Any experience with the built in 1 Touch Up & Down for window controls?
Discussion in '2.5 Gen Tundras (2014-2021)' started by brkncly, Apr 28, 2022.
  1. May 16, 2022 at 8:54 PM
    #151
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Ok all, i just installed the switch and it works great. However, I have a concern. Has anyone noticed how long the auto function stays activated. I noticed once the window is fully up or down it continues to apply power to the motor for quite awhile. Must be a built in delay to apply power to the switch when pressed into Auto mode. Is that the same as the platinum trim level switch operation? Will or Does this have any negative effect to the longevity of the drive motor, etc...?
  2. May 16, 2022 at 9:28 PM
    #152
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    Does anyone know if the 3 passenger switches are lit?
  3. May 16, 2022 at 9:33 PM
    #153
    MaxPower
    MaxPower New Member
    How many seconds is quite a while?
    The switches that had double auto from the factory have a secondary computer that controls when the motor turns off. That is why you couldn't swap in a double auto switch into the SR5 trim.
    1lowlife likes this.
  4. May 16, 2022 at 9:39 PM
    #154
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    They are lit yes
    bulldog93 likes this.
  5. May 16, 2022 at 11:06 PM
    #155
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Badderup likes this.
  6. May 17, 2022 at 5:44 AM
    #156
    jtwags
    League City, TX
    2018 Tundra CM
    I timed it this morning with the truck off. It appears the auto mode engages the power for 8.5 seconds. It takes about 4 seconds for the window to go down and 5.5 seconds for it to go up. So it is applying power for an extra 4.5 seconds down and 3 seconds going up. I may put the stock auto switch in to test how long it engages when using the stock auto down feature.
    MaxPower[QUOTED] likes this.
  7. May 17, 2022 at 6:20 AM
    #157
    AZCementTundra
    AZCementTundra Member
    AZ
    2018 TRD OR 4x4
    6112/5160, TRD (Dual Exhaust, Skid, Rear Sway), Durobumps, Rigid D-Series Pro, Talons Cat Skids, 275/70/18 KO2s
    I was going to install mine after work today - I can test the auto down before I do the swap so you don't have to swap it back and forth. Would I just be listening for the window motor to be running in excess after the window is all the way down? You got me curious now.
    jtwags[QUOTED] and showtime240 like this.
  8. May 17, 2022 at 6:38 AM
    #158
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Hopefully they can come out with one to replace the double auto switch. And maybe one for the rear window as well
  9. May 17, 2022 at 7:11 AM
    #159
    jtwags
    League City, TX
    2018 Tundra CM
    Great, that would be helpful. Yes, just listen for when the motor stops working, it is an audible click when the relay shuts it down.
  10. May 17, 2022 at 7:29 AM
    #160
    PermaFrostTRD
    Northern NY
    This would be pretty cool - not sure why it isn't standard on the Tundra. My wife's 4Runner has the auto up/down for her rear window and it's just a SR5 (premium) package/trim
    showtime240 and Sumo91[QUOTED] like this.
  11. May 17, 2022 at 7:47 AM
    #161
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    I have almost one full Mississippi from when the window stops moving down until the 'click'
    Edit: Also of note. Is it just me or are these window motors loud as hell?
  12. May 17, 2022 at 7:48 AM
    #162
    Sumo91
    TN
    Right? My gfs 4runner has auto up down for every window. And the rear window switch is located in a more convenient spot
    PermaFrostTRD[QUOTED] likes this.
  13. May 17, 2022 at 8:04 AM
    #163
    AZCementTundra
    AZ
    2018 TRD OR 4x4
    Just tried it out. It's almost immediately after the window bottoms out there is an audible click.
    sgtfluffy16 and texasrho83 like this.
  14. May 17, 2022 at 8:37 AM
    #164
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ask the seller to swap for another set.
  15. May 17, 2022 at 9:19 AM
    #165
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Doesn’t power to the motor get cut in an overload anyway? Otherwise I could hold the window button down or up manually and burn the motor out
    MaxPower likes this.
  16. May 17, 2022 at 6:04 PM
    #166
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    I also just checked mine and had the same results.
  17. May 17, 2022 at 6:08 PM
    #167
    AZCementTundra
    AZ
    2018 TRD OR 4x4
    Anyone that still has the box does it say "RAV4 13-18" on the label? Just caught my eye. Otherwise the fit and form factor look to be correct.
  18. May 17, 2022 at 6:39 PM
    #168
    MaxPower
    MaxPower New Member
    Arrived today! Should be able to install them tomorrow.
  19. May 17, 2022 at 6:45 PM
    #169
    MaxPower
    MaxPower New Member
    Same! I received two boxes from them because I decided I needed the passenger switches a couple of days later. Both boxes list the RAV4.
  20. May 17, 2022 at 6:58 PM
    #170
    Azblue
    The Dirty T ( ^_^)_且
    Dammit. I didn't need this, but at the same time, I really needed this.
    Order placed.
    shellshock and nhw544 like this.
  21. May 17, 2022 at 7:10 PM
    #171
    sgtfluffy16
    sgtfluffy16 New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    I wonder if it's actually the same as a Toyota RAV4?
  22. May 17, 2022 at 8:35 PM
    #172
    eick
    eick New Member
    So we’re buying an oem part then lol
  23. May 17, 2022 at 8:58 PM
    #173
    sgtfluffy16
    Corey
    Stock
    That is honestly what I'm wondering. If it is just a Toyota RAV4 window switch. Has anyone tried this? Buy an OE Toyota RAV4 window switch?
  24. May 17, 2022 at 9:11 PM
    #174
    APalmTree
    Brandon
    SW Washington
    My understanding is that the factory auto windows functions are handled by separate ECU's so swapping RAV4 switches in would not work. From this listing it looks like the RAV4 switches are the same form factor and maybe they just have them all listed under that model but they work on our trucks :notsure:
  25. May 17, 2022 at 9:22 PM
    #175
    sgtfluffy16
    Corey
    Stock
    Just went and looked up the RAV4 of that year range on RockAuto and it's just a driver window Auto up down switch. Not all four
    2020 dc likes this.
  26. May 18, 2022 at 7:15 AM
    #176
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    My boxes do as well. But they seem to be working just fine so far.
  27. May 18, 2022 at 1:35 PM
    #177
    AZCementTundra
    AZ
    2018 TRD OR 4x4
    I just installed - everything functions great. I did notice a solid 4 count like @jtwags did before I heard the discernable click in both the up and down auto.
    Decided to check my wife's 4runner (all windows auto as others had mentioned), the click is basically immediately after auto up/down completes.
  28. May 18, 2022 at 1:46 PM
    #178
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Just went out and checked the wife's 2017 rav4 platinum - yep the switches look identical! But also only driver window auto down. So maybe once they get here for the Tundra I'll do a quick rav4 test.
    I was mad you guys ordered after me and got them before me but they must not have had my color in stock in California so now my order will wait for next shipment to get stateside, then ship from CA. Better than waiting 5 weeks to ship direct from China I suppose.
  29. May 18, 2022 at 1:51 PM
    #179
    sgtfluffy16
    Corey
    Stock
    Please let us know your results.
  30. May 18, 2022 at 1:53 PM
    #180
    Taco-Spike
    Two Trucks
    Do the rav4 switches come in different colors?
