Anybody have a tonneau that's bone dry?
Discussion in 'Tonneau Covers, Caps and Shells' started by kirk1963, Feb 24, 2018.
  1. Feb 24, 2018 at 12:55 PM
    kirk1963
    kirk1963 [OP] New Member
    Thanks!
  2. Feb 24, 2018 at 1:13 PM
    Sunnier
    Sunny
    San Diego, CA
  3. Feb 24, 2018 at 1:14 PM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    The covers are usually not the problem. The tailgate sometimes leaks. Others have installed tailgate seals. I have a revolver X4 and it's 99% dry. No need for me to put a seal on the tailgate. You can get a fiberglass cover that would probably be the most water resistant. Good luck
    kirk1963[OP] likes this.
  4. Feb 24, 2018 at 1:17 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    I just took my MX4 through one of those high pressure touchless a only had about a total of 2 tablespoons of water.
  5. Feb 24, 2018 at 1:19 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    I have had NO leaking issues with my Bakflip MX4 cover. We have had some really good storms here in the Bay Area and I always check to see if there is any water in my bed after every storm. So far no problems.
  6. Feb 24, 2018 at 4:31 PM
    Undercover one piece lid no water at all inside back
  7. Feb 24, 2018 at 4:55 PM
    mscroggi
    mscroggi New Member
    I believe you will always have a tiny bit of water seep in at the top corners of the tailgate.. It is virtually impossible to completely block out every drop of water, especially when there is pressure.
    Even the tailgate cap has an uneven surface which would lend itself to a tiny bit of leakage.. BUT the leakage is so small.. It's a non-issue, at least for me.
    See post #20 https://www.tundras.com/threads/tri-fold-tonneau-cover.19597/#post-449771
  8. Feb 24, 2018 at 7:34 PM
    kirk1963
    Thanks guys - give the large variation in peoples experiences I wonder how much of it is related to proper installation. Thanks for all the info.
  9. Feb 24, 2018 at 7:44 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    What he said....
    Had one on a GMC, always dry..........
  10. Feb 24, 2018 at 8:03 PM
    Bones2012
    Bones2012 2012 CM
    Windy City
    2012 Black Crewmax
    Step Tubes BakFlip VP Dee Zee Bed and Tail gate mats Pop A Lock tailgate lock Smitty Built M1 Rear Bumper Weather Tech mats Interior LEDS Remote control Bed Lights Cabelas seat covers
    BakFlip VP
  11. Feb 24, 2018 at 8:33 PM
    Tundra9831
    Tundra9831 New Member
    no leaking under my Diamondback HD, but we haven't had many storms in the SF Bay Area since I've had it.
  12. Feb 25, 2018 at 6:27 PM
    mscroggi
    mscroggi New Member
    Well yeah... the one piece lids typically extend past the top edges of the bed. But the loss of flexibility to open all or part of the bed up to hauling tall cargo is a huge consideration.
  13. Feb 25, 2018 at 6:28 PM
    Yeah when I load up items it's like Tetris..truck came with it
  14. Feb 26, 2018 at 5:40 PM
    heywaitfourme
    heywaitfourme New Member
    Chesapeake, VA
    Diamondback HD has been dry since she he say I put it on. Expensive but worth every penny. Only regret was waiting so long to purchase as I was scared off by sticker price. Turns out, it is worth it.
    Tundra9831 likes this.
  15. Feb 26, 2018 at 6:38 PM
    mscroggi
    mscroggi New Member
    The Diamondback HD is certainly a supreme unit. but it literally costs twice what my Bakflip MX4 costs. Its another cover that extends over the top of the vertical bed walls so there is no question that it stays dry.. But the inability to fold the cover away to use the bed for tall cargo is a deal-breaker for me. Don't mis-understand.. I love the cover. Its just not a fit for people like me. It all boils down to what you are trying to accomplish with covering the bed.
    Okimar likes this.
  16. Feb 26, 2018 at 6:48 PM
    Tito
    Tito New Member
    2018 Tundra Crew Max TRD 4x4
    TRD Pro grill, Nerf bars, Roll n Lock bed cover, TRD intake sytem
    No rain in SoCal! But after a wash, I have a Roll-n-Lock and rarely have any leaks.
  17. Feb 26, 2018 at 6:48 PM
    heywaitfourme
    Chesapeake, VA
    No denying that it has limitations and that it is not for everyone. I will say that the panels are removable in 2-3 minutes. The center bar does require an extra minute or two and a wrench.
    I had a bakflip hd as my last cover and I hated it after two years. Leaked REAL bad and the seals did not hold up to the southern heat. Plus, a coat hanger is all that’s needed to across the bed of the truck if the tailgate is locked. The only way you are getting into my bed is with some serious power tools.
    Good luck in what you pick. That’s why there are hundreds of options.
  18. Feb 26, 2018 at 7:01 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
  19. Feb 26, 2018 at 7:08 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    NO leaks from my Bakflip MX4. Very happy with this cover.
  20. Feb 26, 2018 at 7:15 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have a tri-fold soft tonneau from Rough Country. (I think they are just about all the same, with different brand names glued or stitched to it; maybe small differences such as improved seals). Anyways, mine has a special dust seal in the front where I know some other brands leak, and the tailgate seal is also very tight. I have not had it in the rain yet, but I have tested it with a pressure washer all the way around and there were no leaks.
  21. Feb 26, 2018 at 8:25 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    I have the solid top undercover, dry as a whistle.
    Why would a whistle be dry?
    I cannot whistle when my lips are dry either....
    Boerseun, Sunnier and Mountun Goat like this.
  22. Feb 26, 2018 at 8:30 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I have the old undercover one piece with a tailgate gasket kit and I’ve never seen water in there. So I’ll call it dry.
  23. Feb 26, 2018 at 9:10 PM
    Smiley
    Smiley New Member
    08 Tundra TRD
    I have that same one, it came on my truck. When I got it the top had rubbed through the paint, clear to bare metal.
    So I had bed liner sprayed all the way around the top edge of the bed and tailgate. Now the top sits on it real nice and the gaps are smaller too.
    Mountun Goat[QUOTED] likes this.
  24. Feb 26, 2018 at 9:11 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I see mines rubbed straight through too now that you mention it! Good call on the bed liner. Your truck looks just like mine only crewmax haha
    Smiley[QUOTED] likes this.
  25. Feb 26, 2018 at 11:00 PM
    seatrout
    seatrout New Member
    West Coast, BC
    2017 Off Road
    In Vancouver, BC with a mx4 and it leaks quite a lot unfortunately. It does rain here quite a lot too - unfortunately!
  26. Feb 27, 2018 at 6:29 AM
    Dejohnson8034
    Dejohnson8034 New Member
    Prosper, Texas
    2017 Tundra Limited
    Have an America Tonneau foldable cover, only leaks near tailgate
  27. Feb 27, 2018 at 6:58 AM
    Trooper2
    JR
    I would think any of the foldable covers will leak in time. Most if not all pliable materials, where the folds occur are going to "weather" from the elements. They also discolor which would bother me as well. They are still going to keep most of the water out. I have a roll up BAK15121 on my work truck; gets wet in tailgate area, not a lot but enough to mess up any cardboard boxes that may be in there. I keep most of my important stuff back there in some Contico boxes where they stay dry. The draw back to any roll-up cover is the the loss of space by the cab where the cover retracts into, I can it the "can".
    As mentioned previously, the hard cover like the Undercover is going to be the dryest for sure. They are not that hard to remove if needed, probably best with two people though.
  28. Feb 27, 2018 at 8:30 AM
    Smiley
    Smiley New Member
    08 Tundra TRD
    Yeah I thought they were the same untill I saw you rear window. The bedliner mode is the ticket.
  29. Feb 27, 2018 at 9:46 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    I have a cheapy Tonno Pro with tailgate gasket and my gear stays dry unless i pressure wash the seam.
  30. Feb 27, 2018 at 9:52 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Always had a little leakage with my Extangs, also on various other customers of mine seem to usually have a little.
    Not many where there was a lot of water, in those cases more often than not it was a bad install. A couple were defects.
    I don't see too many where there are no leaks when talking to truck customers of mine about such things.
    Now I have a #BAMF bed rack and that things leaks like a mofo!!
