Any and All LED Questions!
Discussion in 'Lighting' started by Headlight Revolution, Sep 4, 2019.
  1. Dec 17, 2019 at 12:32 PM
    #61
    DigbyPotter
    DigbyPotter New Member
    Denham Springs, LA
    MGM 2019 SR5 CM TSS Black 4.6L 4x2
    @Headlight Revolution what is the best LED fog light bulb to match the V.4 headlight bulb or should I do the factory LED (non-rigid) swap? Thanks!
  2. Dec 17, 2019 at 12:41 PM
    #62
    Headlight Revolution [OP] New Member Vendor
    Atlanta, GA
    Hey Homie! For the Fog Lights, check out the new Ultra 2 LEDs! The New Ultra 2 LEDs are the End-All of all LED Bulbs! Not only are they the Brightest LED bulb we have ever tested before, but the Beam Pattern & Overall Performance is unparalleled! They are truly Plug and Play, their Compact design allows for a Large variety of Fitment applications, and they are extremely dependable! One of the biggest bonuses to these bulbs is the Warranty. GTR Lighting is so confident with their products, they back the Ultra 2 LEDs up with a Full Lifetime Warranty - No Questions Asked. Even say in 10 years you have a bulb fail on you, just give us a call or shoot us an email and we'll set you up with a replacement, free of charge. Now that is confidence!
    Ultra 2 Link: https://headlightrevolution.com/2014-2020-toyota-tundra-ultra-2-led-fog-light-bulbs/
    These bulbs are right at that 6,000k Color, making them Match right up with the V.4 LEDs! :hattip:
  3. Dec 17, 2019 at 6:50 PM
    #63
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    So...what’s the beam pattern of the fogs?
    Following the above link, there’s nothing showing the fog light beam. (Video is headlights)
    I get that they’re bright, that’s the easy part.
    What I’m looking for is fog light pattern like my ‘03 Tundra had - very wide, very low and decently bright. That my ‘17 has these pieces of excrement from the factory is mind boggling. They check NONE of the boxes!
    Turn them on and you can almost hear them sucking!
  4. Dec 17, 2019 at 7:18 PM
    #64
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Hi it’s Eddie just got all your LEDS for my tundra and NSV light bar early this year love it all. Do you have anything for my 2020 Santa Fe it has projectors and fog lamps the DRL are already LED but the other lights look horrible
  5. Dec 17, 2019 at 7:33 PM
    #65
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    Your interior LEDs are amazing! I had no idea they would put out this much light!
    CAF6B398-D689-4570-82DE-B2A7298C8117.jpg AB888F2F-6730-4702-B69F-94B7C6110B17.jpg
  6. Dec 18, 2019 at 5:52 AM
    #66
    Atlanta, GA
    Sure thing! With that said, I really think you would want to look into the Morimoto XB LED Fog Light Assemblies!
    The XB LED Fog Lights offer an excellent beam pattern controlled Via an Integrated LED Projection lens built into the housings themselves, just like the headlights. The color will match up exactly, the beam pattern covers everything you need it to and does a damn good job at it too, and installation is just as great. Simply pull out the OEM housings and plug in the new ones. It really is that easy! :) Not only will these fog lights compliment the headlights on appearance, but they work hand in hand with performance as well. :) These bad boys also sport a 10-Year Warranty! Link: https://headlightrevolution.com/toyota-oval-xb-led-fog-lights/
    You can see the Performance Here: https://www.youtube.com/watch?v=cfYfwpGP9LM&t=6s
  7. Dec 18, 2019 at 5:55 AM
    #67
    Atlanta, GA
    Hey Eddie! Happy to hear from yah my man! :)
    For your Sante Fe, It takes an H7 bulb for the Low/High beams!
    Some cars like (VW's, Mercedes, BMW's, Mazda, Fiat, Saab, and Porsche) have these special bulb adapters that plug into the halogen bulb and hold the bulb into the headlight housing and then the wiring plugs into that adapter. If your car has this then, unfortunately, you will not be able to use LED bulbs, as we do not have adapters for this style H7 LED bulbs.
    If your car has one of these special adapters then you would have to go with an HID system. If you are not sure what you have or cannot tell by looking, then you can always get a picture of your bulb and pull it out and get a picture of that and send that to us and we can tell from looking at that what you have and what you will need.
    If your car uses a Retainer clip/Spring to hold the bulb in place, then we have options for you!
    If you are unsure, shoot some pictures of the OEM bulbs/Connector over to Sales@Headlightrevolution.com and we will take it from there! :) Thank You!
  8. Dec 18, 2019 at 6:06 AM
    #68
    Atlanta, GA
    This is AWESOME! Holy Lighting my man! Well if the Infamous Seat crack tries to ever eat your phone, you shouldn't have a hard time finding it! Lol :) Thank You for sharing the Picture!
    Can we use this for a Facebook/Instagram post? I want to ask permission first off!
  9. Dec 18, 2019 at 6:49 AM
    #69
    ProtoJ
    ProtoJ New Member
    Yes!
  10. Dec 18, 2019 at 6:52 AM
    #70
    Atlanta, GA
    Awesome, Thank You! If you see your Truck on our Media, that is why! :) Haha
  11. Dec 19, 2019 at 5:15 AM
    #71
    Glockmeister
    Thanks for the heads up. Those look like a very viable option. :thumbsup:
  12. Dec 19, 2019 at 5:47 AM
    #72
    Atlanta, GA
    With the Ease of Install, performance, and that warranty, it's hard to pass it up! Just another awesome option for the Tundras!
  13. Dec 23, 2019 at 3:37 PM
    #73
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    What is the brightest spot LED fog light bulb i can install in my 2016 Tundra SR5? And the part #. Thanks
  14. Dec 23, 2019 at 8:45 PM
    #74
    Atlanta, GA
    Hey man! Sure thing, I can definitely help with this upgrade! With better lighting, you want to look at Beam Patterns. This is what will develop usable light to project onto the road ahead of you. Here’s a couple options I would definitely recommend looking into!
    1. Fog Light Housing Replacement
    Morimoto XB LED Fog Lights: https://headlightrevolution.com/toyota-oval-xb-led-fog-lights
    (SKU: LF220)
    2. Bulb Replacement - OEM Housing
    GTR Lighting Ultra 2 LED Bulbs
    (SKU: B-U2-14TUN2)
    I personally love the XB housings for the Ease of install, clean aftermarket look, Projector Beam pattern, and that clean 5500k color. The 10-Year warranty ensures peace of mind for the roads ahead!
    The Ultra 2 LEDs keep that OEM look, while boasting the best LED Performance we’ve measured to date, beating out 55w HIDs in some applications! GTR Lighting is so sure of their products, the cover it with a Lifetime Warranty. Drive with Confidence!
    let me know if you have any other questions for me! Merry Christmas! :santa:
  15. Dec 24, 2019 at 4:19 AM
    #75
    Rustedfenders
    Wally
    Rosedale Md.
    Thanks much. Merry Christmas to you and your family too.
  16. Jan 20, 2020 at 4:07 PM
    #76
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    I just bought a 2019 Tundra TRD PRO last week, and immediately noticed how weak the front turn signals were. This YouTube video was one of the first I found about LED front turn signals for my truck. I'm glad to know there is no "hyperflash" with these JDM bulbs. Just now went to AMAZON and ordered a set. Thanks for the great videos that you and your son provide. I will post my results after the install.
    WrongwayUp[QUOTED] likes this.
  17. Jan 20, 2020 at 4:33 PM
    #77
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    Has the Crystal lens T10 been replaced on the site?
  18. Jan 21, 2020 at 6:10 AM
    #78
    Atlanta, GA
  19. Jan 21, 2020 at 12:49 PM
    #79
    WrongwayUp
    WrongwayUp New Member
    Andrei
    working on them.
    your welcome.... there was only one individual that said he got hyperflash on his 2014... i tried to get more info from him with no luck
  20. Jan 21, 2020 at 12:53 PM
    #80
    WrongwayUp
    Andrei
    working on them.
    are they still getting sticker for the TRD-PROs?
    okcowboy and Bad Cow[QUOTED] like this.
  21. Jan 21, 2020 at 2:15 PM
    #81
    Bad Cow
    Georgia USA
    I can't answer that question. The 2019 PRO that I just purchased was Used with 9000 miles. The owner traded it back in for a 1794. What I can tell you is that I paid $46K for this truck and it is like brand spanking new. Garage kept, never off road, completely immaculate inside and out. I had to drive 2 1/2 hours from home to buy it, and it was worth it. The window sticker on this truck says $54,991. Now I'm trying to get use to NOT getting 20-25 MPG like I was getting with my Tacoma, hahaha. But I got this truck to tow my Center Console Bay Boat. The Tacoma had a hard time with that. Towing the boat the Tacoma only got 12 MPG.
  22. Jan 21, 2020 at 8:53 PM
    #82
    WrongwayUp
    Andrei
    working on them.
    just curious...ya i payed window sticker... i plan on keeping it for the duration
    Bad Cow[QUOTED] likes this.
  23. Jan 22, 2020 at 1:58 AM
    #83
    Bad Cow
    Georgia USA
    Same here brother. At 61 years young I plan on keeping this truck til the Cows Come Home. Only wish there was a way to get better fuel economy out of this 5.7 motor. Going to take some time to get use to that.
  24. Jan 22, 2020 at 1:40 PM
    #84
    kevine0001
    kevine0001 New Member
    Kevin
    HR, i have a 2017 Tundra SR5 CM. i replaced the bulbs with LED, and it's spraying light. Are the 2017-2019 OEM LED headlights plug and play? i've seen posts saying yes and others saying additional parts needed. Alternatively, I saw your Vision X HID's on your site. The goal was as much light as it is the lower power draw with LED. Just curious how significant the LED power draw is compared to the Vision X HIDs. I only use the truck for camping and hunting, so having a lower power draw on as much of the electrical is the goal
    thanks.
  25. Jan 22, 2020 at 2:07 PM
    #85
    Atlanta, GA
    Hey Man!
    Depending if your Tundra has the Turn Signal DRL/Parking light DRL, you will need BOTH the Conversion Harness + the DRL Harness.
    If your Tundra has the OEM LED Strip (White or Amber) on the Bottom, then you will ONLY need the Conversion Harness, not the DRL harness too.
    Headlight Kit Link: https://headlightrevolution.com/2014-2018-toyota-tundra-oem-bi-led-headlight-housing-pair/
    Here is a Video where we do the Complete Installation of the OEM Bi-LED Headlights: https://www.youtube.com/watch?v=xPZbmI4QMQg
    While these Headlights are Fully Plug and Play, you may need to swap some Pins to make sure they are properly set up for your Truck! See 4:30 for this Re-Pinning Process!
    LEDs are going to be more Conservative than HID any day of the week, so from the sounds of what you are looking for, LED is the route for you! :)
    kevine0001 likes this.
  26. Jan 22, 2020 at 3:33 PM
    #86
    kevine0001
    Kevin
    mine has the DRL...thanks
  27. Jan 22, 2020 at 7:12 PM
    #87
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I have OEM Bi-LED headlights with your conversion harness. I’m thinking about switching my front turn signals to LED. I know I need resistors, my question is can I tap them into the conversion harness or do I have to tap into the OEM wires?
  28. Mar 6, 2020 at 7:47 PM
    #88
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Is there an LED headlight bulb that will fit in a set of stock 10 tundra housing and still be able to use the rubber caps ?
  29. Mar 19, 2020 at 8:34 PM
    #89
    SmoothDog89
    SmoothDog89 New Member
    Brandon
    2014 White Tundra TSS Offroad 4x4 Crewmax
    6" Fabtech Suspension Lift, KMC XD series Misfit 20x9 +0, Toyo A/T Open Country Extreme 35x12.5R20LT, K&N Performance Intake, Spray-On Bed Liner, Pace Edwards Full Metal JackRabbit Tonneau Cover.
    I have a 2014 Tundra Crewmax and recently purchased a set of LED headlight bulbs and fog light bulbs from a local source in the DFW Texas area. Needless to say I'm not impressed at all, don't get me wrong they work and are brighter than the halogens but I'm needing and wanting as bright as possible on both the headlights and fog lights. I plan on applying some luminex amber tint to the fog light lens so I need all bulbs to be as bright as possible. So before ordering some off of Amazon I figured I would ask your first. are there any recommendations that won't break the bank since I've already spent $180 on a set of headlight and fog light LED's?
  30. Mar 19, 2020 at 9:16 PM
    #90
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Safe to run two lights bars 30” and 40” on the same relay and fuse? 40amp fuse and relay..total amps for both bars combined is 35amps
