Antenna mold fell off
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 1Tundra5, Dec 20, 2022.
  1. Dec 20, 2022 at 6:05 AM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    The little plastic at the base of the antenna broke off at some point and wanted to see if anyone had a replacement part that they recommended I get. I noticed that the antenna also comes lose often, so if you also have a suggestion as far as a new antenna goes I’d appreciate it. I noticed the thread part isn’t straight anymore. D4C5E352-1573-4E12-820D-FA14D2C4E07A.jpg
  2. Dec 20, 2022 at 6:16 AM
    War Machine
    War Machine SSEM # 5 3MW
  3. Dec 20, 2022 at 6:18 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    This is honestly the most difficult part to remove from a tundra.
    Has got to be some kind of Christmas miracle.
    Bulldog9 and War Machine like this.
  4. Dec 20, 2022 at 6:19 AM
    Hightide
    Abalama
    Magic School Bus
    Also, a car wash will do both to mount and antenna.
    @War Machine may delete his suggestion if you’ve been doing the car wash thing.
  5. Dec 20, 2022 at 7:32 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    This happened to my 2010 CrewMax, so glad the Sequia does not have it.
    Sorry OP.
    1Tundra5[OP] likes this.
  6. Dec 20, 2022 at 2:14 PM
    1Tundra5
    Junior
    2015 White SR5
  7. Dec 20, 2022 at 2:24 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  8. Dec 20, 2022 at 4:49 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Hmmm............ I guess I need to look at mine...........
  9. Dec 21, 2022 at 1:19 AM
    War Machine
  10. Dec 21, 2022 at 4:42 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Make sure to get the genuine Toyota antenna grommet. I bought an aftermarket one on Amazon first and the material it was made of was much stiffer. It would not install correctly and I ended up punching a hole through it trying to push it into position with a screwdriver even after I applied some WD40 to make installation easier.
  11. Dec 21, 2022 at 5:02 PM
    Bulldog9
    NOVA
    Not sure what part we are talking about here. My stock (2017) antenna has a hex section on the bottom that screws onto the threaded stud that sticks up from the antenna mount on the fender. This mount seems to have a rubber boot over it. I believe it has been this way since new. All seems to work, so I am trying to understand what this issue is?
  12. Dec 22, 2022 at 4:05 AM
    BlueCrushSC16
    Charleston, SC
    OP initially asked for the rubber boot/ grommet. Then, a few posts later also asked for a suggestion for a shorty antenna
  13. Dec 22, 2022 at 4:12 AM
    War Machine
    The rubber boot tends to dry out and crack over time.
  14. Jan 5, 2023 at 7:34 AM
    1Tundra5
    Junior
    2015 White SR5
  15. Jan 5, 2023 at 8:25 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Clear enough..:confused::D
    h5bnqmc9_bcb257994d01ccd858c337bc1b4e0f0293937e8c.jpg xpabao5t_d0c7a4de7c47f33e8f057dd52f7f3cbfa76f3473.jpg
  16. Jan 10, 2023 at 5:20 PM
    Bulldog9
    NOVA
    Hmmmm... Mine looks like neither Model Year 2017
  17. Jan 10, 2023 at 5:37 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Good for you..
    It's a noted common issue.
    Probably more with vehicles parked outside 24/7 in extreme temps for a few years..
    If it hasn't happened to you I'd guess you're a lucky MF'er..
    Congrats..:thumbsup:
  18. Jan 10, 2023 at 6:40 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
  19. Apr 27, 2024 at 12:30 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Was just able to do this to mine along with some other repairs.
    Bought the boot here:
    https://www.amazon.com/dp/B09CL2MS6L?ref=ppx_yo2ov_dt_b_product_details&th=1
    It was easiest for me to undo the fender liner and come from underneath. Took longer than it should though... those plastic retaining clips are a b*tch, especially if you're trying to reuse them. Ended up just breaking them and replacing. The boot/rubber mold fits perfectly snug.
    The best way for me was to seat the boot perfectly prior to putting the antenna assembly back in place. Either yourself or a helper should push the boot down/hold the boot in place while you push the assembly in place from underneath.
    equin and bulldog93 like this.
  20. Nov 7, 2024 at 11:24 AM
    KillaahCam
    KillaahCam New Member
    Cameron
    North East Texas
    2014 MGM 1794 Crewmax 4x4
    Called my local dealer. $15. Will have it in the morning.
