Any experience with Start-X remote starter?
Discussion in '2.5 Gen Tundras (2014-2021)' started by madmatt, Jul 30, 2019.
  1. Dec 1, 2021 at 1:12 PM
    #91
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Clarify? If the CL 6 cable is blue, and it's plugged into a blue port, that's incorrect.
  2. Dec 1, 2021 at 1:17 PM
    #92
    19TurdPro
    2019 Tundra TRD Pro
    Blue from Carlink goes to blue input on harness. Black output on the harness goes to the blue antenna port on the CL6
    jhardy1979 likes this.
  3. Dec 1, 2021 at 5:18 PM
    #93
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    This is how I have it after finding the correct install instructions. My issue was that I did not have the other smaller cable as well.
  4. Dec 1, 2021 at 5:25 PM
    #94
    19TurdPro
    2019 Tundra TRD Pro
    That's not how I programmed my Fortin. It was all thru the valet button. Do you have a valet button? If so, try below. If not, let me know and I will tell you how to make one.
    STEP 6. LEARN THE MYCAR TELEMATICS DEVICE TO THE EVO-ONE
    In order to communicate with the remote starter, the telematic system must be learned to the EVO-ONE.
    1 - Cycle the ignition to the ON position.
    2 - The YELLOW LED on top of the EVO-ONE should come ON.
    3 - Press & Hold the EVO-ONE programming Valet button for 5 seconds.
    4 - The RED LED on the side of the EVO-ONE will Flash rapidly.
    5 - Release the push button.
    6 - Press & Release the push button 5x times. Every time the push button is pressed the parking lights & the RED LED on the side of the EVO-ONE will blink.
    7 - Then Press & Release the Brake pedal.
    8 - At that same moment the RED LED on the side of the EVO-ONE will blink once to confirm that the Telematic device ID has been learned to the EVO-ONE.
    9 - Cycle the vehicle’s ignition to the OFF position to Exit the EVO-ONE programming.
  5. Dec 1, 2021 at 5:31 PM
    #95
    jhardy1979
    Justin
    I emailed StartX yesterday and they sent me this and its how I finally got it working last night
    The protocol in the app should be set to Fortin.
    In terms of physical installation connect using the ascl6 adapter labeled HRN-LLRS-01.
    Program it like this:
    1. Turn the key ON-OFF-ON (red led will turn on)
    2. Press and release brake 4 times (red led will flash on each brake press)
    3. The Red LED should be blinking..
    4. If the MyCar sent the learn command, the RED LED would briefly stopped blinking.
    5. If not, send the lock command from the app
    My issue the entire time was that I was missing the second adapter cable I think.
  6. Jan 9, 2022 at 12:06 PM
    #96
    Bigdan120
    Bigdan120 New Member
    2019 CM
    Just Wanted to let you know that you cannot use the RF long range system with the cell phone app Via start X
  7. Jan 9, 2022 at 12:08 PM
    #97
    19TurdPro
    2019 Tundra TRD Pro
    I think you can, but you need to flash it using the flashlink, set protocol to Fortin 2.
  8. Jan 9, 2022 at 3:27 PM
    #98
    Bigdan120
    2019 CM
    The help email from startx said no. I really have no clue... lol my al6 wouldn't program until I disconnected the RF kit.
  9. Jan 9, 2022 at 3:33 PM
    #99
    19TurdPro
    2019 Tundra TRD Pro
    I have a flashlink you can borrow if you want to try it.
  10. Jan 9, 2022 at 3:34 PM
    #100
    19TurdPro
    2019 Tundra TRD Pro
    Eh, maybe it won't work. I did more digging.
  11. Jan 9, 2022 at 3:56 PM
    #101
    Bigdan120
    2019 CM
  12. Jan 9, 2022 at 3:57 PM
    #102
    Bigdan120
    2019 CM
    Yeah I found this convo on Fortin.
  13. Nov 30, 2022 at 8:33 AM
    #103
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Reviving this thread. Looking hard at getting one of these starters but curious if anyone has any experience with whether disconnecting the battery messes the programming up? I unplug mine when it sits for extended periods (work bs) and dont want to have to rip the dash apart to access and reprogram every time..
  14. Nov 30, 2022 at 11:46 AM
    #104
    19TurdPro
    2019 Tundra TRD Pro
    The longest I did was about 12 hours without power. No issues with the Fortin EVO or the Carlink.
    FlyingWolfe likes this.
  15. Dec 31, 2023 at 4:02 PM
    #105
    Seess
    Seess New Member
    Dustin
    2019 Tundra 1794
    Just installed a Start X in my 20019 Tundra. The remote start works as advertised. However, I now have a warning that my RCTA - Rear Cross Track Alert - Failure see dealer that was not present prior to install. Did anyone else experience this issue? I have the system turned off for now. I triple checked the connections and everything appeared to be correct and emailed the manufacturer.
  16. Dec 31, 2023 at 4:08 PM
    #106
    19TurdPro
    2019 Tundra TRD Pro
    Did it go away once you turned on the ignition and stepped on the brake?
  17. Dec 31, 2023 at 4:47 PM
    #107
    Seess
    Seess New Member
    Dustin
    2019 Tundra 1794
    oops I guess I should have added that to my post. The warning is present after stepping on the brake. I have cycled the system and Truck on and off several times.
