Any electricians out there? I need some outdoor outlet help!
Discussion in 'Home Improvement' started by Ron_Pro, Aug 23, 2020.
  1. Aug 24, 2020 at 8:43 AM
    Ron_Pro
    Ron_Pro [OP] New Member
    California
    2020 Tundra TRD Pro CrewMax
    Not sure what is causing the plug-in to give that reading. I used a volt meter and checked the terminals and got nothing back-no power.
  2. Aug 24, 2020 at 9:49 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Make sure
    Test on a known live circuit other than that problem one. Make sure your meter is set to the correct setting. You should have 120v or there about between white and black, and bare and black. Zero between white and bare. Sounds like there's a bad neutral connection somewhere. Test at wire to remove device from equation
    Ron_Pro[QUOTED][OP] likes this.
  3. Aug 24, 2020 at 3:15 PM
    Ron_Pro
    California
    Here are the readings from a volt meter. What are your thoughts?
    Hot to Neutral: 15v
    Hot to Ground: 121v
    Neutral to Ground: 112v
  4. Aug 24, 2020 at 3:50 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Sounds like it but also may have some hidden Jerry rigged shit. At this point it may be faster and safer to have an electician show up in your area. Its very hard to tell/ fully diagnose via interwebs.
  5. Aug 24, 2020 at 3:55 PM
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Neutral is floating somewhere.....
  6. Aug 24, 2020 at 4:03 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    ^^^ Yep. Time for an electrician. These can be very difficult to correct.
  7. Aug 24, 2020 at 4:21 PM
    NWPirate
    Zach
    WA
    +1 on this.
    Sounds like you have a neutral that pulled out of a wire nut.
    Pull your neutrals apart and re-wire nut them. The neutral might have a load on it so make sure to kill that circuit. Could get sparky on ya!
    Dalandshark and ARES35[QUOTED] like this.
  8. Aug 24, 2020 at 4:29 PM
    ARES35
    Mile high
    Absolutely. Kill the breaker feeding said outlet and find each on the same circuit. Once breaker that feeds is found pull devices and check that Nuet conductor on each. You'll find it with patience.
    NWPirate[QUOTED] likes this.
  9. Aug 24, 2020 at 4:44 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Definitely dropped that neutral. Plug a cheap radio into that circuit and crank it up. Grab your plug tester and plug it into other receptacles in the area and garage. Wiggle it around inside each plug and listen for the radio. You may get lucky
    Hi06silver and ARES35 like this.
  10. Aug 24, 2020 at 4:46 PM
    ARES35
    Mile high
    Dang, @JimboSlice413 that shit is old school but will work if the Nuet isnt completely disconnected. Not gonna lie, a pretty good damn way to go without pulling devices:thumbsup:
  11. Aug 24, 2020 at 4:49 PM
    JimboSlice413
    Bakersfield
    Resi guys like to run those circuits in and out of the receptacle instead of pigtailing behind it. This leaves the load on both the hot and neutral running entirely through the receptacle, its especially hard on the first device in the circuit and causes those cheapo home receptacles to heat up and fail prematurely. Its a real good place to look in homes if you've lost a circuit
    biebs96 and ARES35[QUOTED] like this.
  12. Aug 24, 2020 at 4:50 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I second the meter. Gotta identify those wires. Disconnect the wires from the outlet before testing. The outlet may be fried if it got wet.
  13. Aug 24, 2020 at 4:54 PM
    ARES35
    Mile high
    Agree 100%. I specialize in commercial but have my fair share if residential service changes and remodels. In the older homes usually they are never pigtailed..... Hot/neutral - in/out on devices. Most the time devices not working lose that Nuet, burnt out receptacles/switches etc..... I always pigtail those that are in my scope,b tell the owner other existing are more then likely wired with that same method..... Which will eventually fail in the older homes
  14. Aug 24, 2020 at 5:31 PM
    Ron_Pro
    California
    Update: Outlet works!
    I checked all of outlets close the bad one and they were all either working properly or controlled by another gfci in the kitchen. I left the plug-in tester and started to flip breakers to see which one turned it off. The outlet ended up being tied to the kitchen lights. I was afraid I was going to have to open up each recessed light and check the wiring. So I opened up the light switches first and there was a single neutral wire with a wire nut, but it wasn’t connected to anything. I found the other neutral wires and tied them all together. I flipped the breaker and prayed for the best. Haha. I tested the wires and received:
    Hot to Neutral:120v
    Hot to Ground: 120v
    Neutral to Ground: 0v
    Power!!!!
    It appears the builder messed up/rushed on the wiring at the light switch.
    Thank you so much for all of your help! I was able to fix two bad outlets with completely different issues, because of everyone’s input. I also saved a bunch of money too! More money for mods!
    :cheers:
    1lowlife, ARES35, T-Rex266 and 6 others like this.
  15. Aug 24, 2020 at 5:42 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Fucking awesome! Good work @Ron_Pro . You've been working hard and fast at this judging by time between responses lol.
  16. Aug 24, 2020 at 6:05 PM
    Ron_Pro
    California
    Lol. I was on a mission to fix these damn outlets! I was literally just about to give up and call an electrician too. Thank god for the members on this forum!
    NWPirate likes this.
  17. Aug 24, 2020 at 6:45 PM
    NWPirate
    Zach
    WA
    Hell yeah!
    $100+/hour should add up to some decent mod money :thumbsup:
  18. Aug 24, 2020 at 7:25 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Great job! You ever been nicknamed Bulldog?
    Ron_Pro[OP] likes this.
  19. Aug 24, 2020 at 7:49 PM
    #49
    biebs96
    PA
    Awesome!!
  20. Aug 24, 2020 at 8:11 PM
    #50
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Glad you figured it out.
    If it was my house, I wouldn't have been able to rest until it got figured out.:eek:
    There are a lot of good helpful people on this forum..:thumbsup:
    It's awesome that we can ask each other for help on anything, not just Tundras...:hattip:
