Any one have these tow mirrors? Thoughts?
Discussion in 'General Tundra Discussion' started by TomC843, Jul 19, 2018.
  1. Dec 1, 2018 at 7:51 AM
    #61
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Honestly I don’t remember
  2. Dec 1, 2018 at 2:37 PM
    #62
    ARGUNNER
    ARGUNNER New Member
    Do you have documentation or pictures to show how you wired the spot lights and front turn signals/driving lights and where you tied them into your trucks wiring harness.
  3. Dec 14, 2018 at 7:46 AM
    #63
    ARGUNNER
    ARGUNNER New Member
    recently bought a set of aftermarket tow mirrors off of Ebay. I have installed them and everything works great except for the front Driving/Marker lights. There is a pin on the new mirrors that powers the LEDs but my truck mirror harness does not have a wire running to that pin. I want to run an extra wire and tie it into my DRL lights but am having difficulty finding the correct circuit to tap into under my dash. Has anyone run into this before? I don't really care if they are turn signals I just want them on when my running lights are lit up.
    #63
  4. Dec 14, 2018 at 5:02 PM
    #64
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Nice. Want these for my 2017 CM Limited.
    Can you confirm all the electrical functions of the factory units work on the Trail Ridge?
    Ease of installation?
    KELZ84 likes this.
  5. Dec 16, 2018 at 5:49 AM
    #65
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Yes all the Factory functions work as they should. Installation is fairly simple.Plug and play for those that have Factory BSM.
    Y0TA PR0, Paulskie and tundracap like this.
  6. Jan 12, 2019 at 5:17 PM
    #66
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    How did you wired the new replacement DRLs? I'd like to see some pictures of them installed if you have a chance?
    Thanks man.
  7. Jan 28, 2019 at 9:02 AM
    #67
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Did you ever get this all wired up? Any pics? I like these a lot more than the Toyota tow mirrors.
  8. Jan 28, 2019 at 9:10 AM
    #68
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    The mirrors are much better in my opinion,I used a kit from boostauto that makes the front blinkers into running lights as well,other than that they are plug and play!FF1DA9BB-47DF-49C5-9E35-317C94996FCB.jpg
    CAJUN_TRANSPLANT likes this.
  9. Jan 28, 2019 at 9:12 AM
    #69
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Thanks! I saw the comment about clipping the purple wire to remove BSM. Was it a pain to get those backup lights wired up on the face of the mirror?
  10. Jan 28, 2019 at 9:15 AM
    #70
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    I did not run them as reverse lights,I hooked them up as courtesy lights instead.
  11. Jan 28, 2019 at 9:23 AM
    #71
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Oh good idea. So with the amber LED wired up as daytime running lights, the blinker still functions it just lights up brighter?
  12. Jan 28, 2019 at 9:36 AM
    #72
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Yes,it still functions as normal.
  13. Jan 28, 2019 at 9:44 AM
    #73
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Thanks for all of the help
  14. Jan 28, 2019 at 9:58 AM
    #74
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Not a problem!
  15. Feb 18, 2019 at 6:23 PM
    #75
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Is there any plug & play towing mirrors ? I hate having to require crap mostly becuz i dont know how too.
  16. Feb 20, 2019 at 2:14 AM
    #76
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    The mirrors we are talking about in this thread are plug and play as far as the main functionality goes,all you have to wire is the reverse lights which is two wires!
    KELZ84[QUOTED] and Watt maker like this.
  17. Mar 2, 2019 at 12:55 PM
    #77
    CAJUN_TRANSPLANT
    CAJUN_TRANSPLANT New Member
    Cape Coral, FL
    2018 Grey Tundra DC TRD Off-Road 4x4
    OCD console organizer
    Did you try this? If so what wires did you hook to? I was trying to use the two wire clip that came with the mirrors instead of buying a harness.
  18. Mar 2, 2019 at 5:12 PM
    #78
    Yotatundraaah
    Yotatundraaah My tundra stays hungrry
    Southern CA
    2016 Silver Sky Tundraaaah
    Kings suspension Built Right ufc 295/70-18 Toyo AT2 18" XD bully wheels Baja designs foglights Baja designs ditch lights Rago fabrication ditch brackets Tiger auto rock slider Extang solid fold 2.0 cover Read more....
    Rule number 1
    Never buy anything on ebay
    Lol jk:cheers:
    On a serious note, any noise problems with any tow mirrors?
    #78
  19. Mar 7, 2019 at 6:58 PM
    #79
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    I have the a1 tow mirrors for Tundra - technically I have two sets of them. First set was without BSM (for my '14) tundra - second set is with the BSM for my 2018 limited (same ones Idale posted). I like that the bottom portion of the mirror is adjustable vertically and horizontally (and I like the smoked outter light look). Yes, I agree that the other mirrors may look a bit nicer, but function is what I'm about. No wind noise issuess either. The other sets you guys are hooking up are definitely flashy though. I pull a 24' camper and needed them... Now I just have too many, ha! I'm not a car wire/electric guy, but the guys who took this job on definitely got a flashy upgrade! Nice!
  20. Mar 8, 2019 at 6:08 PM
    #80
    CAJUN_TRANSPLANT
    Cape Coral, FL
    No noise. Just pissed I can't figure out how to hook up DRLs and Spots. Pissing me off and seller on ebay just shrugs and says they have no idea. They are super stable, even at 85+.
    #80
  21. Mar 9, 2019 at 4:00 AM
    #81
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    You are going to have to tie into the the original drl wire on the mirror plug on the door side!658AB997-7655-44F9-A5BB-545CB946E4D3.jpg594A6CC3-7882-4D8C-A01A-A6E95419F7CB.jpg
    JimC and Watt maker like this.
  22. Mar 9, 2019 at 11:30 AM
    #82
    CAJUN_TRANSPLANT
    Cape Coral, FL
    Will try thanks!
  23. Mar 25, 2019 at 10:06 PM
    #83
    fireheadman
    fireheadman New Member
    1794 Tundra (2018)
  24. Apr 7, 2019 at 12:50 AM
    #84
    wayoutwanderer
    wayoutwanderer @wayoutwanderer
    Austin, Texas
    2019 Tundra Limited CrewMax 4x4 in Cavalry Blue
    The GM mirrors look a little mismatched to me. Maybe it's just because I know they are GM. I'm sticking with the BSM Trail Ridges since I'm used to the manual OEMs. Just ordered tonight.
    Y0TA PR0 likes this.
  25. Apr 7, 2019 at 5:02 AM
    #85
    davescarp
    davescarp New Member
    Massachusetts
    '18 DC TRD OR
    Wanna sell the set w/o bsm? My sr5 doesn't have it and looking at tow mirrors for boating season around the corner.
  26. Apr 7, 2019 at 10:21 AM
    #86
    YeeYeeTundra
    Ohio
    Sold them to another member from this site, otherwise I would have. He ended up doing a puddle light install on them (and write up also) -- they turned out pretty awesome! I realize the trail ridges may not be as flashy compared to the GM style posted, but I truly have no buyers remorse. They work well/no wind noise and fit the truck style IMO. Hope you find a set on here (as I've been lucky enough to already get a few great buys from this site as long as you keep eyes peeled).
  27. Apr 8, 2019 at 6:45 AM
    #87
    davescarp
    Massachusetts
    '18 DC TRD OR
    OK thanks yeah I saw that thread about the puddle lights. I wanna do that for sure looks great.
  28. Apr 18, 2019 at 7:25 PM
    #88
    CAJUN_TRANSPLANT
    Cape Coral, FL
    Update... Got DRLs working, Still working on backup floods.
    Watt maker likes this.
  29. Apr 19, 2019 at 2:16 AM
    #89
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    So which route did you take on wiring the drl’s?
  30. Apr 20, 2019 at 12:39 PM
    #90
    CAJUN_TRANSPLANT
    Cape Coral, FL
    It came with a little two wire whip and no wiring diagram and when i tried to tap into power with the plug in i had no luck. So I tapped the grey wire on the mirror side of the plug... And then i ran it to the power on the window switch. It was the yellow wire on the LH switch and the white w/black stripe on the RH switch. So when auto lights kick on DRLs draw power from the light that comes on, on my window switch.
