Any good frame oiling recipes out there?
Discussion in '1st Gen Tundras (2000-2006)' started by Rdway60, Oct 17, 2020.
  1. Oct 23, 2020 at 9:40 AM
    #61
    Professional Hand Model
    Hand Protectors
    I’m trying! Got enough carbon credits for 2-3 people built up. Wurrld Peas!!!
    Hi06silver[QUOTED] likes this.
  2. Oct 24, 2020 at 12:24 PM
    #62
    cajunworm
    cajunworm New Member
    New York
    Fluid film all day!
  3. Oct 25, 2020 at 6:19 AM
    #63
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Woolwax is a bit better. Both are good
  4. Oct 27, 2020 at 5:46 AM
    #64
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    I only cleaned the axle and differential as they were visible using brake cleaner. I used just under 3 cans of Amsoil MP HD on my 2020 Crewmax.
    WFD473 and Casper3 like this.
  5. Oct 27, 2020 at 7:10 AM
    #65
    Warreng
    Warreng New Member
    Thats a good idea!
    FWIW, Krown is ok for the environment, it was developed for use on sea planes. Corn oil would definitelybe the more enviro choice though.
  6. Oct 27, 2020 at 9:02 AM
    #66
    tundra121
    tundra121 New Member
    BC8998DF-A78E-455E-A726-15BE9221FAA7.jpg Any rustproofing is better than nothing!
    There’s no excuse for letting you truck look like this.
    Tundra2 likes this.
  7. Oct 27, 2020 at 9:12 AM
    #67
    tundra121
    I finally had a chance to spray the truck with corrosion free my self ..I will never ever complaining about the $189 they charge up here again. To do a thorough job it’s takes time a fare bit of time.
  8. Oct 31, 2020 at 6:44 AM
    #68
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Started the PHM method of rust prevention the last couple days...it's not that bad if you take your time. I'm using microfiber to rub down the frame. The top side of frame where ya can't get fingers and towel, just feed a corner over and drag back and forth down as far as ya can. This obviously after the rag has a good amount of grease left on it. Don't forget safety glasses there's a lot of shit up in there, flakes and what not on mine. Where clothes you don't mind tossing.
    I made my rod from a fish stick, 4 microfiber towels and tape because I forgot a sponge. Tried to run a fish tape the whole U shape of boxed portion but I don't think it's doable. Any where I can't get my hand with that rag is getting fluid film sprayed on it. I made it from front to leaf springs in about 1.5hrs Will take more pictures when done.
    Don't forget some sort of pliers to grab that rod you will not get it out with just your hands after grease.
  9. Oct 31, 2020 at 7:07 AM
    #69
    tundra121
    great looking side kick by the way !! mine does the same.
  10. Oct 31, 2020 at 7:23 AM
    #70
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    That'll buff out.....
  11. Oct 31, 2020 at 7:37 AM
    #71
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
  12. Nov 5, 2020 at 7:00 AM
    #72
    FJ432
    FJ432 New Member
    Randy
    2006 DC SR5
    None
    A quick question from a new member and my first post. August of 2019 I bought a 2003 RCLB. Colorado being as dry as it is I've noticed a squeaking on the right side just behind the cab. I suspect it has something to do with where the bed is attached to the frame rail and this subject matter of this thread may help.
    I realize that this was brought up to help rust proof the frame but will this also possibly help my situation? If not, I may a have another common issue. Thanks for any insight.
  13. Nov 5, 2020 at 9:13 AM
    #73
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Welcome to the club FJ. Grease will always help a squeaky situation. My suggestion would be to remove the 6 bolts that hold the bed onto the frame, raise the bed up a couple inches and grease all the areas where the Bed contacts the frame. I assume you're not dealing with much of a rust issue?
    The other thing to check would be the condition of the body mounts. If they're starting to deteriorate, that will cause some squeaks as well.
  14. Nov 5, 2020 at 9:47 AM
    #74
    FJ432
    FJ432 New Member
    Randy
    2006 DC SR5
    None
    Thank you. I appreciate the advice. I love this truck and I'm going through it to make it like new. Thankfully the truck appears to have only surface rust but I may have to look at the body mounts as a possible solution. IMHO the first gen Tundras are the best.
  15. Nov 5, 2020 at 12:15 PM
    #75
    Pucks18
    It's simply a fact first gen is best!
  16. Nov 6, 2021 at 11:42 AM
    #76
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I wanted to revive this thread because it's nasty weather season and I'm thinking about it. I just saw this on the youtube and wanted to get people's input. Wondering if anyone has had any experience with this new product from B'Laster.
    A few questions for a noob that's never undercoated. What does one do with an older rig that's never been under coated? Pressure wash and wirewheel to get it reasonably clean then spray it? It's getting colder; don't bother now with the lower temps? Also, what under the rig do you want to stay away from coating? The only thing that really comes to mind would be the exhaust. Anything else?
  17. Nov 6, 2021 at 12:15 PM
    #77
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I've read before there was fluid film, there was Bar & Chain oil which people used up North (Canada) and whereabouts to coat their frames in the winter time to keep them from rusting.
  18. Nov 6, 2021 at 2:46 PM
    #78
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    I sprayed mine down with a salt away and a pressure washer and then coated the shit out of mine with fluid film. Probably wasn’t a good idea to spray exhaust and all but was easier that way lol
    BCTRD likes this.
  19. Nov 7, 2021 at 5:22 AM
    #79
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm willing to cheat on Fluid Film and try this new product but it doesn't appear to be on any shelves near me. Even online I only see an option to buy 6 cans. I only need 2-3.
    Ideally you would pressure wash off the dirt and grime first that way this can penetrate directly into the metal but spraying over that dirt won't hurt anything. Supposedly you should avoid spraying rubber with Fluid Film but I'm not usually that careful.
  20. Nov 7, 2021 at 5:51 AM
    #80
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  21. Nov 7, 2021 at 6:33 AM
    #81
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  22. Nov 7, 2021 at 6:56 AM
    #82
    w666
    Maryland
  23. Nov 7, 2021 at 7:33 AM
    #83
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    My homedepot has about 10 cand supposedly. I'm going to have to try this out. If I can be a help to any one I can pick some up and ship it.
  24. Nov 7, 2021 at 9:30 AM
    #84
    Cummins3500
    Logan
    I’ve still got a pretty good coat of fluid film from last year but some spots that need to be re-sprayed. Can I just spray over the top of what’s there or does it need to be cleaned and re-applied?
  25. Nov 7, 2021 at 10:30 AM
    #85
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Spray it right over the old layer.
    Cummins3500[QUOTED] likes this.
  26. Nov 7, 2021 at 11:48 AM
    #86
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Any of these products are going to help (except for undercoating as stated). I'm using NH oil on my Tundra and have it applied annually although there is enough built up I could probably skip this year. But I've used grease in the past and nothing lasts longer than that. If you had an old vehicle that required greasing the ball joints, the excess grease on the control arms stays there forever and if you remove it the metal is like new underneath. Spread it everywhere and it does the same thing.
  27. Nov 7, 2021 at 11:53 AM
    #87
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    What I like about the PB surface shield is that it's seems like the power washer doesn't effect it. During the winter I usually try to hit the car wash that has underbody sparys to wash as much salt off. So I believe fluid film comes off with a power washer.
  28. Nov 7, 2021 at 12:39 PM
    #88
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Interesting option.
    Does it dry or flash over on the surface?
    tundra121[QUOTED] likes this.
  29. Nov 7, 2021 at 12:44 PM
    #89
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    First time user here. It leaves a slimey residue on the surface.
    I bought the 4L jug and cheap sprayer.
  30. Nov 7, 2021 at 12:46 PM
    #90
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I am having a local shop apply fluid film this week. Takes them 3 hours. As long as you get something under there you will be good. Plenty of applications to pick from.
    BCTRD likes this.
