Anyone change oil with this?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BrownieT, Aug 3, 2019.
  1. Aug 3, 2019 at 3:42 PM
    BrownieT
    BrownieT [OP] New Member
    2018 Tundra TRD 4x4
    Was contemplating using this to aide in oil changes but not sure if there any downfalls? Anyone have past experience ?
  2. Aug 3, 2019 at 3:45 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I have not. But I've got to believe that a Fumoto valve makes an engine oil change at least as "easy" as that^^^. And in my book even easier. I'm only talking about the engine oil pan oil. There's always the cartridge oil filter and it's inherent mess.
  3. Aug 3, 2019 at 3:45 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Not sure a cock pump would be good for oil changes. At least not the ones on your truck.
  4. Aug 3, 2019 at 3:48 PM
    Sas
    OKC, OK
  5. Aug 3, 2019 at 3:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I used to use one on a previous car years ago. They would actually pull more oil than by draining. Lot less mess too. No downfalls that I know of. Just make sure the oil is warm. Not hot or cold.
    NewImprovedRon likes this.
  6. Aug 3, 2019 at 4:11 PM
    neirbot
    neirbot New Member
    I have that pump for my boat, but I also use it to suck the oil out of the Tundra through the Fumoto valve. Works like a charm.
  7. Aug 3, 2019 at 4:58 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I have the Mityvac version, same thing, going on 7 years. It is great for changing fluids on cars, especially lexus with all the under carriage cladding. I could pull out all the oil, remove one screw from skid plastic, swap filter and put back together with no mess. Some vehicles prevent the tube from making it to the fluid pan though. I have not tried it on the Tundra yet as I am still using the freebie changes. I still use it to pull out transmission fluid in the pan, motor oil, pwrstr fluid on other vehicles we have. The plastic top is starting to warp a little on top which reduces the seal when removing fluid from the container (pressurizes container to push fluid out, causes extra pumping) but it doesnt affect the vacuum extraction from the vehicle. It can take 20 mins to extract fluid depending on size tubing you use, but you dont need to attend it the entire time.
  8. Aug 3, 2019 at 6:00 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Sas[QUOTED] likes this.
