Any way to avoid the cab mount chop?
Discussion in '2.5 Gen Tundras (2014-2021)' started by joem1cha3l, Oct 8, 2016.
  1. Oct 8, 2016 at 9:32 AM
    joem1cha3l
    joem1cha3l [OP] New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    With the new tires and new wheels, I'm rubbing and it ain't good. Any way to avoid the cab mount chop?
    Considering going to a BOSS suspension from Toytec (also looking at others), but I'm not sure if that small lift will help at all? I'm currently running 2.5" level up front
  2. Oct 8, 2016 at 10:25 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    What size tires and what wheels are you running?
  3. Oct 8, 2016 at 12:12 PM
    Offset makes a difference. UCA'S can help too
  4. Oct 8, 2016 at 3:15 PM
    joem1cha3l
    Albany, NY
    Running 275/70/18's on 18 x 9 Ballstic Wheels with a +12 MM offset.
  5. Oct 8, 2016 at 5:46 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Shouldnt have rubbing issues with that setup....Try a new alignment. Tell the tech to max the Caster out (pushes the lower control arm as far forward as possible) and then pull back just until the camber is back in spec.
    With just a couple inches of lift (your leveling kit) and the alignment done in that way it will drive the best on the street and shouldnt have rubbing issues. At 3" of lift I can clear 35x12.50s with 18x9 +12mm with no noticeable rubbing in DD use and the alignment done this way.
    If that doesnt fix it, well we sell CMC plates! ;) haha
    ColoradoTJ, csuviper, Law323 and 3 others like this.
  6. Oct 8, 2016 at 8:27 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    what @Relentless said is spot on.
    There shouldn't be any rubbing on 33's even on a 2" lift. o_Oo_Oo_O
  7. Oct 8, 2016 at 10:35 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    I'm running the same set up except +20 on my 18x9 fuels, no rubbing whatsoever
