Anybody got pics of Tundra on 33 tires
Discussion in 'Wheels & Tires' started by BigJohn6886, Nov 14, 2018.
  1. Nov 19, 2020 at 3:46 PM
    Nikwho
    Nikwho New Member
    Nik
    Black 2015 Limited TRD Tundra
    Yes
    To be fair, these 285/65-20's are not 33's. That is a 34.6"x11.2" tire. Apparently lots of people are being told that these are 33's. I bought my truck with 285/65-20 BFG A/T's on it. They look great. Love the tire. But, not a 33" tire. Much closer to a 35. Same exact height as the 315/75-16's on my Land Cruiser, that "people" say is a 35" tire. Both are 34.6". I'll follow up with a picture of the same truck (it is leveled up front) with 33's, too. Need to take a picture, though. The 20" wheels came on my truck when I bought it. I am also a fan of 17" wheels, and more sidewall. Makes for a much nicer ride. But, I like that everyone likes different stuff! I dont want everyone's vehicles to look like mine!
  2. Nov 19, 2020 at 3:54 PM
    Nikwho
    Nikwho New Member
    Nik
    Yes
    Even with overall tire diameter and width being equal, the look changes so much, particularly as wheel diameter, width and offset changes.
  3. Dec 8, 2020 at 8:14 PM
    Lugnuts2020
    Lugnuts2020 New Member
    2018 crew max
    Here is mine......285/55/20. Just a hair under 33. Front leveled 1-1/2”. After I put the flairs on, It made the wheel and tire set up seem less proportionate to the truck. Now wishing it chose a larger size. :annoyed:
    Rica25 likes this.
  4. May 10, 2021 at 11:52 AM
    kjb106
    kjb106 New Member
    Kyle
    2017 MGM Tundra
    Hey man, what brand tires are those?
  5. May 10, 2021 at 3:43 PM
    Bigkitchens
    Bigkitchens New Member
    Alabama
    2014 1794 crewmax 4x4
    Front and back trd sway bars, 14 inch magnaflow dual in dual out exhaust, undercover bedcover, rough country 2 inch leveling coilovers and rear shocks, 285/60/20 nitto ridge grapplers, wireless charger, driver grab handle, tech12volt 10 inch sub and enclosure upgrade , and stillen cold air intake .
    Here's my 2014 1794 with 2 inch leveling shocks, And 285/60/20( 33 1/2 x 11.2) , and stock 20's. I just had to trim the ears off the front of the skid plate. I can't put a finger in between the tire and the steering knuckle.
  6. Oct 14, 2023 at 6:03 PM
    Ezery
    Ezery New Tundra owner 2023
    Ezery
    Fresno
    2023 Crewmax ideas
    I couldnt find a pic, but i found this.
    33“ Tires on a 20” Rim
    When fitting 20” rims, always make sure you don’t opt for an aggressive negative offset since the Tundra factory axle is quite wide. Always try and stick to a +18 to +20 offset for the perfect fit.
    For example, a 33×12.5 R20 will fit perfectly without any rubbing at all. Wheel clearance is 100% both ways as well as in reverse. The 20” tire is a great fit! There is about a finger space between the tire’s inner side wall and the springs and still clears the UCA fine.
  7. May 21, 2024 at 10:53 PM
    Sophara
    Sophara New Member
    Sophara
    2017 Super White Tundra Platinum
    Bad cover
    I had a 33 inches tire and I do a gps run on multiple app they came out pretty accurate.I had 33 inches on stock for a while then I go with 1.75 leveling kit and now it’s stand pretty level to the back I sit at 39 in the front and 39 and a quarter in the back.
    ZappBrannigan likes this.
