Any engine damage from driving a few miles without any oil?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gleninaz, Sep 9, 2020.
  1. Sep 9, 2020 at 6:31 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I would want to know how much oil they had to put in it. A quart or two would not be a huge concern. But if you had no oil pressure I would assume they did not put any back in it.
    I would want to pull the filter in about a thousand miles and check it for metal. You could arrange to do it at the dealership with you watching. Once you pull the filter you can cut the element with a razor knife and expand it like an accordion until it is flat. Look for metal particulate on the outside of the element. That will give you a pretty good idea of what damage may have been done.
    Alex38 likes this.
  2. Sep 9, 2020 at 6:42 PM
    Welcome from NY, by the way.
  3. Sep 9, 2020 at 6:46 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I’d just drive it for a few days and see how it goes. Your dealer told you that it was fine so just drive it and see if anything weird pops up.
  4. Sep 9, 2020 at 6:54 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I have this weird paranoia that they'll try to claim I didn't change oil often enough or something if I don't bring it to them and I ever had a warranty claim.
  5. Sep 9, 2020 at 7:09 PM
    Gleninaz
    Gleninaz [OP] New Member
    They have changed the oil since new every 5000 miles with synthetic. I just checked and it is full and when the guy pulled the dipstick it had zero oil showing. If there is a couple of quarts left when that happens then it will likely be fine. I am sure he put 5 quarts or so in it as he had two jugs plus one quart and put that in.
  6. Sep 9, 2020 at 7:12 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    If the whirring sound you described is directly related to the lack of oil. I'm sure your not gonna get out of this one without some scratches..
    This is like screwing without lube!
  7. Sep 9, 2020 at 7:15 PM
    ....ahh.... 32 valve, dual over cam motor needs lubrication...motor might not be "probably ok" at least for me. "Probably" doesn't register.....
    Alex38 and Hartsy8 like this.
  8. Sep 9, 2020 at 7:17 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    If you didnt have enough oil to build sufficient pressure your engine would sound like a bag of rotating hammers after 1 minute under load.
    betotundra, Bammer, JLS in WA and 2 others like this.
  9. Sep 9, 2020 at 7:25 PM
    or...a "slight whirring sound" which prolly isn't normal unless a Huey was flying overhead....
  10. Sep 9, 2020 at 8:44 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I get it, sir. No disrespect intended. May I suggest trying to find a reputable place that you trust other than the dealer.
    Black Wolf likes this.
  11. Sep 9, 2020 at 9:08 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Mine didn’t have a warranty anyway.
  12. Sep 10, 2020 at 2:53 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sure, once it's out of warranty, I'll either change it myself or go to an independent shop one of my friends takes all his Toyotas to.
  13. Sep 10, 2020 at 3:33 AM
    timsp8
    NY
    Sounds like your gauge is showing accurately now. Did you notice what it showed on your way back after the oil change? 4 miles isnt too far. Be optimistic. Maybe it had enough oil and will be ok. That wasn’t far enough to even warm up the engine. You could trade it in and the next guy wouldn’t even know and might drive it another couple 100k miles with no issue. How many miles are on your truck now? Are you well under your warranty mileage?
  14. Sep 10, 2020 at 4:38 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    That’s why I hate having other people do what I can do myself... my 2020 has a little over 2k on the clock, not planning on having dealer do any services...
    BTBAKER likes this.
  15. Sep 10, 2020 at 5:36 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Good idea. I’m the same way but the OP is 71 and I’m not sure I’ll have the appetite to do it myself at that age.
    WFD473 and Black Wolf like this.
  16. Sep 10, 2020 at 6:03 AM
    Justin Case
    Justin Case New Member
    TX
    Happened to me with a transmission service at dealer (not Toyota). They forgot to put oil in. Dealer admitted mistake, sent email admitting mistake, then sent same tech out to house to fill with fluid. Prob drove 60 miles with low fluid. Decided to just let it go. Had emails if trans issues developed. It did helped that the service manager was sorry and acknowledged the severity of the mistake.
    Not sure how much oil remains in our trucks after draining. Would also help out a lot to know how much they put in.
  17. Sep 10, 2020 at 6:39 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Ditto this ^^^
    I came to this conclusion after finding all the bolts loose on the skid plates of my wifes 4runner and my Tacoma a year or two ago. Her 4runner drain plug is also damaged from probably going in with an impact gun. The threads are damaged and it always goes out/in pretty tight.
    Both vehicles were routinely maintained at the dealership for the free oil change intervals and I never laid a hand on them prior to the discovery.
    Since then, I do all my own maintenance on her 4runner and my 2020 Tundra... even if its free from the dealer...
    That doesnt even factor in my time.
    I can spend 6 fucking hours at the dealership just to get the oil changed. :mad:
  18. Sep 10, 2020 at 7:36 AM
    JLS in WA
    Yikes. If I didn’t have to take my skid plate off it would markedly reduce job time. As it is, I’m looking at about 1.5-2 hours to change oil, grease u joints and rotate tires.
    Dragracer_Art[QUOTED] likes this.
  19. Sep 10, 2020 at 8:15 AM
    #49
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    Well reading what I’ve been reading in this thread here I think I’ll be changing my own oil, isn’t there some kind of adapter for the oil filter cartridge that you can buy to make that easier, some kind of drain plug? I have a 2020 with the 5.7 engine
    Thanks in advance for any information on that
    Saab95v6 likes this.
  20. Sep 10, 2020 at 8:15 AM
    #50
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    Dealer left 2 bolts off skid plate first free oil change.
    My local mechanic charges $20 to $30 to change the oil, by appointment, and i supply the oil and toyota filter (purchase jugs when on sale). They give me the jug back with a few quarts left, so i know they put in the oil in and I have documented oil changes for my extended warranty.
  21. Sep 10, 2020 at 8:46 AM
    #51
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Glen, I have sent you a pm. Please give me a call. Together we might be able to get you to a resolution.
  22. Sep 10, 2020 at 8:50 AM
    #52
    :monocle: :fingerscrossed:
    BTBAKER and WBW[QUOTED] like this.
  23. Sep 10, 2020 at 10:40 AM
    #53
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would like to know why the OP didn't see the warning displayed on the dash indicating there was no oil pressure?
  24. Sep 10, 2020 at 10:54 AM
    #54
    Saab95v6
    Saab95v6 New Member
    IMHO , there is no adapter for the filter , just the https://www.motivxtools.com/product...x2341-drain-tool-bundle/?variant=895099699225 . For the oil drain plug , you can use Fumoto or Stahlbus http://www.stahlbus.com/products/en/oil-drain-valve/
    Which I personally use on my Highlander , and will start using on the Tundra .
    Toyotoholic likes this.
  25. Sep 10, 2020 at 1:01 PM
    #55
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I run with a Fumoto now but that Stahlbus looks pretty damn cool and would appear to have a much smaller chance of opening up. Do you happen to know which one the 5.7 takes?
  26. Sep 10, 2020 at 1:21 PM
    #56
    Saab95v6
    Saab95v6 New Member
    BTBAKER[QUOTED] likes this.
  27. Sep 10, 2020 at 1:50 PM
    #57
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
  28. Sep 10, 2020 at 5:13 PM
    #58
    Rlawshe1
    Rlawshe1 New Member
    Rob
    2020 MGM
    Personally, if it was mine, I would’ve purposely driven until it didn’t drive anymore and then they would’ve put a new engine in for me. For free. LOL
    2018TundraLimited likes this.
  29. Sep 10, 2020 at 6:00 PM
    #59
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Maybe. What would you tell them why you drove 20 miles with the low oil light on?
    MT Madman and Cpl_Punishment like this.
  30. Sep 10, 2020 at 6:02 PM
    #60
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    You wouldn't need to go 20 miles if you kept in 2nd. :eek2:
    Darkness and betotundra like this.
