Any good frame oiling recipes out there?
Discussion in '1st Gen Tundras (2000-2006)' started by Rdway60, Oct 17, 2020.
  1. Oct 21, 2020 at 8:42 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Tar and feather it...
    You know a duck is never wet in the water...
    Steam clean then, then wire brush bad spots.
    Diesel fuel reaks big time. Id black body shults.
  2. Oct 21, 2020 at 12:06 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    If that’s a rubberized undercoating, I would highly recommend against using it.
  3. Oct 21, 2020 at 12:08 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    My dad always told me if I dont know enough about something then dont give opinions on it, I wish your dad did the same! Rubberized undercoating is the worst thing for your car!
  4. Oct 21, 2020 at 12:36 PM
    Professional Hand Model
    Hand Protectors
    It said MolyB Grease has excellent waterproofing qualities.
    MEWaters and tvpierce[QUOTED] like this.
  5. Oct 21, 2020 at 12:41 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    X2. I would never put that on my truck, no offense.
    Tundra2 and mech_engineer09 like this.
  6. Oct 21, 2020 at 12:44 PM
    Hand Protectors
    Azblue likes this.
  7. Oct 21, 2020 at 12:47 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    In pharmacy, we call that an off-label use.
  8. Oct 21, 2020 at 12:48 PM
    Azblue
    The Dirty T ( ^_^)_且
    :drool::drool::drool:
  9. Oct 21, 2020 at 12:51 PM
    Hand Protectors
    Lil Steve and Azblue like this.
  10. Oct 21, 2020 at 1:02 PM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    Amsoil HD Metal Protector. Inexpensive and easy to apply. It's a cosmoline wax so it holds up the entire winter. Looks good once applied also. So far, very happy with it.
    TILLY and Casper3 like this.
  11. Oct 21, 2020 at 2:08 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    What about whale oil? My uncle Quint has a boatload of the stuff....?
  12. Oct 21, 2020 at 2:10 PM
    tundra121
    tundra121 New Member
    Never seen a Duck with a rusty under carriage yet ....but surly wouldn’t recommend a rubberized product you’ll end up with a unhappy rubber ducky ...holding any salt and moisture in isn’t a good thing.
    But on the other hand corrosion free is a great option. No smell at all.
    Just delivered today....this stuff really works and ..will not affect any of the rubber or electrical components. Also doesn’t drip like crown or Rust check.
    This is the first year for us to do our own fleet.
    Will see soon how well that goes for us!!
    splitfuse and GODZILLA like this.
  13. Oct 21, 2020 at 2:51 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    I think something like this would work great
    TS-115 Corrosion Control Grease
    [10-115-101]
    16oz ctg
    Application
    TS-115 is a multi-purpose, bearing and machinery grease for use where salt water, salt air or atmospheric chemicals are present. Plants such as fertilizer, desalinization, petroleum, chemical, caustic, soda, potash plants, and sewage treatment could all use TS-115. In addition, TS-115 also may be used in underwater conditions or as an assembly lube where elastomer compatability is important.
    Benefits
    TS-115 has proven effective to protect equipment from rust and corrosion. It has a high melting point, over 500°F, outstanding mechanical stability, and excellent resistance to water washout. It may also be used as a protective coating for exposed metal to prevent rustin
    $15.46
    T. S. Moly Lubricants, Inc.
    P. O. Box 230225
    Houston, TX 77223-0225
    Tel: (713) 671-2676
    (800) 508-5545
    Fax: (713) 671-9417
    info@tsmoly.com
    splitfuse likes this.
  14. Oct 21, 2020 at 3:06 PM
    Hand Protectors
    I’m feeling the Grease Train gathering steam!
    Hi06silver and Tundra2 like this.
  15. Oct 21, 2020 at 3:33 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Jeez! What does it look like when driven down a dusty country road for miles with all the oil/grease coating/packed everywhere? Won't that cause some grit to stick and grind away at joints/movement points? I guess its better than the alternative....
  16. Oct 21, 2020 at 3:45 PM
    Hand Protectors
    Go back and see post #13 for the picture I posted. First few weeks some dirty will stick as the grease is shiney/gooey. After a month or so the grease on frame starts to turn doughy. This past year since doing it, the frame has maintained a matte finish with a doughy surface layer. Using MolyB Grease. Not sure how other greases will perform.
  17. Oct 21, 2020 at 3:49 PM
    P-Factor
    P-Factor New Member
    Another potential alternative is Gentoo™ Quart Kit (Part A and B) Hydrophobic Coating. Not specifically designed for vehicle undercarriages but works very well on other metal surfaces exposed to harsh conditions. Some what expensive but a single application has water and salt shedding properties that allow this system to be ideal for corrosion resistance according to product specifications. It would be interesting to hear from anyone who has experience or better knowledge of this product.
    https://www.youtube.com/watch?v=l7ZJez-dJmI&feature=emb_title
  18. Oct 21, 2020 at 4:03 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    I'd guess it would work but oof, the smell. Remember gear oil back in the day with whale oil additives? Stinky!
    4zyNpadJk_iMclkI-E_xmM41XhgSAh2cYnDb8mSI_2984bd29bb25c3c5caa3627dea32adc1c3928d61.png
    N84434[QUOTED] likes this.
  19. Oct 21, 2020 at 5:12 PM
    #49
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    What's the best method for clenaing one's frame prior to applying any of these cocktails? Also, I'm beginning to lean towards the AMSOIL MP HD. How many cans to do the job?
  20. Oct 21, 2020 at 7:00 PM
    #50
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I just spray mine down with a pressure washer or go to the quarter wash and use theirs.
    Tundra2 likes this.
  21. Oct 21, 2020 at 10:30 PM
    #51
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the 02 tacoma had 3m cavity wax put in the frame rails when it was new. When i use a bore scope inside the frame, 18 years later, theres no rust to speak of inside.
    now the outside? i need to address that. its getting ugly. (not rot.. just ugly)
  22. Oct 22, 2020 at 4:11 AM
    #52
    Hand Protectors
    I knew this guy that used to drive thru the fast food slosh pit out back. The French Fry Grease Residue worked wonders.
  23. Oct 22, 2020 at 5:40 AM
    #53
    Pucks18
    U really dont need to clean your frame at all unless if it has road salt residue still on it or if there is mud all over your frame imo
  24. Oct 22, 2020 at 7:16 AM
    #54
    Pucks18
    Are u crazy? Lol
  25. Oct 22, 2020 at 7:27 AM
    #55
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    That dusty road is probably covered in a salt brine to keep the dust down. Not even touching on the honey lol
  26. Oct 22, 2020 at 7:28 AM
    #56
    MEWaters
    MEWaters New Member
    Maine
    What are y’all doing for surface rust on painted surfaces. Corner of tailgate. Various small paint chips to hood and rust
    Tape and spray with rust reformer then cover with auto paint?
    Rdway60[OP] likes this.
  27. Oct 23, 2020 at 3:54 AM
    #57
    Hand Protectors
    I may be switching over to Corn Oil Latherings in the near future just for the sake of being environmentally conscious. Its safer and sexier than Fluid Film. Lasts about the same amount of time. :rofl:
    Pampered Chef makes a great spritzer.
    Warreng and MEWaters like this.
  28. Oct 23, 2020 at 4:17 AM
    #58
    MEWaters
    MEWaters New Member
    Maine
    I follow your humor. However, spraying that GMO corn onto your vehicle is probably the most toxic thing for you and the environment LOL
  29. Oct 23, 2020 at 4:39 AM
    #59
    Hand Protectors
    But it sounds so good!
    They used the Pampered Chef Spritzer on my hands before photo shoots back in the day. Where am I going with this? I need help. :rofl:
    Luckydog and Hi06silver like this.
  30. Oct 23, 2020 at 9:28 AM
    #60
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Maybe you're in over your head with still trying to turn left, getting the kids into the center and all. Can't save the planet all at once.
