Any one have these tow mirrors? Thoughts?
Discussion in 'General Tundra Discussion' started by TomC843, Jul 19, 2018.
  1. Apr 22, 2019 at 3:02 PM
    #91
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    I actually like it as a courtesy light and they don’t bother me visually but that may be because I’m 6’4 lol
    legger99 likes this.
  2. Apr 22, 2019 at 3:12 PM
    #92
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    Well I am not that tall, only an inch under 6 ft though, but do the lights shine more toward the ground or straight back? It was hard for me to tell when bench testing.
    My thought on the cargo light wire would be it could be used for backing up if needed too and I think the cargo light comes on with the dome lights if the switch is in the correct position. I currently have mine off because of the cap and the light doesn't do anything...
    And I need to locate this cargo wire regardless for my upcoming bed light install, the cab to bed wire has been in place for a year now.
  3. Apr 22, 2019 at 3:28 PM
    #93
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    It shines more straight back but the bottom bulb angles down some as far as I can tell and you can definitely wire them to be dual functional!
  4. May 5, 2019 at 7:51 AM
    #94
    Punisher17
    Punisher17 New Member
    I looked at my plug for my 2007 SR5 crewmax and there are only 3 wires going to it. I believe they are positions 10,11 and 12 for mirror adjustment only. Which means they don't have wires for blinker, drl and the courtesy light. I've been debating getting these mirrors. The main purpose for me is to see better with them. I'd probably run the courtesy light to my courtesy lights and the drl to the window switch but I was wondering if anyone has figured out which wire I could run the blinker light to possibly in the door sill on each side of the vehicle. I would imagine that there is a wire for the rear blinkers in that harness. Any help appreciated.
    If not I was thinking about forgetting about the blinkers and running those as drl also so they wouldn't have blinkers at all..
    And another option would be to spray paint the side markers black and just not wire anything lol
  5. Jul 15, 2019 at 12:48 PM
    #95
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    So what did you end up getting??? I basically have the same questions as you, just two years later :)
  6. Dec 8, 2019 at 4:53 PM
    #96
    Meltz
    Meltz New Member
    Where did all of you get these gm type mirrors with BSM? 1aauto only has them with power fold. I have a 2017 limited with no power fold and wanted to keep them manual fold plug and play. Can anyone link me to the gm type mirrors with power fold. I want some that people have bought and have proven to work with no vibration. Thanks
  7. Dec 8, 2019 at 5:04 PM
    #97
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I searched 'Tundra Tow Mirrors' in ebay and found a set.
    https://www.ebay.ca/itm/123561850344
    Not 1000% sure if the BSM works or was wired in the set I bought, my truck doesn't have that. Ad says it should though.
    #97
  8. Dec 8, 2019 at 5:09 PM
    #98
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    https://www.ebay.com/ulk/itm/312420933089
    #98
  9. Dec 8, 2019 at 5:38 PM
    #99
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    I have this set: https://ebay.us/JrGBiI
    I installed them last April. I did bench test them and found out one side had the wiring switched. I also clipped the BSM wire as I didn't have those. After a week or two I had to tighten the pivot by taking off the curved cover as the right one kept moving when the door was closed.
    Other than that no issues or vibrations. I never did wire the "backup strobes" to anything. And the front lights function with the parking lights, and the red mirror leds and heaters work great too! I had also extended them a lot last summer pulling my RV. I don't recall any vibrations when extended either.
    My truck doesn't have power fold, or BSM.
    I had a text file with notes from mine here it is in case anyone needs it (and after reading those I think I moved the ground from the single plug to the main harness, as there is a common ground inside the mirror, so the reverse lights would be a one wire connection now):
    on separate plug:
    for white reverse leds:
    white is +
    gray is -
    purple is blind spot
    blinker on mirror glass is pink w/ orange stripe
    the negative from separate plug
    is the ground for the orange running lights
    blue wire
    RIGHT MIRROR
    has white and blue wires reversed
    for white leds and orange running lights
    #99
  10. Dec 8, 2019 at 8:24 PM
    #100
    Meltz
    Meltz New Member
    Ok awesome I actually found some on eBay and was thinking hard about getting some. I suppose eBay ones can be trusted? I just thought everyone was buying 1aauto ones.
    Does anyone know if the in mirror signals on some of the mirrors work with factory plug and play or some additional wiring need to be done?
  11. Dec 8, 2019 at 8:57 PM
    #101
    belanger9
    Edmonton, AB
    A bunch
    Should be plug and play. If it's not it would be as simple as tapping into a wire in the mirror. My truck didn't have signals in the original mirrors but the truck is already wired for them. Those mirrors tie into that OEM wired circuit for the light on the back I can verify, I would assume the manufacturer of these would use the same circuit for the face signal.
  12. Dec 9, 2019 at 10:01 AM
    #102
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    I also think they would be plug/play. My wire cross issue wasn't the norm. It was wired wrong from the factory and I didn't want to bother with returning them.
  13. Dec 18, 2019 at 9:02 AM
    #103
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    so boost auto sells kits to swap the marker lights to white led... are mirror clearance lights required to be amber? I know a member on here swapped his, but he’s in Canada. I’m in TX... wondering if I’d get pulled over...?
  14. Dec 18, 2019 at 3:46 PM
    #104
    Meltz
    Meltz New Member
    Update all. I just installed some tow mirrors I got off ebay. Everything appears to work, even a blinker located on the inside of the mirror however there's outside LEDs that are supposed to run the blinkers and the running lights and they do not light up off the factory harness. Any ideas how to fix this? I thought they would work since all the other features on the mirror works including the blinker on the inside of the mirror. Belanger9 said the truck is wired for this. Any idea how to fix these outside LEDs. If so is it an easy fix?
  15. Dec 18, 2019 at 5:25 PM
    #105
    belanger9
    Edmonton, AB
    A bunch
    Are you talking about the backside turn signals being on as running lights? Mine do not do that, they are only turn signals. The truck is wired for them, I had the running lights on with OEM tow mirrors, but the GM mirrors I bought the lights only come on with the turn signal with no extra wiring. There is extra wiring to do for puddle lights if that's what you're asking about - there's too many lights on these damn things it is kinda confusing.
  16. Dec 18, 2019 at 5:39 PM
    #106
    Meltz
    Meltz New Member
    So I got these
    https://www.ebay.com/ulk/itm/333419369708
    These have the in mirror signal lights for when the signals are on. These work as well as power mirror and BSM seem to work. However the problem is the outside(front) of the mirror, lights do not work. I see you also had an issue with that above. How did you fix this so the signals and running lights work?
  17. Dec 18, 2019 at 5:49 PM
    #107
    belanger9
    Edmonton, AB
    A bunch
    Mine the front running lights never worked, they only work for turn signals and that was plug and play for me. The truck is able to run running lights as mine did it with OEM style tow mirrors, the GM mirrors I have won't do it though. So if yours are doing the same as mine it would be wiring inside the mirror, I'm not sure how to get it to work as I haven't even looked at getting them to work in that way.
  18. Dec 18, 2019 at 6:03 PM
    #108
    Meltz
    Meltz New Member
    Thanks for clarification. I know there's a way but I'm thinking because I technically have 2 blinkers, I'm wondering if my blinkers on the inside of the mirrors took priority to run vs the lights on the back. I'm sure if I exchanged for mirrors without signals inside the mirror the back LEDs would work as a signal. If anyone has any clue on how to fix these and make the outside LEDs work, I would greatly appreciate it. I know I have to wire it but I just don't know how or what to do. Thanks!
  19. Dec 18, 2019 at 6:19 PM
    #109
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    My front "orange" running lights wouldn't light up until I grounded those. They seem to share a ground with the white rear mounted puddle lights. I cut the ground wire off the 2 position plug and spliced it to the other plugs ground wire (mirror side) This post has the diagram for that plug (the truck side): https://www.tundras.com/threads/any-one-have-these-tow-mirrors-thoughts.28775/page-3#post-1066943
    Those "orange" lights now are on with the parking lights and do not flash. that is a separate mod that requires diodes to be purchased and installed in the red mirror blinker lights and the orange front lights in-order to make them flash.
    I initially looked into doing this, but I removed one of the glass mirrors and some of the small clips broke off, so I put it back together as I didn't want to risk the mirrors not clicking into place.
    The 2nd issue I had was the puddle lights and the orange lights were switched on the right mirror, but you won't know this yet until you put 12vs to it.
    If I ever do decide to hook up the puddle lights I just need to run a single wire up to each mirror as the grounds are already hooked up.
    I hope this helps.
    Note - I did test all this before I cut the wires!
    Another note - You might not have your truck side pre-wired for the running lights? You can check by looking at the post I linked and looking at your truck to see if the wire is there (looks like you have a limited so I assume it is). Also you could just connect the little wire harness and run one side to ground, and would be an easy test.
    TRD-tv likes this.
  20. Dec 19, 2019 at 4:58 PM
    #110
    Meltz
    Meltz New Member
    That sounds sort of difficult. I'm not good with wiring. I was was just thinking it was my mirrors and to return my mirrors and try a different one as it seems other people with the same trucks have no issues just plug and play and everything seems to work.
    On the other hand it appears many other mirrors include the wiring along with the mirrors making me think many trucks also need additional wiring. I wish they gave instructions with the mirrors. That would make this process a lot easier and less guessing.
  21. Dec 28, 2019 at 5:28 PM
    #111
    JC-TRD-TX
    JC-TRD-TX New Member
    2020 Toyota Tundra Army Green
    6 inch ready lift Kit Ranch hand grille guard
    I got mine color matched and installed today! I had the OEM tow mirrors before and can honestly say these beat those any day. Way better mirrors overall.
  22. Dec 28, 2019 at 6:07 PM
    #112
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    2019 MGM Tundra TRD Sport
    3/1 leveling kit with 295/60/20 Nitto Ridge Grapplers, Go Rhino Dominator D6 step rails, Husky X-Act floor liners (front and back).
    JC-TRD, what mirrors are does?
  23. Dec 28, 2019 at 6:28 PM
    #113
    Meltz
    Meltz New Member
    Great looking truck! How much did that cost you to have them color matched ? And what type of shop did it? I may do that with mine as well.
    JC-TRD-TX[QUOTED] likes this.
  24. Dec 28, 2019 at 6:50 PM
    #114
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    how are these working for you? did this work?
    JC-TRD-TX likes this.
  25. Dec 28, 2019 at 6:57 PM
    #115
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    what about the BSM? how do you disable that?
  26. Dec 28, 2019 at 7:30 PM
    #116
    JC-TRD-TX
    Yes the BSM was disabled. Don’t know exactly how because I had a highly recommended auto shop do this project for me since I knew it would not be an easy one.
  27. Dec 28, 2019 at 7:31 PM
    #117
    JC-TRD-TX
    Thank you!
    I had a auto paint shop do them paint them for me for $120.
  28. Dec 28, 2019 at 7:32 PM
    #118
    JC-TRD-TX
  29. Dec 28, 2019 at 8:45 PM
    #119
    belanger9
    Edmonton, AB
    A bunch
    If your truck is not wired for BSM it doesn't matter what the mirrors are. The BSM wire in the mirror won't have anything to connect to from the truck side.
  30. Dec 29, 2019 at 11:26 PM
    #120
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    my truck doesnt have BSM. from what i understand the light is always lit then. can this be disabled by cutting a wire? which wire?
