes, i just dropped my truck off at the dealer for the same issue they are going to take a look and let me know
  30. Feb 3, 2023 at 2:28 PM
    Dethred
    Dethred New Member
    This 100% happens to me. I close the door harder than a regular car and it still won't latch. Basically have to slam it in anger, and I get noise at 20+ mph, it's louder than the radio at 10 volume, and infuriating for an $80k truck (23 Capstone)
