Another timing belt post
Discussion in '1st Gen Builds (2000-2006)' started by vercetti, Feb 22, 2024.
  1. Feb 22, 2024 at 6:25 AM
    vercetti
    vercetti [OP] New Member
    2001 Tundra 4.7
    How difficult of a job can this be for someone who has never done one before? Ive done alternators, starters, valve cover gaskets, ac compressor, axles on other cars but no timing belts. It makes me a bit nervous because of the cranking you gotta do to line things up. So far im doing;
    aisin timking kit
    that japanese name sounding radiator
    thermostat
    radiator cap
    all from rockauto
    probably gonna get a pulley puller from Amazon. also read somewhere that i need a long 12mm wrench? anyone can give input on this?
  2. Feb 22, 2024 at 6:34 AM
    I did mine never having done a timing belt before. If you have good general automotive repair knowledge and patience, then all auto repair is like baking a cake. With the proper tools and procedures, anyone can do it. Look at those monkeys down at the repair shop. Difference is you care about your truck. When you get to a problem, stop and figure out the best resolution. Use your available resources such as this forum and Youtube university. I always have a shop manual handy as well and review the procedure and tips in it. I have a Haynes manual, but the Toyota FSM is probably a better resource. I'm currently doing a GM 6.2 DOD delete and lifter repair which required me to pull the whole motor out and strip it down to the short block. I've ever done that before either. I've got 5 sources of information to have my plan and a buddy has a lifeline to a mechanic he knows when bigger questions arise. I know what to do, but also like to know why to do it. Don't half ass it, do the research, make the plan, get the right tools and take your time. Having a hard deadline ruins a lot of jobs cause you start cutting corners and ignoring obvious problems. Pilots call it "get there-itis". The need to complete the job at a certain time rushes you. My timing belt job turned out fine. I did have a radiator hose clamp leak after I finished that I had to go back and revisit, but otherwise 50k trouble free miles since then.
    G_unit3000, Jack McCarthy and JasonC. like this.
  3. Feb 22, 2024 at 1:09 PM
    Mr Badwrench
    Mr Badwrench New Member
    It's not too bad, but attention to detail goes a long way. I guess that goes for anything though.
  4. Feb 22, 2024 at 1:38 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    It’s easy. You have the knowledge. You’re just applying it to a different part of the engine.
  5. Feb 23, 2024 at 6:51 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
  6. Feb 23, 2024 at 6:58 AM
    FishNinja
    Lee
    06DC2wd
    Here are all the videos I used to help me get through mine
    https://youtu.be/__7KouGrRfg?si=KAoKdurtx_-NwYqx
    https://youtu.be/zRPhl1xcYYw?si=EYnivN1Cbg_sD0Ni
    This one is by far my favorite. He rips through the whole thing but it shows you it’s really not that much work. It’s just a lot of little things that have to ALL be done to get this job done
    https://youtu.be/BdyXF4uNRQg?si=5p8pCDkij-HUdQTk
    I will note. PUT the cam marks on the “T” when changing the belt. This is what Toyota uses to keep the cams from jumping when you pull off the timing belt. If you put the cam marks on the “ | “ the cams will most likely jump and you’ll have to individually turn the cams to get everything back to TDC
    G_unit3000 and KNABORES like this.
  7. Aug 29, 2024 at 9:49 AM
    Methodical
    Methodical New Member
    Maryland
    2006 Tundra SR5 DC TRD 4x4
    If you've done all that other work, then you should be ok. Just take photos and bag bolts.
    G_unit3000 likes this.
