Any OBDII gurus know if the 2004 sends a door open signal?
Discussion in '1st Gen Tundras (2000-2006)' started by Tohopko, Feb 2, 2020.
  1. Feb 2, 2020 at 10:59 PM
    Tohopko
    Tohopko [OP] New Member
    2004DC
    Just trying to figure out if the 2004 DC sends a door open signal to the main ECU. Helps determine whether I can use the "plug and play" AMP Research set up.
    The boards themselves will not be hard to fit, some slight shimming should put them at the right angle--just working out the trigger signals.
  2. Feb 3, 2020 at 12:24 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    connector b10 on the Body control ECU gets a signal from front LH door. pin 15 is the driver front door. Wire color Grey-Red
    both left doors are on connector b10, both right doors are on b11- This is all from the EWD on TIS for a 2004 double cab
    mtntop, Tohopko[OP], bmf4069 and 2 others like this.
  3. Feb 3, 2020 at 5:47 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Not an OBD2 guru but the attached pic is 2005 DC, it does somewhat follow what @empty_lord posted.
    bmf4069 likes this.
  4. Feb 3, 2020 at 7:53 AM
    Tohopko
    2004DC
    EUREKA! Thank you. I'm like a dog watching television when it comes to wiring diagrams--not to mention trying to muddle through with the 05-06 FSM for a 2004.
    With this info, and a little more investigating, I should not need the "plug and play" model.
    mtntop likes this.
  5. Feb 10, 2020 at 10:48 AM
    Tohopko
    2004DC
    Dan, the boards will be arriving this week. Any chance your diagram lists the colors for the other doors? Or if it is a ground signal versus a +?
  6. Feb 10, 2020 at 11:27 AM
    empty_lord
    05 rollover special
    I’ll post up the pdf when I get home. @ me if I forget in 8 hrs
  7. Feb 10, 2020 at 11:39 AM
    Tohopko
    2004DC
    Thanks! I may just tap into the courtesy switches, but that does require a little more wire running.
  8. Feb 10, 2020 at 9:02 PM
    empty_lord
    05 rollover special
  9. Feb 10, 2020 at 9:22 PM
    Tohopko
    2004DC
  10. Feb 10, 2020 at 9:23 PM
    empty_lord
    05 rollover special
    I almost forgot! Work does that to me. my mind cant remember things like it use to lol.
  11. Feb 10, 2020 at 9:26 PM
    Tohopko
    2004DC
    I do appreciate your remembering. My mind is a bit scattered right now, but I'll finish with the hard pain meds tomorrow, so I should be more clear. Miserable, but more clear :)
    empty_lord[QUOTED] likes this.
  12. Feb 11, 2020 at 8:26 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Thanks for that @empty_lord, at least now I know the 05-06 FSM pdf I have is like an 04 in some respects. Still hoping to run across an actual downloadable 04 FSM :fingerscrossed:
    Toho, I take it you still feel like a dog watching television when it comes to wiring diagrams :rolleyes:
    empty_lord likes this.
  13. Feb 11, 2020 at 8:33 AM
    Tohopko
    2004DC
    Absolutely. In fact, my dog may get more out of the television--but these help a bunch. Printing them out in color so I can lay them out and put together a plan for tapping the signal for the running boards.
  14. Mar 17, 2020 at 11:46 AM
    Tohopko
    2004DC
    Bubba, if you ever do find a FSM that covers the 2004 Double Cab, I'm IN! Frustrating to "discover" the little differences after you are already elbow deep in a project.
  15. Mar 17, 2020 at 12:30 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Please do the same @Tohopko , I have run across many downloads specific to 00-03 and 05-06 but only bits and pieces of 04. Even using Google search for "RM1091U1 filetype: Pdf", I was some what shocked I came up empty. I now bounce between the 00-03 and 05-06 when I have issues or to offer assistance and at least get close enough. It's almost as if we are a stepchild o_O
  16. Mar 17, 2020 at 12:46 PM
    Tohopko
    2004DC
    Wonder if a Sequoia manual might be of more use?
  17. Mar 17, 2020 at 3:05 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
  18. Mar 26, 2020 at 8:06 AM
    Tohopko
    2004DC
    I broke down and bought the full paper copies, $180ish from E-bay. If you need something specific looked up, let me know and I'll work on it.
    BubbaW[QUOTED] likes this.
  19. Mar 26, 2020 at 8:38 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    :thumbsup:
    just pages 1-4000 Thanks :thumbsup::cool:
