Any appliance guys here?
Discussion in 'Home Improvement' started by Outbound, Mar 17, 2018.
  1. Mar 17, 2018 at 3:39 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Our fridge/freezer is making an irritating ticking or knocking sound. I've tried diagnosing myself and best idea I came up with is the compressor being buggered. No problems staying cool in either the fridge or the freezer.
    Ticking is intermittent, usually for a few minutes at a time that stops for awhile, then starts up again.
    I've narrowed it down to coming from the upper section, seemingly near the freezer cooling vent.
    Here's a vid of the sound. Any ideas?
    Unit is a General Electric model GTS18IBRURBB, serial # HM525917
  2. Mar 17, 2018 at 5:22 PM
    Ice maker?
    Sunnier and Outbound[QUOTED][OP] like this.
  3. Mar 17, 2018 at 6:01 PM
    B_brand
    B_brand New Member
    Brandon
    2017 White SR5 4WD DC
    NFab Steps, LEER Shell, BedRug
    Our’s is not that same model, but makes a similar sound sometimes. It needs to be defrosted as there is some ice build up that the fan is hitting. This might be your issue?
    Outbound[OP] likes this.
  4. Mar 17, 2018 at 6:04 PM
    Outbound
    Aaron
    Northern Alberta
    Negative. No ice maker on this model.
    I'll look into that. There doesn't appear to be much ice build up, but there could be some hidden inside the internal workings itself I suppose.
  5. Mar 17, 2018 at 6:26 PM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Check for ice build up on the circulating fan in the freezer. Typically behind a panel with a few screws holding it in.
  6. Mar 17, 2018 at 6:40 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I'd defrost it before you do anything else. I've fixed some weird problems with fridges just by defrosting it. If that doesn't work it may be your evaporator fan going out.
  7. Mar 17, 2018 at 7:02 PM
    Outbound
    Aaron
    Northern Alberta
    So I pulled off the rear interior panel. Next to no ice whatsoever. The clicking continued even thought the circulation fan wasn't spinning.
    I'm thinking something more internal is failing. I can't seem to remove the exterior rear panel in order to assess the internals from that side. Only the exposed bottom 12" and the upper interior rear panel as shown here are accessible. Clicking is definitely coming from the freezer portion.
  8. Mar 17, 2018 at 11:27 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    this was my guess
