Any engine damage from driving a few miles without any oil?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gleninaz, Sep 9, 2020.
  1. Sep 12, 2020 at 5:07 AM
    #91
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    ^^^^ DITTO
    As ALWAYS- after being happy with my Fumoto I find out there is something BETTER!
    Have to check this Stahlbus out !!
    TheBeast likes this.
  2. Sep 12, 2020 at 5:38 AM
    #92
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I'm going to say yes.
  3. Sep 12, 2020 at 5:42 AM
    #93
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I have 2 Fumoto Valves ready in waiting for install on my Tundra and Sienna, might need to consider the Stahlbus valve instead....:monocle:
  4. Sep 12, 2020 at 6:04 AM
    #94
    timsp8
    NY
    I was looking at this for my next oil change. To me the fumoto sticks down too far and I’d be worried about it getting hit by something on the road. But I’ve never seen one in person and I’m sure it’s good since so many use it.
    https://www.valvomax.com/
    betotundra and glowblue like this.
  5. Sep 12, 2020 at 6:34 AM
    #95
    Professional Hand Model
    Hand Protectors
    I’ll second that notion.
    Rex Kramer[QUOTED] likes this.
  6. Sep 12, 2020 at 10:27 AM
    #96
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Has anyone ever had an issue with the check ball in these valves getting clogged by a piece of debris? I've never used one or have done an oil change with one installed on a vehicle.
  7. Sep 12, 2020 at 10:37 AM
    #97
    timsp8
    NY
    I’ve never used one either or know anyone who has. I’ve never seen the fumoto in person, but that design worries me. I am the type of person to over tighten everything. I wouldn’t like something holding my oil with just a lever that could be hit with road debris.
    I’d guess if the check ball was clogged, you’d just take the whole thing off. It would negate the whole reason for it, but you would still be able to drain your oil.
  8. Sep 12, 2020 at 10:41 AM
    #98
    No issues with mine. Probably the best mod, makes changing the oil a breeze.
    Ruggybuggy and betotundra like this.
  9. Sep 12, 2020 at 10:46 AM
    #99
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If you have road debris that knocks the valve open you're going to have other damage as well.
    The lever is spring loaded into a catch and needs some pressure to lift out and turned 90 degrees. They also make a couple different lengths.
  10. Sep 12, 2020 at 10:58 AM
    #100
    timsp8
    NY
    That sounds better than what I was assuming from looking at pictures of it. I’m sure it’s good since so many people use them and I haven’t heard anything bad, but I worry about the little things.
  11. Sep 12, 2020 at 11:24 AM
    #101
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    I had one on my Subaru for 80k. I ran over some semi truck tread on the road which destroyed my plastic splash guard and hit my Fumoto valve. Nothing happened to the valve. It worked just as well after that as it did before. I had some black marks on it, but that was about it.
    WBW likes this.
  12. Sep 12, 2020 at 12:18 PM
    #102
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    That is a good bit of info there. Thank you!
  13. Sep 12, 2020 at 2:42 PM
    #103
    timsp8
    NY
    That’s good. Sounds like they built it tough. I guess that’s expected though from a popular company who makes something that goes under the truck and holds your engine oil.
  14. Sep 12, 2020 at 5:09 PM
    #104
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    If you are so concerned just use safety wire...problem solved.
  15. Sep 14, 2020 at 9:18 AM
    #105
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Had a fumoto on my old D-Max, 155,000 miles and not one issue !
  16. Sep 14, 2020 at 9:32 AM
    #106
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    This one didn't go too long.
  17. Sep 14, 2020 at 10:09 AM
    #107
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Whoa...Crankcase explosion! Had to be turbo(s) and nitrous involvement. Must have the slo-mo! :cheers:
  18. Sep 14, 2020 at 10:32 AM
    #108
    JohnLakeman
  19. Sep 14, 2020 at 11:02 AM
    #109
    TheBeast The Beach
    that Stahlbus valve looks good. German engineering too.
  20. Sep 14, 2020 at 11:12 AM
    #110
    BigRedFireEngine
    BigRedFireEngine New Member
    Toronto, Canada
    2016 Crewmax 1794 Edition in.... red.
    Extang Solid Fold 2.0 Trifold Tonneau, Go Rhino RB10 running boards, Kenwood DDX9905s
    If you have your oil changed by a dealership, third party mechanic, or anyone other than YOU, please please check the dipstick and ground for leaks before driving away.
    I have worked for THREE different Toyota dealers, and I would NEVER allow them to change my oil because I know they hire the youngest and most inexperienced staff to do the work. They just haven't been in the workforce long enough to care about your $55k+ brand new truck. And I'm saying this as someone who could have had his oil changed practically for free!!
    For me, changing the oil in my driveway provides some extra quality time with my sons. :thumbsup:
    berto40, bleach, G10dra and 1 other person like this.
  21. Sep 14, 2020 at 11:24 AM
    #111
    MGM2018OR
    MGM2018OR New Member
    Craig
    2018 MGM OR dbl cab ( gone but not forgotten )
    SOO TRUE! Wife and I saw a Tesla, yes a TESLA driving in the pines. This was not a road to drive a Tesla
    unless they wanted to destroy the suspension.
  22. Sep 14, 2020 at 12:05 PM
    #112
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Notice both guys end up running away.
  23. Sep 14, 2020 at 12:08 PM
    #113
    timsp8
    NY
  24. Sep 14, 2020 at 1:41 PM
    #114
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    JohnLakeman[QUOTED] and GODZILLA like this.
  25. May 17, 2025 at 6:13 AM
    #115
    2020Tunprotoy
    2020Tunprotoy New Member
    2020 Black Tundra Pro
    None
    Brought it to the dealer to get the oil changed in my Tundra Pro waited two hours and got it back with a dent on my door . They did send it to a body shop after I was not my best self. Ater days of driving a new loaner pro I got my Truck back door repaired .Is grease monkey an option?
  26. May 17, 2025 at 6:41 AM
    #116
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Yea thats the lesson here. If you have any place change your oil. You really should check for leaks and oil level before you leave.
    I mean dealerships could have a second person check the first person's work to make sure this does happen and for the high prices they charge the customer gets value and wants to buy their next car from them.. But that would cost several dollars. The dealership owners don't have but 10's of millions to spare. So it's like Walmart sometines you need to bag and scan your own groceries. Because if they always paid a employee to do it they would have a family fortune of 600 billion instead of 700 billion. We need to do our part after paying and recheck all the work/ doing the work ourselves. Alot of guys on here and myself just do our own work because of this.
  27. May 18, 2025 at 11:48 AM
    #117
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    The lever has a notch for it to lock in place and a lever clip to lock it in place if you want...don't believe opening on its own would be an issue
    BlackNBlu likes this.
