Any 2016ers change battery out yet?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tierhog, Mar 11, 2019.
  1. Mar 11, 2019 at 7:09 AM
    Tierhog
    Tierhog [OP] SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Like most... Im assuming the batt is a late 2014/2015 battery in a 16 truck that sat in the California heat, then I started beating it up. Have plans this summer and test it annually, but realize I'm probably pushing the limits.
    Considering a Northstar, Interstate Agm, etc
    Notachickmagnet likes this.
  2. Mar 11, 2019 at 7:49 AM
    My 07's OEM battery had the date of mfr on it. Lasted 7 +years. Johnson Control made it. Not sure about the new batteries Toyota is using.
  3. Mar 11, 2019 at 7:50 AM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    I just replaced the OEM battery in my 2011 last week, it hadn't died but was starting to turn over hard when it was cold,so rather than wait for it to crap out I decided to change it out. By my estimation that battery was 7 years old. So I wouldn't be surprised if your battery has a couple more years in it if you keep the terminals clean, and battery filled with distilled water.If it's turning your truck over good I wouldn't be in a rush to replace it. Hope this helps you out!
    Tierhog[OP] and Black Wolf like this.
  4. Mar 11, 2019 at 7:55 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I took advantage of the last North Star GB and replaced the battery in my '16. I don't want to have it fail on me when I'm in the middle of nowhere. Besides, I can use the old one in my trailer.
    Black Wolf likes this.
  5. Mar 11, 2019 at 12:48 PM
    Tierhog
    Good input.. Perhaps I should check my battery.. I thought it was sealed.
  6. Mar 11, 2019 at 12:51 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I Got about a year out of my stock battery. I'm on my second battery close to needing to go on my third for next winter. 2016 186k
    Tierhog[OP] likes this.
  7. Mar 11, 2019 at 12:51 PM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    I live in TX and had to change the batt in my 2013 by 2016. The heat does a number on them. It started turning over slow. I replaced it with a Optima and never had another problem. Waiting for the 2018 I've had just over a year to start doing it sometime this summer...
  8. Mar 11, 2019 at 1:13 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    :eek2:
    Thats crazy!...for batteries so far and # of miles on the truck.
  9. Mar 11, 2019 at 1:25 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I have a '16 and Toyota replaced my OEM battery under warranty at ~2 1/2 years. (I have no doubt that this will fail just after a group buy ends.)
    Tierhog[OP] and 831Tun like this.
  10. Mar 11, 2019 at 1:40 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Same thing on my 2016 only 18k miles replaced battery last december under waranty, on my old 2003, the battery was good for 8 years!
  11. Mar 11, 2019 at 5:40 PM
    Tierhog
    I'm seeing a trend here fellas... The northerners have battery life that's a year or two ahead of us in California, Texas, Florida, etc. People are jumping to AGM after 4yrs in hot climates..
  12. Mar 11, 2019 at 6:08 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I had a Ford battery die at 9 months. Fortunately I had boat with me so I just pulled a battery out of the boat. Unfortunately on a Sunday so replacement was on my dime. Tacoma OEM batteries both died at 3 years. Slow starting gave me warning.
  13. Mar 16, 2019 at 8:32 AM
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    I have a 2017 that a picked up brand new November of 2017. Has about 10,4xx miles on the odo right now. Just had to change the battery yesterday. Slow starting for 2 days.
  14. Mar 16, 2019 at 8:56 AM
    Dontra
    Dontra Newer
    Don
    AR
    2021 Ram Big Horn
    2021 Ram Patriot Blue, Lonestar or Bighorn, Crew cab 4x2, 5.7 bed, 5.7 Hemi etorque, Level 2, anti-spin 321 rear end, Air ride, 33 gal tank, 18 in wheels, Multifunction tailgate, Ram box, Wheel liners, MT Brown Deluxe bucket seats, 8.4 no navigation, Trailer brake controller. Front and rear rubber mats. Mopar power steps,8 yr 85K extended Mopar warranty.
    Bought 2016 on 11-2015, still going strong. Both battery and truck, no problems
  15. Mar 17, 2019 at 8:05 PM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    I just put an optima 35 in my 18.
    NewImprovedRon likes this.
  16. Mar 17, 2019 at 8:16 PM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    Still on my OEM battery. 2.5 years.
