Any KC-135 maintainers?
Discussion in 'Military' started by Tundra234, Apr 8, 2019.
  1. Jan 2, 2022 at 4:09 PM
    #91
    boomsling
    boomsling New Member
    ‘18 SR5 Double Cab 4x4
    Magnuson
    I’ve probably been in the desert with you at some point. 6 times in the Deid and once to al Dhafra. Never made it to Diego. Always got sent to the desert.
  2. Jan 2, 2022 at 4:32 PM
    #92
    Tundra234 [OP] New Member
    I was in QA in the Deid from Jun-Nov 2007 and worked the line from Feb-Jun 2009. I was a jet troop.
  3. Jan 2, 2022 at 5:57 PM
    #93
    Haslefre
    Haslefre New Member
    TN
    Wasn't center wing tank. It still has a spot for the water tank in the center. It's considered a ballast now.
  4. Jan 2, 2022 at 5:58 PM
    #94
    I remember now. The center wing used JP-7 for the SR's.
  5. Jan 2, 2022 at 6:00 PM
    #95
    boomsling
    Magnuson
    JP-7 was in the body tanks. Filled by the SPR in the left wheel well. Used to be Q models. I worked them as T models.
    Haslefre likes this.
  6. Jan 2, 2022 at 6:04 PM
    #96
    I'm old lol. Wasn't something different on the Q's for the center wing though for the SR-71's?
  7. Jan 2, 2022 at 6:09 PM
    #97
    boomsling
    Magnuson
    I think it was something with the manual defuel handle. Gotta ask a crew chief.
  8. Jan 2, 2022 at 6:12 PM
    #98
    Speaking of....I have a book on 135's at work that I got on Amazon. It's very detailed. Did you know that on certain 135s, the tail fin is 40 mm taller than the others? Some strange stuff in that book lol.
    boomsling[QUOTED] likes this.
  9. Jan 2, 2022 at 6:30 PM
    #99
    Mr. King
    Mr. King New Member
    Old KC-135 Crew Chief here!
    93 Bomb Wing, Castle AFB in the early 80s. 57-1440 was my favorite girl. I prepped her for the KC-135R wing reskin, turbofan and APU upgrades. As I understand it she’s still flying!
    Water injection was the tank behind the center wing tank (670 gallons). After maintenance runs using water we would send new guys on headset back to check the light in the water drain mast. They would report position and whoever was sitting in the co-pilots seat would hit the water drain switch. Yessir, we soaked a few!
    Cheers brothers and thank you for your service!
    Mr. King
    Tundra234[OP] likes this.
  10. Jan 2, 2022 at 6:42 PM
    #100
    I'll look tomorrow and see where 1440 is.
  11. Jan 2, 2022 at 6:47 PM
    #101
    Mr. King
    Mr. King New Member
    Thank you very much! That would be great to know.
    Mr. King
  12. Jan 2, 2022 at 7:17 PM
    #102
    Haslefre
    Haslefre New Member
    TN
    McConnell last I checked. Might be guard or mothballed now though.
    We had both 1440s when I was last there. But I retire this coming year... And haven't touched 135s since 13
  13. Jan 2, 2022 at 7:20 PM
    #103
    Haslefre
    Haslefre New Member
    TN
    Every single upgrade (TCTO) I did to them, every plane was different. A stringer here that isn't there, an extra panel. An old mod only got certain planes that wasn't removed, just disconnected...
    I took apart probably every single active duty 135 at some point in 10 years as an electrician.
  14. Jan 2, 2022 at 7:25 PM
    #104
    boomsling
    Magnuson
    Wiring for slipway door actuators was different on almost every RT it seemed. E/E had a hard time locating the relays on each jet.
    Haslefre[QUOTED] likes this.
  15. Jan 2, 2022 at 7:25 PM
    #105
    I hear ya there. It's still the same. 30 years with this airframe and the best TCTO to date was the tail stand in the keel beam.
    Haslefre[QUOTED] and boomsling like this.
  16. Jan 2, 2022 at 7:45 PM
    #106
    Haslefre
    Haslefre New Member
    TN
    No, it was. They gave 3 companies 2 aircraft each to modify it to an RT because all were made RTs at different times, based on what the variant it was before.
    126 was an RC, and a different aircraft before that. 124 the same. We did a TCTO/depot to make them all the same. For a while, we had to bring out the original schematics that filled our desk to troubleshoot
  17. Jan 2, 2022 at 7:49 PM
    #107
    boomsling
    Magnuson
    Worst thing to happen to a 135 is MPRS. Being a hydro troop, I really hate MPRS.
  18. Jan 2, 2022 at 7:52 PM
    #108
    Mr. King
    Mr. King New Member
    Last I knew she was at McConnell. I believe I have a picture with McConnell on the tail.
  19. Jan 2, 2022 at 7:59 PM
    #109
    Haslefre
    Haslefre New Member
    TN
    Ever change a crossover valve? That was a really crappy on the road R2...
  20. Jan 2, 2022 at 8:02 PM
    #110
    boomsling
    Magnuson
    Yep. Scary part is simulated retract with engines running. Those main doors are fast!
  21. Feb 17, 2023 at 5:05 AM
    #111
    It's at Fairchild currently.
  22. Feb 18, 2023 at 7:20 PM
    #112
    Haslefre
    Haslefre New Member
    TN
    How's the grounding going? You guys should be about 3/4th done with the inspections, right?
  23. Feb 18, 2023 at 7:50 PM
    #113
    belairbrian
    belairbrian New Member
    2016 Crew Max 4x4 TSS
    Only worked them a few times when the Comm/Nav guys were short handed. Was a B-52 Bomb/Nav Mech at Griffiss from 81-94. Left there for Edwards. Did manage to catch some rides on the 135. Quite a few in the BUFF.
    We had a jet troop that worked graveyards when I was in Job control. We had to get permission for water runs on graves. He would always run a full 120 seconds. Figured if he was up the rest of the base could be too.
    IYAMYAS
    boomsling and Roborob70 like this.
  24. Feb 19, 2023 at 3:51 AM
    #114
    There is quite a few that are down. Just under 50% of ours. Last I heard is they are talking about one time flights to depot :eek:.
  25. Feb 19, 2023 at 3:52 AM
    #115
    You know what they say...the sound of freedom!
  26. Feb 19, 2023 at 6:37 PM
    #116
    Haslefre
    Haslefre New Member
    TN
    I retired this last year, so I'm only hearing bits from friends still at McConnell. Couple of my friends just retired down at MacDill.
  27. Jun 25, 2023 at 9:38 AM
    #117
    Florida AF
    Logan
    North Florida
    Just found the mil tab on this site....
    Not a maintainer, but a long long time ago I used to put people and stuff on that airframe, and many other big body airframes. I actually just found a drive that I thought was dead and was able to recover what few photos we had from back then.
