Any advice for new spare location
Discussion in 'General Tundra Discussion' started by JKlimek283, Nov 9, 2016.
  1. Nov 9, 2016 at 2:56 PM
    JKlimek283
    JKlimek283 [OP] New Member
    Jake
    2016 tundra limited
    So been looking into getting some sort of mount/rack for my full size 35" spare since it won't fit under my truck anymore with the cb shackles installed. Anyone have input on new mounting spot would be appreciated.
    Thanks Guys
  2. Nov 9, 2016 at 3:04 PM
    JKlimek283
    Jake
    2016 tundra limited
    Forgot to add I want to be able and lock it down and can't seem to find the toytec one I've seen on another thread
  3. Nov 9, 2016 at 4:33 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Some put em on a rack on the roof/lose clearance and risk collapsing the support structure.
    Some put em in the bed/takes a lot of space up and can tear up the mounting location depending on how hard you drive and washboards.(I've done that)
    Some put it on a custom rear bumper that hinges away to open the tailgate/not bad but combined weight of tire, wheel, bumper, and mount can make you need to re-spring the rear.
    You could just put it in the garage.
    NewImprovedRon likes this.
  4. Nov 9, 2016 at 4:45 PM
    JKlimek283
    Jake
    2016 tundra limited
    Yeah roof is out and not a fan of tailgate one. Was hoping for something in the bed.
  5. Nov 9, 2016 at 4:53 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Pretty much just leaves the bed. Those angled center mounts, like racers and prerunners have, use up most of the bed space. If you are going to stand it up straight either behind the cab or along one side I recommend you design and build a pretty stout custom frame to hold it
  6. Nov 9, 2016 at 4:58 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    i would try fabbing something like this. Minimal space wastage.
  7. Nov 9, 2016 at 5:05 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yeah that is kind of what I had once. After running hard about 8 months and living down a dirt road it tore off a section of bed rail. Knowing what I do now I would modify it with at least a 3' piece of angle along the top edge on both sides of the corner and run the base piece out far enough to catch the frame through the bed
    joonbug likes this.
  8. Nov 9, 2016 at 5:07 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    But I wonder if there's enough space there on a crewmax?
  9. Nov 9, 2016 at 5:08 PM
    JKlimek283
    Jake
    2016 tundra limited
    Good idea but I don't think it will fit in that location.
  10. Nov 9, 2016 at 5:18 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    How much are the shackles in the way? I think it was @bandit who did some chopping underneath to get in 37's.
    gosolo likes this.
  11. Nov 9, 2016 at 5:20 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Or keep it in the closet!
    joonbug likes this.
  12. Nov 9, 2016 at 5:21 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Or buy a compressor, air it down and shove it in there.
    zcarpenter92 and gosolo like this.
  13. Nov 9, 2016 at 5:22 PM
    JKlimek283
    Jake
    2016 tundra limited
    Shackles are about 1" thicker than stock and when I had stock shackles on, only had about 1/2" clearance on each side
  14. Nov 9, 2016 at 5:25 PM
    JKlimek283
    Jake
    2016 tundra limited
    I've been told about the compressor idea, I just don't want anything to rub even when I air it down it's Gna be right on it
  15. Nov 9, 2016 at 5:26 PM
    JKlimek283
    Jake
    2016 tundra limited
  16. Nov 9, 2016 at 5:27 PM
    JKlimek283
    Jake
    2016 tundra limited
    Found these ...Last one looks pretty cheap, middle one doesn't really have a locking spot. So I'll have to look into the first one some more
  17. Nov 9, 2016 at 5:29 PM
    jokerftn1018
    jokerftn1018 New Member
    Daniel
    Virginia Beach
    2016 mgm sr5
    i was considering the bed mount from fab and place it right in the middle
  18. Nov 9, 2016 at 5:32 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    David
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Is the tire not mounted with a cable?
    What if you were make a brace to the back of where the tire sits to move it forward. Just throwing out ideas. I havent even had a chance to look under my truck yet.
  19. Nov 9, 2016 at 5:36 PM
    JKlimek283
    Jake
    2016 tundra limited
    Thought about moving it forward a bit, Then the rear diff would possibly hit
  20. Nov 9, 2016 at 5:40 PM
    jokerftn1018
    Daniel
    Virginia Beach
    2016 mgm sr5
    i have seen some people that put the bracket you normally see flat on the bed vertical against the side of the bed towards the cab and mount some d rings that they lock up the actual tire with. people get pretty fancy with the ideas on here.
    gosolo likes this.
  21. Nov 9, 2016 at 6:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I personally would need to stand the tire up. I can't lose that much bed space. Do you need your bed space? If not you have so many more options.
  22. Nov 9, 2016 at 6:11 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep!
  23. Nov 9, 2016 at 6:12 PM
    JKlimek283
    Jake
    2016 tundra limited
    I'm still on the fence about standing it up or laying it down, I use my bed pretty frequently but not to the point where I always need all the bed space.
  24. Nov 9, 2016 at 7:15 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    That's not a bad way to do it, if it were me I'd at minimum run a locking bike chain through the wheel.
  25. Nov 9, 2016 at 7:25 PM
    JKlimek283
    Jake
    2016 tundra limited
    That's what I'm doing at the moment, chain and lock
    zcarpenter92 likes this.
  26. Nov 12, 2016 at 5:29 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    In the pasted I used NFAB rear tire mount in the bed of my truck for a full size 35" tire. It also allows you to run a lock on it for security. Here is what I used on a previous truck. Very solid but it will still take up some bed space. IMG_4895.jpg
    Here is what I did on my current truck. I installed a Thule rack system since I can install kayak racks, cargo carriers or a rack system like shown below and retain all my bed space. The Thule system is lockable, full adjustable up and down and removes in a matter of minutes. Just a thought. Here is a sample of what it would look like. IMG_4893.jpg
    Jay661 likes this.
  27. Nov 12, 2016 at 7:59 AM
    n2deep
    n2deep Pavement Princess
    I need 2 spares so had to use the bed. Put an eye bolt in the bed to run a cable lock. just to make it more difficult steal.
    Spolar and JKlimek283[OP] like this.
  28. Nov 12, 2016 at 8:06 AM
    1UPPER
    TEXAS
    Flux capacitor!
    Looks like you made it work.
    Here is another cool setup for two spare tires.
  29. May 18, 2017 at 4:44 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I ended up with an NFAB bed rail mount set up. I have been very happy with it.
    Spolar and NewImprovedRon like this.
