Anybody know what this wire is? (RES Diagnostic)
Discussion in '2nd Gen Tundras (2007-2013)' started by Jrharvey02, Nov 13, 2019.
  1. Nov 13, 2019 at 2:13 PM
    Jrharvey02
    Jrharvey02 [OP] New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I’m in the middle of wiring up my
    Pop n Lock and came across this single yellow wire labeled “RES Diagnostic” in the passenger side kick panel, just above where I’m tapping into my door locks for the pop n lock. It’s not plugged in...
    any ideas what this is or what it does?7E313922-8C4C-4789-9547-E3297B7C4DFC.jpg
  2. Nov 13, 2019 at 2:20 PM
    koditten
    Kirk
    Midland of the Mitten
    Remote engine start. So a tech can start the truck from the engine compartment I'm thinking.
  3. Nov 13, 2019 at 3:36 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Self destruct. In case of bad guys.
    Jrharvey02[OP] and TXMiamiFan like this.
  4. Nov 13, 2019 at 4:34 PM
    Jrharvey02
    Weird...but okay. Wonder why it’s unplugged, I do have remote engine start...
  5. Nov 13, 2019 at 4:44 PM
    koditten
    Kirk
    Maybe your truck has remote start, but it was disconnected because the factory remote start is really quite shitty? I dunno.
    Jrharvey02[OP] likes this.
  6. Nov 13, 2019 at 4:46 PM
    Jrharvey02
    That’s a possibility, I’m second owner, truck came with a Clifford 2 way, 1 mile, remote start that works great. So I’m guessing you hit the nail on the head...
  7. Apr 28, 2022 at 1:24 PM
    cdavi060
    cdavi060 New Member
    Virginia Beach, VA
    2017 Super White Tundra Platinum CM
    285/70r18 NITTO RG | Method NV 18x9 | Bilstein 6112 @2.5" w/CB shims, SPC UCA, 5100 & CB +3 Shackles | Entune 3.0 Swap | 2018+ Platinum grille + Pro LED Headlights
    Wondering the same thing about this cable, as I seem to have factorry remote start that does not work. What is RES diagnostic?
  8. Nov 29, 2024 at 9:56 AM
    rreece71
    rreece71 New Member
    I know that this is an old thread, but I wanted to chime in. I was looking for the location of the RES wire. Thank you for posting that it is in the passenger side kick panel. The directions for what I am doing say passenger cowl. That doesn't really narrow it down. The reason I needed to find this wire is because my factory remote start quit working. It will kick on the dash/stereo and the starter will click, but it will not turn over. Then after a few seconds, it shuts everything back off. You have to connect the 2 ends of this wire to re-teach the system. You have 10 minutes once you connect the wires to go thru the programming process. I just thought I would let you know. Thanks!
    koditten likes this.
