Anyone else get a whistle when they close ac vents on the dash?
Discussion in '2nd Gen Tundras (2007-2013)' started by ftmyerstundra, May 17, 2022.
  1. May 17, 2022 at 8:15 AM
    ftmyerstundra
    ftmyerstundra [OP] New Member
    Gary
    2007 Tundra Crew Limited
    absolutely none
    When I ride alone I usually shut the passenger side ac vents so that my side cools off faster. In the Tundra I get a significant whistle sound when I do this? Anyone know a cure for this?
    Also, I notice that the vents dont like to hold their position very well, usually dropping down as the air volume increases. Any fix for that? New vents an option?
    Thanks
    Gary
  2. May 17, 2022 at 10:00 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Doctor, it hurts when I do this...
    Seems like the increase in velocity you desire is too much for the vents to supply quietly.
    I'll try to take mine out later today and see if I can replicate.
    I imagine new vents would stay in position better. Hopefully replacements are available without having to replace half of the dash... otherwise, if they can be disassembled to the point of accessing the pivot points, application of petroleum jelly or fairly thick grease would handle it.
  3. May 17, 2022 at 10:08 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Mine whistles depending on certain configurations of closed percentage and which one(s) and air flow setting. Never tried to fix it, but it's a minor whistle in my case and I just adjust the vent slightly to stop it.
  4. May 18, 2022 at 3:05 AM
    ftmyerstundra
    Gary
    absolutely none
    Well fixed the floppy vent by pulling off the adjuster tab and putting electrical tape on each side. Nice and tight now the way I like it. ;) I will figure out how to stop the whistle another day.
  5. May 18, 2022 at 3:19 AM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    Most of these vents have some type of foam gasket on the damper which degrades over the years and causes the whistle.
    MPG_LOL likes this.
  6. May 18, 2022 at 5:43 AM
    ftmyerstundra
    Gary
    absolutely none
    Yeah I just gotta figure out how to get in their.
  7. May 21, 2022 at 10:37 AM
    Underdogg
    Underdogg New Member
    07 Crewmax 5.7L
    Oh yea, happens the second I close any one of them other than the leftmost one. I try to close the front ones so the air to the rear gets stronger for my dog in summer but the whistle drives me nuts. Sorry doggo
  8. May 22, 2022 at 9:51 AM
    chrisf111
    chrisf111 New Member
    Yep this is what I figured as well. When I took apart my dashboard I got a good look at the damper. On the edges there is a slot for a piece of thin foam that creates a good seal. Mine fell apart at my touch.
