Anyone ditch the spare?
Discussion in 'Wheels & Tires' started by lassiter1979, Sep 12, 2020.
  1. Sep 12, 2020 at 8:17 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I literally built a roof rack so I could keep a full size spare and retain all my box space still. If 5 wheels aren’t in your budget save longer. I’d never run without a spare.
    37x12.5 full size spare ftw!:headbang:
    sensei, Y0TA PR0, Shuffler and 5 others like this.
  2. Sep 12, 2020 at 8:30 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Nice looking truck.
    Mountun Goat[QUOTED] likes this.
  3. Sep 12, 2020 at 8:32 PM
    kwebre
    kwebre New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    I installed a used 285 75r18 I purchased from Bestusedtire.com For $70. Only required bending the tabs slightly but fits fine and piece of mine on hunting trips to National Forrest is worth much more.
    Mountun Goat likes this.
  4. Sep 12, 2020 at 8:46 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks, it’s getting there :hattip:
  5. Sep 12, 2020 at 8:55 PM
    LA184
    LA184 Living the Dream
    2014 4x4, 4.6L Radiant Red Tundra
    4 in lift, 35s, Black Rhino Armory Wheels, Custom Rock Sliders, SDHQ ABS Guards, Warn Winch Bumper, Warn Evo VR 12-S Winch, 4.88 Re-Gear, Rear E-Locker.
    If you run a different spare size you risk causing issues in your differential. If you’re not wheeling, just make sure the spare is in the front and in your in 2wd to not cause further damage.
    Shuffler likes this.
  6. Sep 12, 2020 at 9:03 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Maybe its just me, but in all honesty i don't think I've ever heard this question asked before today. Why in the world would you willingly put yourself and your family in harms way over a few dollars and some extra MPG'S. It makes absolutely no sense to me. Hell, even my 25 T has one, 95 years later i wouldn't be without one no matter the cost or inconvenience.
    betotundra, Mhorst1, Boerseun and 5 others like this.
  7. Sep 13, 2020 at 6:39 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Running Cooper ST MAXX 35/ 12.5/ 20 , Went with 295/70/18 34.5" dia. for spare on stock rim , cut out tabs under bed and it just fits between leafs.
    Mountun Goat and ElNopal like this.
  8. Sep 13, 2020 at 8:53 AM
    Nootherids
    Nootherids New Member
    David
    2013 Tundra Rock Warrior
    35x12.5 Nitto Ridge Grapplers on 17" TRD Rims
    So...about those 35" Spares. I'm reading posts making it sound like it's no big deal. But, is it?
    I'm running 35x12.5x17 and thought it wouldn't hurt to just run a different diameter for a while if necessary. But then I started reading and learning that you definitely don't want to do that, and if it's a must then put the off-diameter on the front and run 2WD. I'm understanding that. I also carry a plug kit and a compressor so I was even considering just dumping the spare altogether. But we are getting a Travel Trailer shortly and will start travelling longer distances more regularly with the whole family. Dynamics of what's acceptable change when it's just me on the road vs the whole fam, and I don't want them waiting on the side of the road for hours for a roadside assistance vehicle.
    So back to the spare... Is it really easy to mount? Should I get one that's close to 35", but 34" is good enough? How about one that's not 12.5" wide? Would any 12.5" fit the stock spare wheel width anyway? Would it be better/easier to find a Metric dimensioned wheel instead (i.e. 365x50/18)? Just trying to keep the family safe here. ;)
  9. Sep 13, 2020 at 9:03 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    If your carrying a compressor, sounds like you can just air down your spare, tie strap around it until it fits in the stock location with the alignment tabs cut off. That’s where I would start if it were me.
    LA184 and Nootherids[QUOTED] like this.
  10. Sep 13, 2020 at 9:04 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    might of been asked, what many vehicles come without a spare?
  11. Sep 13, 2020 at 9:05 AM
    18" TRD Off Road Wheels
    There are some cars, never saw a truck, that come with a small inflation kit instead. Some times it's an option.
  12. Sep 13, 2020 at 9:09 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    My wife’s sienna came with run flats and no spare. A lot of higher end and sports cars come sans spare too.
  13. Sep 13, 2020 at 9:28 AM
    Nootherids
    David
    That sounds pretty damn ingenious. Are those alignment tabs something that would require an angle grinder (which I don't own) or can they be broken off or bent with a hammer or hand saw? And what are your thoughts on the width of a 12.5 on the spare rim?
  14. Sep 13, 2020 at 1:45 PM
    LA184
    The 35in spare can be a pain to lift back to the undercarriage, but it’s not impossible. It’s easier with two people, with one cranking it up and another guiding it back to the right spot. I had a tire shop mount my 35x12.5x18 to the stock rim, and it was fine. I have my family in mind too, and that’s why I went with the full size spare. That’s also why I’ll probably never go any higher in size. I picked up the spare on OfferUp for $40 and paid $20 more for the mounting/balancing.
  15. Sep 13, 2020 at 1:48 PM
    LA184
    I wonder if anyone has done this with 37s.
  16. Sep 13, 2020 at 2:15 PM
    Turtle88
    Turtle88 New Member
    2018 Tundra - Platinum - 3/1 level kit - Fuel Crush 18” / 285/75/18 NRG - Stubby Antenna - TRD Skid plate - NSV light bar - Fuel Crush Wheels - 285/75 R18 Ridge Grapplers - Rear Sway Bar - Tinted Windows - Halo 9 head unit with Focal Speakers, (2) 10" subs and sound deadening throughout the cab - LED interior bulbs - Removed chrome and replaced with color matched mirror caps and black door handles - TRD Shift Knob - Storage unit under rear set - 3/1 Toytec leveling kit - line x bed liner
    If I read this thread right and seeing some say you can get a 35” spare under the bed then I should be able to fit a 285x75x18 under the bed in place of the original spare and this will fit and won’t be too close to the leaf springs or exhaust. Is there anyone here that can confirm if this is correct or not? Thank you.
    Skey44 and Mountun Goat like this.
  17. Sep 13, 2020 at 5:05 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I cut mine off with a side grinder, just because it’s cleaner underneath without. I’m sure if a guy started some spots with a hacksaw, you could smack it back and forth until it breaks.
  18. Sep 13, 2020 at 5:10 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Who knows. I bet you could use a couple 2x4s or something to shape it small where you need it...
    LA184[QUOTED] likes this.
  19. Sep 13, 2020 at 5:13 PM
    #49
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Relocated it since my tires are almost 36".
    TILLY, GODZILLA and Mountun Goat like this.
  20. Sep 13, 2020 at 5:15 PM
    #50
    Handbanana
    Handbanana New Member
    2018 TSS CM 4x4
    Trd sway front Trd sway rear Trd shift knob Nitto ridge grapplers OEM LED FOGS
    Only reason to remove the spare is for a train horn
  21. Sep 13, 2020 at 6:47 PM
    #51
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    I cut mine out with a SAWS ALL , cut pretty easy, used a short 4" blade , but fairly easy , just go slow.
  22. Sep 13, 2020 at 7:08 PM
    #52
    LA184
    Not a bad idea! With it aired down, I think this may just work. 37s may be in my future after all.
  23. Sep 13, 2020 at 7:25 PM
    #53
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    :fingerscrossed::fingerscrossed::spending:
  24. Sep 14, 2020 at 5:42 AM
    #54
    lassiter1979
    lassiter1979 [OP] New Member
    Donnie
    NC
    2020 Tundra SR5 Crewmax 4x4 in Silver Sky Metallic with XSP Package
    3" front lift, 1" rear lift; BFG KO2 295/60R20; color matched front grille and hood bulge
    Guess my post left off some pertinents just as yours made some assumptions. I rarely have my family in the truck, I don't offroad, I don't live in extreme weather environment, 90% of my driving is within 10 miles of my house, and there are more tire shops near me per capita than there are Baptist churches. Which is to say a lot.
    My thought process was that in 25 years of driving I've literally never had to put on a spare. Plenty of screws/nails/flats, but was always able to get an air tank to inflate long enough to get to a tire shop. But I get it, most are uncomfortable with the idea. Was just curious if anyone else was that much of a gambler. :bikewhoops:
    Blueknights75 and Mountun Goat like this.
  25. Sep 14, 2020 at 6:15 AM
    #55
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    7C5662C9-4633-4C1D-99E9-BC0F1B97F09E.jpg 285/75r18 The tire shop bent the alignment tabs back with a sledge and you just have to guide it in there. Stock shackle, Dobinsons heavy leaf-pack for clearance reference.
  26. Sep 14, 2020 at 6:25 AM
    #56
    coTony
    Tony
    Montrose, CO
    My 35 spare rubs the CB shackles and is a pain. Anyone have a single spare tire mount for the bed? Looking to place just behind the cab
  27. Sep 14, 2020 at 6:58 AM
    #57
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I put my 33 in the bed with a 3-way tie down strap using the two factory tie downs and an additional one I put in the floor of the bed. Stainless hardware and bedliner coating.
  28. Sep 14, 2020 at 8:10 AM
    #58
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Won't fit a 37, no way no how. There's just not enough room between the leafs.
  29. Sep 14, 2020 at 8:16 AM
    #59
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    There's a Buffett song about riding around with no spare.
    Black Wolf[QUOTED] and 831Tun like this.
  30. Sep 14, 2020 at 8:22 AM
    #60
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    Harbor Freight you can get set up for under $20. I did it with a Dremel and went through 3 metal cutoff wheels. Would have been much easier with the angle grinder I now own. Wear gloves and safety glasses.
    831Tun and Mountun Goat like this.
