Any one have these tow mirrors? Thoughts?
Discussion in 'General Tundra Discussion' started by TomC843, Jul 19, 2018.
  1. Dec 30, 2019 at 1:14 PM
    #121
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    My mirrors have a little BSM marker but it's not lit. I don't think it's wired for it though. If the mirrors have it wired and it does stay on check the connectors to see which truck one is blank and the corresponding mirror one is pinned - could then de-pin that wire and tape it off. That way it's not cut and can go back in if it's not the right one. Don't see how it could be lit up without connecting wires to send a current through.
  2. Dec 30, 2019 at 10:20 PM
    #122
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    so yours work perfectly and are entirely plug and play (with the exception of wiring the reverse lights yourself. thats easy i got that part)
  3. Dec 31, 2019 at 8:15 AM
    #123
    belanger9
    Edmonton, AB
    A bunch
    They work how I expected.
    They don't have running lights on the forward part, that is just a signal light. And they bolted right in and the heated part works fast - like they're melted faster than the area around the windshield wipers.
  4. Jan 20, 2020 at 5:58 PM
    #124
    Meltz
    Meltz New Member
    I finally settled on a set of mirrors. My mirrors have everything I was looking for in a row mirror. I got them off ebay. They have BSM, heated, power, front facing clearance lights and blinkers and also an inside the mirror blinker, so the front and back of the mirror blinks. Best of all they are sequential lighting for the blinkers. I have attached a photo. I'll grab a video of the sequential lighting of the blinkers if you guys want.
    vegas4x4, g6t9ed, tinman10101 and 3 others like this.
  5. Jan 21, 2020 at 4:48 AM
    #125
    Silverfoxtundra
    Silverfoxtundra New Member
    JC
    Orlando, Florida
    2018 Tundra limited
    Leveling kit, bed racks, roll up tonneau cover, ICS dash mount, ICS usb charger, under hood led lights, truck bed led lights (mattgecoled), Fab Four premium rear bumper, window tint on all glass.
    JC-TRD did you have power mirrors prior to installing these? I have a 2018 limited without was wondering if I switched out the mirror control switches would I be able to run the mirrors you used?
  6. Jan 21, 2020 at 5:00 AM
    #126
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Wanna sell the ones you took off?
  7. Jan 21, 2020 at 5:03 AM
    #127
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Those look really good!
  8. Jan 21, 2020 at 9:15 AM
    #128
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    Which mirrors would work with an 18 Limited?
  9. Jan 21, 2020 at 10:17 AM
    #129
    Meltz
    Meltz New Member
    Just look for the options on the new mirror that you currently have.
  10. Jan 21, 2020 at 10:46 AM
    #130
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    That looks awesome. Do you have a link? Thank you in advance.
  11. Jan 21, 2020 at 12:05 PM
    #131
    Meltz
    Meltz New Member
    Yeah the sequential lighting is awesome I love it. Also love the tube led lights vs the LEDs on the other models. Link is here.
    https://www.ebay.com/ulk/itm/233377724194
    tinman10101[QUOTED] likes this.
  12. Jan 21, 2020 at 1:18 PM
    #132
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Are the supplied wires for wiring up the turn signals? The trailridge mirrors have the signals wired to the connector because the factory mating connector has the contacts for the signal wiring.
  13. Jan 21, 2020 at 2:30 PM
    #133
    Meltz
    Meltz New Member
    Actually for mine they were 100% plug and play. No additional wiring was needed. I have a 2017 limited and the signals both front and back of mirror and also clearance lights worked right out of the box plug n play. As many stated on these forums, the limiteds at least, are wired from factory to have turn signals and clearance lights built in factory harness but for some reason not offered from Toyota via factory mirrors. However additional gray/white wiring is included in all aftermarket tow mirrors it seems, with some mirrors those are needed to get clearance working via grounding the clearance lights, with these they are not needed. I believe those extra wiring are to make the spotlights work on the edges of the mirror. For me I decided not to activate the spot lights. Everything else works 100% plug n play. The one issue I have with my set is the BSM lights are not bright enough to see in the day time. Does anyone know if the BSM lights are built into the actual mirror itself or are they backlit. I was thinking if backlit I would just change the bulbs out to LED.
  14. Jan 21, 2020 at 10:29 PM
    #134
    Badbetty
    Badbetty New Member
    Beth
    2020 Tundra Limited
    Intake
    I’m looking for mirrors for 2020 limited?
  15. Jan 28, 2020 at 9:40 PM
    #135
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    if you buy these PLEEEASSEE let me sell them to you lol
    its crazy how much people are willing to over pay for things. thats a reseller...those mirrors can be at your door in 4 days for $150
    strangeobject likes this.
  16. Jan 29, 2020 at 5:10 AM
    #136
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    Which mirror is that
  17. Jan 30, 2020 at 10:20 PM
    #137
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
  18. Feb 3, 2020 at 4:44 PM
    #138
    Tundra13jr
    Tundra13jr New Member
    concord nc
    2017 Toyota Tundra 4x4 magnetic grey
  19. Feb 10, 2020 at 5:59 PM
    #139
    TundraTO
    TundraTO New Member
    Toronto, Ontario, Canada.
    2016 Tundra CrewMax Platinum
    XB Morimoto Headlights TRD Grille - Paint Matched 20" Fuel Vector D579 275/65R20 BFG K02s - trimming required
    Do the mirrors vibrate at all? Been wanting to pull the trigger on a set but can't stand mirror vibration.
  20. Feb 10, 2020 at 7:45 PM
    #140
    belanger9
    Edmonton, AB
    A bunch
    Haven't noticed any wind or road vibration on mine - only vibration is from the mid range speaker in the door when the sound is turned up. Had that same issue with all mirrors.
  21. Mar 22, 2020 at 2:54 PM
    #141
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    I'm gonna order that harness now...what year did you say your truck was on boost auto parts, because they're made for a GM...they still work?
    And how did u have ti modify the wiring?
  22. Oct 22, 2020 at 5:04 PM
    #142
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    Does anyone know how to change out the courtesy light LED bulbs? I just got them wired up but now I'm finding that they're...lacking
  23. Mar 16, 2022 at 4:52 PM
    #143
    CanadianTundra
    CanadianTundra New Member
    Brad
    Ontario Canada
    2014 Black Tundra Platinum
    Sorry to dredge up an old topic, but I have a dilemma that I can't figure out. I have a 14 platinum, and recently swapped out my mirrors for the factory towing mirrors. They have the front amber led, and according to all I have found on the threads is you need to add a power wire to pin 9 to allow them to operate as front marker lights.
    Problem is, I'm in Canada and all 18 pin wires are in place on the harness. Driver side is purple, passenger is brown. Not sure if anyone can help me identify how to get the running lights to work?
    Any help would be greatly appreciated!
    Thanks everyone!
  24. Mar 16, 2022 at 5:31 PM
    #144
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Factory tow mirrors don't have a front facing led, They're on the sides.
    Maybe post a pic of then?
    Get a test light. They're under $10. You can check the wires 1 by 1 and the test light will light up when you find the right wire when you turn on and off the switch.
  25. Mar 16, 2022 at 5:35 PM
    #145
    CanadianTundra
    Brad
    Ontario Canada
    My apologies, I meant the side amber running lights. I'll see if I can get a test light, but I moved to a rural area of new Brunswick, not sure who around here would have that. I'm about 35 minutes to the closest place that would possibly have this. If I know what pin powers the amber running lights I could just bypass the pre-existing wire and feed a power feed to it.
    I'll keep you posted...
  26. Mar 16, 2022 at 5:47 PM
    #146
    Berdine
    Binghamton, NY
    I'm looking all over for it. I tapped into 1 on my 2014, just can't remember which one it was. Someone has to know which pin and plug.
  27. Mar 16, 2022 at 5:50 PM
    #147
    Berdine
    Binghamton, NY
    Did you see this?
    https://www.tundras.com/threads/diy...power-folding-tow-mirrors.42865/#post-2673451
  28. Mar 16, 2022 at 5:58 PM
    #148
    CanadianTundra
    Brad
    Ontario Canada
    I did, but the pin on both sides are occupied but wires, not sure if I would remove them and wire power to that instead? Was not sure if in Canada we got a different wiring configuration?
  29. Mar 16, 2022 at 7:18 PM
    #149
    belanger9
    Edmonton, AB
    A bunch
    If I'm understanding correctly you would have to swap out that wire in pin 9 location. From factory that wire gets power once the lights are turned on, if I read it correctly you want it to be on like a DRL so that would require a wire powered on with the ignition.
    The mirror lights weren't designed to be on in all driving situations, only come on with the lights. Even SR5's are plug and play even though they don't have those lights on standard mirrors.
