ANOTHER Towing Question.
Discussion in '2.5 Gen Tundras (2014-2021)' started by ATCinfantry, Apr 16, 2021.
  1. Apr 18, 2021 at 9:06 PM
    #91
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I really think you are missing my point. Over the five years I have followed this forum there are many posts about people with 5th wheels with a pin weight greater than their total payload rating alone. Yes, you found one that could fit within the Tundras specifications. My original comment was just in reference to the egregious situations I have seen posted.
    Ruggybuggy[QUOTED] likes this.
  2. Apr 18, 2021 at 9:47 PM
    #92
    I’m not sure how many times I’ve seen threads like this now...hundreds a least.
    We all argue about “the right thing to do” is, “you could be liable in an accident...”
    blah blah blah
    Always remember in accidents, not everyone makes it out alive. I’ve posted this picture before, and have kept it on my devices for remembering. This family wasn’t so lucky in this accident. This was on Monument Hill by my house on I-25N.
    Going too fast and something went south...
  3. Apr 19, 2021 at 2:32 AM
    #93
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    The difference between a 3/4 ton and a 1 ton Dodge is one additional spring per leaf pack and different bumps stops, that's it. Everything else is the same.
  4. Apr 19, 2021 at 5:01 AM
    #94
    ATCinfantry
    ATCinfantry [OP] Pot Stirrer
    Trey
    Memphis, TN
    2017 Toyota Tundra MGM SR5 TSS Off Road Package
    Running Boards. AJT YEET Chrome interior kit. Tonneau cover. More Mods Coming SOON!
    I often wonder about these 3/4 ton diesel guys that put those big ass wheels and skinny all terrain tires on them. If, I got hit for over 160lbs for, what I assume is the 20" wheels and all terrains, then how much capacity does that take off the truck?
    Its not that I'm trying to over think it, I just want to do the best thing and the right thing. I don't wanna hurt my family or anyone else. Having said that, I think a 2500 will be the best bet. I don't have to buy one immediately though. For now I'm looking at a 20' enclosed that weighs 2600 empty and that combined with my 2800lb car will be fine. Just gotta strategically load everything. When I start going on these long hauls for big races, I'll make the move to a bigger trailer with a 2500 diesel.
    2600lb trailer + 2800lb car = 5400
    10% of 5400 = 540 tongue weight.
    That'll leave me some leftover for tools, fuel, small generator, etc.
    Bammer likes this.
  5. Apr 19, 2021 at 5:53 AM
    #95
    This is where you are wrong....again.
    Differences:
    3/4 ton has coil rear suspension (5 Link), 1 ton has leaf spring rear.
    3/4 ton has standard output cummins, 1 ton has HO cummins (more options if going gas or standard transmission)
    3/4 ton has 68RFE 8 speed, 1 ton has Aisin transmission 6 speed (there are more options if you go gas or standard transmission)
    Interiors and body panels are the same though....
    ATCinfantry[OP] likes this.
  6. Apr 19, 2021 at 5:56 AM
    #96
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just curious, but do you have any accessories on your Tundra?
    I went down and had my truck weighted and subtracted it from the GVWR printed on the door jam. My allowable payload left was under 1,000lbs. Quite a bit different than the printed 1320lbs that's printed on the door. All I have on the truck for accessories is a hard tonneau cover, spray in bed liner, running boards and a LED light bar.
    You can see why most people who load their Tundra's are over weight. You can load four grown adults in my truck then add some only 200lbs is the bed and be over payload.
    ColoradoTJ likes this.
  7. Apr 19, 2021 at 5:58 AM
    #97
    Bigger tires will take away from your capacity, regardless of make/model. You can always tell who tows or who has a show truck by how they have it set up.
    Matala and Ruggybuggy like this.
  8. Apr 19, 2021 at 6:02 AM
    #98
    ATCinfantry
    Trey
    Memphis, TN
    My truck is pretty plain jane. Its a SR5 with TSS Off Road Package which is a joke because its 2WD. Its got a spray in bed liner, tonneau cover, 20" wheels, 33" BFG All Terrains, Running Boards. Thats pretty much it. I'm betting your truck is 4WD.
  9. Apr 19, 2021 at 6:04 AM
    #99
    ATCinfantry
    Trey
    Memphis, TN
    Then the question has to be asked. What do the ambulance chasing lawyers bring up when a truck is under weight but has aftermarket wheels and tires that aren't rated for towing? Ya know?
  10. Apr 19, 2021 at 6:39 AM
    #100
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    in theory, the tires that come on the tundra from toyota should be capable of exceeding weight capacities. Thats for weak P rated tires
  11. Apr 19, 2021 at 6:50 AM
    #101
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes mine is a SR5 and 4WD. You have close to the same accessories I do. The 4WD doesn't make a difference because its included in the GVWR because it came with the truck. Any accessories that you add after manufacture has to be subtracted from your GVWR. Have your truck weighted, you going to be in for a surprise.
  12. Apr 19, 2021 at 6:52 AM
    #102
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My 2wd DC weights 5680 empty. Only addition is running boards and bed mat.
  13. Apr 19, 2021 at 7:02 AM
    #103
    ATCinfantry
    Trey
    Memphis, TN
    I was under the impression that 4WD lessened the total carry capacity as it was an "option".
  14. Apr 19, 2021 at 7:07 AM
    #104
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I was thinking I wouldn't pay the extra money for a 3500 over a 2500 if I didn't need the capability but I was also thinking the price difference was larger. Looks like on a GMC it's only about $2k.
  15. Apr 19, 2021 at 7:17 AM
    #105
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The GVWR printed on your door jam should be higher than the GVWR printed on my 4WD.
    Anything that you add to the truck after manufacture has to be subtracted from the GVWR to get the true payload rating.
  16. Apr 19, 2021 at 7:25 AM
    #106
    ATCinfantry
    Trey
    Memphis, TN
    I misunderstood what you were saying. We are saying the same thing.
  17. Apr 19, 2021 at 7:30 AM
    #107
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    One thing that makes no sense. Gvwr is higher on a 4wd than a 2wd. Almost as if to compensate for the weight of the front drive gear. Historically, one would expect gvwr to be consistent being as gearing, motor, trans, axle, suspension are all 100% identical
    onesojourner likes this.
  18. Apr 19, 2021 at 7:36 AM
    #108
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Curious, what is your payload ison your 2WD.
    Here's mine
  19. Apr 19, 2021 at 7:40 AM
    #109
    timsp8
    NY
    I don’t see a gvwr in that pic.
    I’ve seen the 4wds are 7200 lb and 2wd are 7000 lbs.
    Cpl_Punishment and Hbjeff like this.
  20. Apr 19, 2021 at 7:43 AM
    #110
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Opps, meant to say payload. I'll correct it
  21. Apr 19, 2021 at 7:47 AM
    #111
    ATCinfantry
    Trey
    Memphis, TN
    Payload is 1360 not including a penalty of 163 so a total payload capacity of 1197
  22. Apr 19, 2021 at 7:49 AM
    #112
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Here's my GVWR. 3220Kg which is 7100lbs.
  23. Apr 19, 2021 at 7:51 AM
    #113
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Wow, only 40lbs difference between a 2WD and 4WD. I thought it would be higher.
    What's the 163lbs penalty?
  24. Apr 19, 2021 at 7:53 AM
    #114
    ATCinfantry
    Trey
    Memphis, TN
    My GVWR is 7000
  25. Apr 19, 2021 at 7:53 AM
    #115
    ATCinfantry
    Trey
    Memphis, TN
    I assume the 20" wheels and tires. It doesnt say.
    Hbjeff likes this.
  26. Apr 19, 2021 at 7:53 AM
    #116
    Wouldn’t that be more negligence on the owner/operator?
    AZBoatHauler likes this.
  27. Apr 19, 2021 at 8:00 AM
    #117
    ATCinfantry
    Trey
    Memphis, TN
    That's what I'm saying. So a guy goes to a dealership, buys a Ford F-250 brand new, puts the yee yee rims and tires on it, pulls a trailer, gets in a wreck where someone gets hurt. I think he would be liable because of the wheels and tires even tho he isn't over weight.
    I guess I just wonder how much these lawyers dig into this. Usually they'll just sue for the max your insurance policy and they wont pursue an individual personally unless they're very well off.
  28. Apr 19, 2021 at 8:02 AM
    #118
    AZBoatHauler
    So.Arizona
    He is at fault and liable because he crashed into someone - the wheels and tires don’t matter. Same with being overloaded. Negligence is negligence.
    Ruggybuggy likes this.
  29. Apr 19, 2021 at 8:21 AM
    #119
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Why would a 2WD have a lower GVWR than a 4WD. The trucks have to same frame and suspension minus the front driveshaft, front diff and CV axles. Makes you really wonder how they figure out the GVWR and it's accuracy.
    Hbjeff likes this.
  30. Apr 19, 2021 at 9:32 AM
    #120
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I think load definitely has something to do with it. If I were an attorney and a vehicle was overloaded, I would present the case that gross negligence occured before they even took to the road, and that regardless of who did what while driving, the overloaded vehicle could not be safely operated...
    for reference my 2wd DC with tow package has a gvwr of 6900 lbs. oddly enough I have an aux trans cooler yet a newer 2wd tundra with the only difference being a lack of a cooler has a gvwr of 7000lb. Makes no sense.
    my truck came with 18 inch alloy rims, sticker says reduce 43lbs of payload. Only option is jbl sound system.
