Any time fog lights
Discussion in 'Lighting' started by TXRailRoadBandit73, Jun 2, 2016.
  1. Jun 2, 2016 at 11:58 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Any done the anytime fog light mod as per instructions via tundrageeks.com for 2014+ ??? I am not electrically inclined but read the instructions posted on that thread from gray connection to pink connection what are other connections for??? to change back to non anytime??? Cause now after all snips you have 4 then u jump but are other 2 left??? Please help
  2. Jun 2, 2016 at 12:38 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
  3. Jun 2, 2016 at 6:31 PM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    I did the mod as described for my 2016. The two remaining ends I just covered them with tape so they wouldn't accidentally ground to something.
  4. Jun 2, 2016 at 7:42 PM
    Who's instructions did u follow?
  5. Jun 3, 2016 at 4:07 AM
    Medic
    Medic New Member
    Ontario, Canada
    I wanted to provide a link to several different Fog Light Modifications that I have found on other forums for easy reference on here.<br /><br /> <br /><br /><b>Toyota Tundra Forum - Foglight Anytime mod - easiest way???</b><br /><br /><b>Fog lamp mod - Toyota Tundra 2012</b><br /><br /><b>FREE 2014 Toyota Tundra fog light Mod.</b><br /><br />The attached 2 pdfs go through the different mods. The easiest is "FogLightsEddieV1.pdf". This is the one that Sean266 and I will be doing soon. I will keep this thread posted on progress, ease of install and install tips.
    I used the free 2014 version. Hope this helps.
  6. Jun 3, 2016 at 7:16 AM
    Morning thanks!
  7. May 11, 2019 at 1:41 PM
    Samuel3rd
    Samuel3rd New Member
    Samuel
    2006 Double Cab Tundra 4X4 SR5 Green
    Roll up bed Cover and rain drains LED upgrades with grill backlight 3000w inverter upgrade K&N filters Battery Bank in Bed Custom low profile 24 Gal fuel tank in bed
    I know this is old, but any guidance on doing this on a 1st gen? I’ve seen some stuff about doing it from under the dash, I was curious if you could do the same thing closer to the lamp?
  8. May 11, 2019 at 1:49 PM
    SG TRD
    SG TRD New Member
    I did this mod using the edies diy . no cutting of wires . used a jumper wire to connect to the two wire that were unclipt from the harnesses
