Any Difference in 17” and 18” Tires On Road?
Discussion in 'Wheels & Tires' started by WestexSBK, Dec 5, 2019.
  1. Dec 5, 2019 at 9:27 AM
    WestexSBK
    WestexSBK [OP] New Member
    2019 SuperWhite CM TRD Sport 4x4
    For those of you that have gone from 18” wheels to 17” wheels, did you notice a big difference in on road comfort?
    If I go to 17” methods my offset will increase and I do not want them any wider than an 18” method. But if the the ride is significantly better I can consider. Thanks
    Joe S
  2. Dec 5, 2019 at 9:54 AM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Probably depends more the the tires, I had 18" P rated tires on my truck, then 18" E rated tires currently 17" E rated tires, the P rated rode the best of the three.
  3. Dec 5, 2019 at 10:03 AM
    WestexSBK
    I’m looking at 35” Toyo RT tires
  4. Dec 5, 2019 at 11:14 AM
    TheBeast The Beach
    not much difference in sidewall between 18" and 17" for the same tire. roughly 5%.
    if you have good aftermarket rims in 18"s I say keep them. Plus a bit more space for the big brakes on the Tundra. Some of those 17's tires weight are super close to the calipers.
    I think it's worth it if you jump from 20" to 17" but if you already have 18's, not much gain imo.
    15whtrd and Pinay like this.
  5. Dec 5, 2019 at 11:15 AM
    TheBeast The Beach
    GODZILLA and Pinay like this.
  6. Dec 5, 2019 at 11:31 AM
    WestexSBK
    Awesome thanks. I agree with your logic. I am replacing my stock tss 20” wheels and suspension with icon. So I’m sure I’ll see a big improvement in ride quality regardless.
    TheBeast[QUOTED] likes this.
