Anyone carry portable air compressors daily?
Discussion in 'Off-Topic Discussion' started by Tundra234, Dec 27, 2019.
  1. Dec 27, 2019 at 10:45 AM
    Tundra234 [OP] Mods, mods, and more mods
  2. Dec 27, 2019 at 10:50 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    I carry the ARB portable compressor in mine. definitely a must for airing back up after wheeling or fixing a puncture on the road
    Tundra234[OP] likes this.
  3. Dec 27, 2019 at 10:58 AM
    WNY PAT
    WNY PAT New Member
    I use them for work all the time. They’re pretty durable. If you’re going to leave it outside all the time you will need to drain the tank several times a year... condensation builds up in there pretty quick. I empty ours once a month or so.... and always get a couple ounces of water from each one. It’s fine for airing up but it’ll take awhile and will be running a lot to do it.
  4. Dec 27, 2019 at 11:04 AM
    I have one in the garage. I actually used it the other day at Wally world to help someone with a flat bc it was still in the truck at the time. I have the Undercover tonneau so I was looking at getting another one to keep in there full time. At 100 bucks and 150 psi, I dont think it's a bad idea.
    WNY PAT[QUOTED] likes this.
  5. Dec 27, 2019 at 11:17 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yep!
    90651990-9C63-4596-A0FD-0045112B575F.jpg 203233E1-DF78-4BF3-BBBF-3E88F99EB9D5.jpg
    Tundra234[OP] and WNY PAT like this.
  6. Dec 27, 2019 at 11:18 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    thats an awesome set up!
    WNY PAT and boardude[QUOTED] like this.
  7. Dec 27, 2019 at 11:27 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Tundra Limited, 2003 Sequoia SR5, 2006 Tundra Base
  8. Dec 27, 2019 at 11:27 AM
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    How does that work when it gets all covered in mud, I see the cap on the connector, but what about the compressor?
  9. Dec 27, 2019 at 11:43 AM
    Yeah I have a Viair 400c (I think that is the model) for my horns but its not working at the moment...haven't messed with it yet.
  10. Dec 27, 2019 at 11:48 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I avoid mud, I hate mud lol. If it were covered that bad though I wouldn’t use it without hosing it down (I have on board water too when I wheel and for camping trips). The cap comes off and replacement filters are pretty cheap. I always carry a couple spares just in case.
    I have it located there for the rear locker. Lot of guys running the same setup with no issues.
    Pinay likes this.
  11. Dec 27, 2019 at 12:29 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    What are you planning to use it for?
    Check that the SCFM rate is sufficient for your use.
  12. Dec 27, 2019 at 12:35 PM
    taco supreme
    taco supreme New Member
    16 white CM 1794
    A dewalt cordless inflator works pretty well for me. Set the psi and go
  13. Dec 28, 2019 at 6:01 AM
    Now that I'm thinking about it, what power inverter do you guys recommend? Also, even though it will be under my Undercover, should I keep the tank empty or have some pressure built up.....I dont know which would be better for condensation or if it even matters. Thanks.
  14. Dec 28, 2019 at 6:58 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
  15. Dec 28, 2019 at 7:37 AM
    WNY PAT
    WNY PAT New Member
    I wouldn’t leave it pressurized all the time but if you’re using it for the day I’d have it cycle and get to 140PSI or whatever it’ll fill to at home and then put it in the truck. I don’t know that I’d personally use and inverter... I’d rig it with some jumper cables to connect directly to the battery and just hook it up when needed. I don’t know the exact surge amps when the units start up, but it’s pretty substantial.
