Any D rated 285/75r16?
Discussion in 'Wheels & Tires' started by AWilliams, Feb 16, 2021.
  1. Feb 16, 2021 at 7:50 AM
    AWilliams
    AWilliams [OP] New Member
    Seems I'm having trouble finding much in the 285/75r16 d rated a/t tires. There really is no need for e-rated tires on such a light duty vehicle. Just makes the sidewall super stiff and your ride accordingly the same. Might just need to go down to 265/75 r16. Even C rated would be great for those that don't tow anything.
  2. Feb 16, 2021 at 8:06 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Just did a search at tirerack for that size, only E load in that size. https://www.tirerack.com/tires/Tire...6&rearWidth=255/&rearRatio=40&rearDiameter=17
    it is pretty common to have to move to E load when installing bigger tires on a Tundra. E load is what is available in larger sizes that fit Tundras. Some folks have installed 17 inch rims, more choices available in load C and D depending on the size you need.
    I totally agree with you. I installed 33inch E load on my factory 18 inch wheels, would have installed something in C load, but nothings available.
    Saltyhero13 likes this.
