any tricks for getting through firewall grommet?
Discussion in '2.5 Gen Tundras (2014-2021)' started by smslavin, Aug 8, 2017.
  1. Aug 8, 2017 at 4:12 PM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    I know I'm setting myself up for some fun comments but, I'm having trouble getting it through the hole and I'm fresh out of KY.
    Trying to feed the SwitchPros connector through. I don't remember the FJ being so tight. Tips, tricks, suggestions of all kinds would be welcome.
    joonbug likes this.
  2. Aug 8, 2017 at 4:15 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    have you tried stretching out the hole with your fingers? Try one finger first, then two, then try to get three in there.
    jobe, jfrd30, 15whtrd and 7 others like this.
  3. Aug 8, 2017 at 4:15 PM
    Romex house wire zip tie or electrical tape push through its tough
    smslavin[OP] likes this.
  4. Aug 8, 2017 at 4:23 PM
    smslavin
    Hudson Valley
    Some stuff
    That's exactly the helpful suggestion I'm looking for...
  5. Aug 8, 2017 at 4:24 PM
    Wooo:eek:
    joonbug[QUOTED] likes this.
  6. Aug 8, 2017 at 4:38 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    Try a wire coat hanger,wrap the electrical wire around it and then wrap it with electrical tape, push and pull like hell.
  7. Aug 8, 2017 at 4:50 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    I use the Thexton THE476 wire tool. It's basically a hollow screwdriver works great
    NewImprovedRon likes this.
  8. Aug 8, 2017 at 5:01 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    If you ever want to make a new location for wires through the firewall I suggest using firewall grommets. You can order them in different sizes pending the amount of wires you need to feed. The inside seal also tightens as you fasten it on.
  9. Aug 8, 2017 at 5:03 PM
    smslavin
    Hudson Valley
    Some stuff
    Joon's method won
  10. Aug 8, 2017 at 5:12 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Were you able to do it with your own fingers, or did Joon come over and try his fingers too ? :rofl:
    jfrd30, Spvrtan, BlueBottle and 4 others like this.
  11. Aug 8, 2017 at 5:33 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Is that what your wife did to you?
  12. Aug 8, 2017 at 5:34 PM
    Eclipsed & Floating
    Voluptuous Whitey
  13. Aug 8, 2017 at 6:08 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Seriously do what swede78 said. I had to get a tiny connector through and it was so difficult. It felt like there was a second grommet on the inside, but couldn't even see it. Next time I'm getting a coat hanger and tape like crazy to it, make a huge cut in the rubber and going to yank it through.
  14. Aug 8, 2017 at 9:35 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    ^^ this ^^
  15. Aug 8, 2017 at 9:50 PM
    15whtrd
    15whtrd Mr. Blonde
    I bet a tire plug insertion tool would work perfect.
  16. Aug 8, 2017 at 9:54 PM
    15whtrd
    15whtrd Mr. Blonde
    IMG_3184.jpg I have quite a few of these laying around collecting them over the years. I'm sure the tools others suggestion would work great but this could be free if you have one.
  17. Aug 8, 2017 at 10:09 PM
    Eclipsed & Floating
    Voluptuous Whitey
    It's actually a double sided gasket that has the same lip on the interior as the exterior of the firewall
  18. Aug 9, 2017 at 4:34 AM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Coat hanger
    ChucklesToy likes this.
  19. Aug 9, 2017 at 5:20 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    You going to at least kiss the grommet before you fist it?
    CM-LENNY and joonbug[QUOTED] like this.
  20. Aug 9, 2017 at 5:43 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    :eek:
  21. Aug 9, 2017 at 7:37 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
