Any body running 17" Methods
Discussion in 'Wheels & Tires' started by Zeb8806, Mar 8, 2018.
  1. Dec 21, 2018 at 12:59 PM
    #61
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Lol! Show him this picture
  2. Dec 21, 2018 at 2:56 PM
    #62
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Sorry about the poor lighting.
  3. Dec 24, 2018 at 6:29 AM
    #63
    brimy311
    brimy311 New Member
    Kalamazoo
    2018 Tundra Platinum
    Method grids. 0 offset.
    6DF8A3D3-6EDB-4546-B555-A6CE80A5F5B4.jpg FD8A27BF-EC02-41E4-BAED-BB9F02785D73.jpg
    nb_nielsen, Paul B, yoshi82 and 7 others like this.
  4. Dec 29, 2018 at 4:44 PM
    #64
    natethenewbie
    natethenewbie New Member
    Oakland, CA
    2015 Tundra CM 4x4
    ADD Bumper, TRD Pro Exhaust, Icon Suspension, Method 17's wrapped with BFG A/T 35's
    Method 17's and 35's.
    o2vGyGERzLOxYDnl2Fu5O58vQYMtmKissK55O9S9_6be1350f98d2db3864f0fef1e2df07c5d30cd659.jpg
    junior, Flyinryank, yoshi82 and 5 others like this.
  5. Jan 1, 2019 at 8:52 PM
    #65
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I've been trying to look for a picture of a white 3rd Gen on 17" Bronze Method Con 6s. Post up if you have something close.
  6. Jan 13, 2019 at 8:03 PM
    #66
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    What lift? With the 0 offset methods, did you just do a bmc? I'm trying to figure out if I got a 0 offset method on my stock pro with 2 shims +3shackle would they fit with just a bmc, possibly bumper shim. TIA.
  7. Jan 13, 2019 at 8:39 PM
    #67
    HappyGilmore
    Trent
    Lakewood CA
    For sure a bumper shim. I'm already grinding my front bumper. Not sure how I'm gonna get the plastic back in there neatly. No bmc and it slightly rubs. I want the mudflap back on though. Still working on that too.
    mgm16trdpro[QUOTED] and Rica25 like this.
  8. Jan 13, 2019 at 10:00 PM
    #68
    mgm16trdpro
    Northern NJ
    What's your lift setup in front? I'm the 1 who commented on your post earlier it looked good regardless of what others could possibly think regarding the cali bro lean. I'm setup with stock pro suspension with 2 shims and +3 shackle, so I might have more lift than you, especially in the front. Stock pros have 2 upfront plus the 2 shims at .5" each gives me a total of 3 upfront. I also added more rear rake like a traditional redneck lol with the +3 shackle, that's 1.75 added to rear. Curious how much lift you have upfront?
    Also, do you feel say a more positive offset than 0, say a +25 offset would help in decreasing the rub on the front bumper? TIA.
  9. Jan 14, 2019 at 5:30 AM
    #69
    HappyGilmore
    Trent
    Lakewood CA
    Appreciate it Mike.
    Now that you add up the math, yeah it sounds like you have more lift than me. I was thinking a Pro only had 1 inch stock lift. My Bilstein 5100 shock advertises 2.25 lift, but i didnt measure before and after. But if you want to have no rubbing at all, I say BMC (mudflap removed) and bumper shim with 0 offset wheel. I would have gone with a different rim if i would i have noticed that. The 18s come with offset and i guess thats what i had looked at initially.
    25mm is about an inch, so yes that would give you more clearance on the outside sweep of the tire for bumper and body mount. But it might hit the skid plate and other stuff if its offset too far in. I really would like to keep the stock plastics and mudflap, so im going to have to come up with something after i grind the bumper back all the way. The body mount rub doesnt bother me, but the mudflap goes over it, so im going to have to trim that clean somehow.
    mgm16trdpro[QUOTED] likes this.
  10. Jan 14, 2019 at 5:47 AM
    #70
    brimy311
    brimy311 New Member
    Kalamazoo
    It's a 3" BDS Suspension lift. I ended up doing the BMC as well as trimming up the front bumper. I've also added bushwacker flares to cover the tires.
    yoshi82 and mgm16trdpro[QUOTED] like this.
  11. Jan 14, 2019 at 6:13 AM
    #71
    mgm16trdpro
    Northern NJ
    Tnx for response. When u say trim front bumper, u don't happen to have a pic of cut do u? Would a .5" bumper shim have got u the clearance needed? I'm trying to decide between a +25 to 0 offset. I do have flares and think 0 would look best. I dont mind the bmc but kinda want to stay away from front bumper if can. I already trimmed front plastics to fit 295/70r18 nitto rgs on stock pro +60 w/1.25 spacer to get to +28.75 offset. It plastic trimming I did still looks stock though and u couldn't tell.
  12. Jan 14, 2019 at 8:16 AM
    #72
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Hey guys, how much are these 35x17in tires weighing in at? I just went to toyo's website and they took off the tire weight which is super lame!
  13. Jan 14, 2019 at 9:11 PM
    #73
    HappyGilmore
    Trent
    Lakewood CA
    If youre also curious about mine. Plastic is off and I trimmed a 1/4 inch off up to the plastic mount bolt. I still need to go another 1/4 I think. Then I plan on putting the plastic back and trimming it where it contacts. I will then form, roll, weld some aluminum to rivet to the plastic to cover all the holes I created.
    equin and mgm16trdpro[QUOTED] like this.
  14. Jan 14, 2019 at 10:20 PM
    #74
    mgm16trdpro
    Northern NJ
    I'm curious with the 3 inches I have upfront, if I went 0 offset with a bumper shim would I still need to cut bumper? Only other problem the 35x12.5r17 pitbull rockers run very true to size so idk?
  15. Jan 15, 2019 at 6:13 AM
    #75
    HappyGilmore
    Trent
    Lakewood CA
    I would guess no bumper trim, but be prepared to mess with the plastic, and remove/trim the mudflap.
  16. Jan 17, 2019 at 11:48 AM
    #76
    HappyGilmore
    Trent
    Lakewood CA
    Im considering getting a 1/4" coilover spacer to see if this helps my problem on the bumper. I dont really want to add a bumper spacer i dont think. That would technically put me at 2.5"-2.75" of lift.
  17. Jan 17, 2019 at 2:08 PM
    #77
    mgm16trdpro
    Northern NJ
    I meant more of a bumper shim. Coach builder sells them. You get 2 for each side and they add half inch of pushing it forward.
  18. Jan 17, 2019 at 8:42 PM
    #78
    HappyGilmore
    Trent
    Lakewood CA
    Yeah I thought about doing the bumper shim. I don't want to change the look of the front by doing that. Not sure how noticeable that is. But I'm also not sure if 1/4" of lift is gonna help me at all. As you can see above, it's hitting pretty good. I think Ill have to trim either way, so I might as well just leave my current height and trim as needed.
    Rica25 likes this.
  19. Jan 17, 2019 at 11:01 PM
    #79
    mgm16trdpro
    Northern NJ
    I doubt a 1/2" is much noticeable. Probably only makes the edge of the bumper move slightly forward in the wheel well. Instead of almost coming flush, it just moves forward ever so slightly. Someone would have to really look to notice, otherwise it would look stock.
  20. Oct 18, 2019 at 5:42 PM
    #80
    KineticExplorer
    KineticExplorer New Member
    2016 Barcelona DC TRD Offroad
    King 2.5 Coilovers w Adj Front King 2.5 Shocks W Adj Rear Camburg Kinetik Billet UCAs 17x18.5 309 Method Wheels 35x12.50 R17 BFG KO2s
    I am having trouble fitting this set up. Any help is appreciated. Currently Upfront I am running 3 inch King Coilovers with Camburg Upper Control Arms. I am at a 3 inch height in the front. I got the BMC done. I removed the front mud flaps and removed/trimmed the front fender liners. For wheels and tires I’m running 17 inch Method MR 309’s on 35x12.50r17 BFGKO2’s. With the alignment I maxed out positive caster in order to push the tire forward and prevent the tire from rubbing the body mount. but now I’m rubbing in the front when at Full Lock (Right turn) on the driver side. Anybody willing to share what they did with their alignment to fit this wheel and a 35? Or any suggestions. Also my tie rods are now rubbing the coil springs, is that normal with this set up?
    Rica25 likes this.
  21. Oct 19, 2019 at 8:50 AM
    #81
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Anyone know if you can mount these in +25? I've notice almost all you guys have 0 offset but I'd prefer 25, not sure if there's still room on the inside of the wheel for the weights to clear the calipers.
    Rica25 likes this.
  22. Oct 19, 2019 at 8:58 AM
    #82
    motoxscott
    motoxscott New Member
    Scott
    Hurricane, UT
    2017 Tundra
    Camburg - FOX - Method - General Tire - Deaver - Rigid
    @Highsierraguy On Tundra's with coilovers and upper arms we recommend running a positive offset wheel. It really helps with fitting a 35" tire and having less rubbing and clearancing needed. I run +25 (6" backspacing) Methods on my Tundra with 35" General X3's. Running a zero offset wheel pushes the wheel and tire out another 1-1.25" per side.
    - Scott @ Camburg
    khens12 and equin like this.
  23. Oct 19, 2019 at 9:35 AM
    #83
    Highsierraguy
    Nor Cal
    Thanks for the info. I'm keeping my stock UCA's and just installing billsteins at 1.9 inches. My plan was to go with a 285/70/17, so I'm not so concerned with rubbing, more so the weights being able to fit inside the rim and clear the calipers if it's not 0 offset, just not a big fan of the wheels sticking out.
  24. Oct 19, 2019 at 11:50 AM
    #84
    TheBeast The Beach
    for any reason, Method likes to release their Tundra 17's mostly in 0 offset. They have very few +25 in 17 for Tundras. Icon is your best bet for 17s. They are all +25 offset which is the sweet spot imo.
    Rica25 and equin like this.
  25. Oct 19, 2019 at 12:32 PM
    #85
    Highsierraguy
    Nor Cal
    Yea I just looked all their wheels and noticed that. Can't stand the fake beadlock nuts on all the Icon wheels, bummer.
    TheBeast[QUOTED] likes this.
  26. Oct 19, 2019 at 12:40 PM
    #86
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    They moved the wheel weights to the side to clear the caliper
  27. Oct 19, 2019 at 2:49 PM
    #87
    mcchase
    mcchase New Member
    chase
    Method 313’s are available in 25 offset. It’s what I’m running on my truck.
    TheBeast likes this.
  28. Oct 19, 2019 at 3:03 PM
    #88
    TheBeast The Beach
    i'm with you here.
    i wish the 702 from Method would come in +18 or + 25.
    blackCat1 likes this.
  29. Oct 19, 2019 at 3:06 PM
    #89
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    WOW!! im like @Zeb8806, just did a 3In toytec lift on my tundra. Looking around for info about if i should go 17 or 18. Was leaning more towars 18's but now with all the pictures im thinking about going 17 now.
    So 17X0 35X12.5 looks nice set up @Makaiofasho
  30. Oct 19, 2019 at 3:08 PM
    #90
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    Hey guys what is BMC? yeah yeah im NOOB
