Antenna Issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by bleedblue19, Sep 13, 2019.
  1. Sep 13, 2019 at 7:34 AM
    bleedblue19
    bleedblue19 [OP] New Member
    Kentucky
    2019 Super White Crewmax Platinum
    Just bought a 19 platinum, and got my color match door handles and mirror caps in. Ordered a shorty antenna but can't get the original to come loose. I pull hard with an 8 mm wrench but it won't budge. Scared to break something if i manhandle. Anyone know why? Dealer told me something about a nut on bottom side, inside fender well?
  2. Sep 13, 2019 at 7:43 AM
    18" TRD Off Road Wheels
    Some members have said that there was a little bag in the glove box that had a wrench for getting it off. Other than that, I know nothing about it.
  3. Sep 13, 2019 at 7:45 AM
    bleedblue19
    Kentucky
    I have tried that plastic tool, but no luck. When i turn it, the base and antenna move together but it never loosens up. Wondered if it was just thread lock needing to be broken loose or if i have to pull inner fender and look in there.
  4. Sep 13, 2019 at 7:50 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Mine did not have thread lock. I used the plastic wrench and it came free pretty easily. I wonder if they cross threaded yours.
    Can you use a non damaging tool to hold the base stationary and then give the antenna hell?
    You may need to chase the treads with the correct size tap when you’re done.
  5. Sep 13, 2019 at 9:17 AM
    bleedblue19
    Kentucky
    I will try my best. I was mainly trying to find out if there is something i'm missing or if i just need to bear down on it and get it out of there.
  6. Sep 13, 2019 at 9:21 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Opposite of mine. It was loose and I finally put some blue thread lock on it
  7. Sep 13, 2019 at 10:45 AM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    Just twists off.
    Force it
  8. Sep 13, 2019 at 12:00 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Don't force it too much or the stud may break because it may be a brass compound. I'd take it back to the dealer and have them work on it. That way, if they break it, it's their problem to fix it.
    NewImprovedRon and 15whtrd like this.
  9. Sep 13, 2019 at 2:26 PM
    bleedblue19
    Kentucky
    The base is moving with it, best i can describe is it acts like it's got some serious loctite on it.
  10. Sep 13, 2019 at 2:30 PM
    bleedblue19
    Kentucky
    I'm going to pop in there monday and have them look at it.. no reason it should be this tight and that's what i'm afraid of.. i'll let them deal with it. Haha
  11. Sep 13, 2019 at 2:48 PM
    15whtrd
    15whtrd Mr. Blonde
    Agreed. I don’t think it’s brass but I hear of many people breaking the stud off inside and having to either replace or use a easy out.
    OP since your truck is so new, you should make the dealer do it for you. An antenna needs to be removed if you’re going through a car wash. Tell them that’s what you want to do and it won’t come off. Then do yourself a favor and don’t go through a car wash. If all else fails, try a box end wrench.
    I had to use a wrench to remove mine but now only install it hand tight. Really freaking hand tight, but hand tight LOL
  12. Sep 16, 2019 at 8:53 AM
    bleedblue19
    Kentucky
    After some head scratching I have decided to let the dealer deal with it. No sense in me breaking something trying to remove it.. and while they are at it, I've made good friends with the service guys at my local Toyota and they are going to swap the door handles and mirror covers for color match too!
    OR18TRD and 15whtrd[QUOTED] like this.
