Antifreeze leak after cam tower repair
Discussion in 'General Tundra Discussion' started by IndyTundra, Feb 27, 2018.
  1. Feb 27, 2018 at 4:56 PM
    IndyTundra
    IndyTundra [OP] Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    So, I just got my truck back on Sat from getting both cam tower seals fixed. Pulled into the driveway and since it was light out, decided to try and look for any oil leaking. Walked toward the passenger side and noticed a puddle of antifreeze on the ground. The whole right side of my truck is covered in antifreeze under the hood. Looks like it must have spit out some yesterday as well but I didn't see it because it was dark. I hope this is just from either over filling the reservoir or an air bubble in the system. Gauge never showed anything getting hot. Popped the hood and didn't notice any hoses loose and the radiator looks to be full. The rad overflow tank appears to be low now though. All the antifreeze was on the right side of the engine so I think it came out of the overflow tank. Could air in the system cause this?
  2. Feb 27, 2018 at 5:36 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Just take it back and show them pic and antifreeze underhood. It is their problem, but one you want documented.
    TheBeast and IndyTundra[OP] like this.
  3. Feb 27, 2018 at 5:47 PM
    TheBeast The Beach
    +1.
    take it back safely and have them deal with it ( and documented..)
  4. Feb 28, 2018 at 11:26 AM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Took my truck back to the dealer this morning to see if they could find my antifreeze leak after the cam tower repair. Turns out that a hose to the water pump had a "bad clamp" and a coolant crossover hose was leaking into the valley from the left head. Seems that a metal gasket was re-used that should not have been. They tell me it's totally fixed now but I will definitely be watching it. The gasket part bothers me. Hopefully that was the only thing re-used that should not have been.
    NCinCO likes this.
  5. Feb 28, 2018 at 11:40 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Inb4 tundras.com becomes a cam tower repair forum
    Damnit too late
