Another switch pro question
Discussion in 'Electrical' started by fisherman951, Jul 10, 2021.
  1. Jul 10, 2021 at 8:50 PM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    For all those who have installed switch pros, I have a question. Most put it on top of the fuse box, my question is did you do quick disconnects inside the fuse box? Or just regular like the picture? Was wondering if something goes wrong would it be best to be able to disconnect those 3 wires in the fuse box or do you guys just plan on pulling out the add a fuse?
  2. Jul 14, 2021 at 8:02 PM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    2018 Tundra TRD-OffRaod CrewMax
    Method NV wheels 0 offset with Micky Thompson 36” tires and TRD wheel caps , fox 2.5 DSC coil overs, Camburg KINETIC UCA's, TRD front & Rear sway Bars, TRD Skid plate, Addictive Desert Stealth Fighter front Bumper, Rigid 40" curved Light Bar, 2 BAJA DESIGNS 10" AMBER driving lights, Baja Designs 40" ONX6 and S8 Amber behind the grill lights, 40" Radiance SR Pro RBGW light bar in hood Bulge, Rigid DSS pro Ditch Lights, pro Comp RGBW rock lights. Amp running boards with custom red LED lighting system, Custom TRD dual air intake with use of GTEK fab and 4" Spector intake tube and Mishimoto silicone fittings, AFE throttle body spacer, Dual Switch Pro 9100 lighting & electrical systems, Pedal commander, Warn Zeon 10K S Platinum winch, SDHQ dual battery Kit with Power steering Upgrade. TRD Pro Front Grill, with Color Matched Hood bulge, Coach Builder Shackles and coil over spacers, Coach Builder bump stops and bushings. Coach Builder tie rods, and steering bushings, IKON RST leaf springs, SDHQ traction bars, Dirty Deeds straight exhaust with Helmholtz resonator, RCV front axles, Total Chaos lower control arms, and Camburg spindles. SDHQ Arb on board twin compressor.
    I do regular like the photo. I’m actually running 2 switch pros on top just leave your lines long enough to lift the box high enough for easy access. I have no issues getting into my fuse box even with 2 switch pros on top of it.
    TampaRD Pro likes this.
  3. Jul 14, 2021 at 8:04 PM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    AJGallo41, TampaRD Pro and COTundra23 like this.
  4. Jul 14, 2021 at 8:17 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Bilstein 6112 at 2.5" w/ 1 Coach Builder Shim on each side JBA UCAs Bilstein 5160 Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Leer 100XR Decked Drawers
    This I think is the main key — leave the wires long enough and you'll be fine.
    I used fuse taps, but extended the wires and added disconnects outside of the fusebox lid so I can easily disconnect/reconnect when needed. Had to do it 2 or 3 times since for other projects and its worked out okay
  5. Aug 22, 2021 at 6:42 AM
    Legend33
    Legend33 New Member
    Middlesex Massachusetts
    SWITCHPRO AND WIFEYAIR.jpg installed SDHQ Battery Terminals, Switchpro and WifeyAir on SDOFFMT tray. Just need to clean up the wiring for a clean look.
    I ran the Red,Blue, and Pink wire into the cab. I connected Add-a fuse under dash fuse panel for those wires, so it will be easy for me to get to in the future.
    GWill likes this.
  6. Oct 7, 2021 at 1:17 AM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Hey just curious, has anyone else plugged/tapped the switch pro into a different fuse besides the ignition? I got some aftermarket headlights that are currently tapped into the ignition.
  7. Oct 7, 2021 at 3:33 AM
    Legend33
    Legend33 New Member
    I did add-afuse right under the dash, instead of the fuse box in the engine. However the cover of the fuse under dash will need to be remove and keep safe somewhere in truck or garage
  8. Oct 7, 2021 at 12:21 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    Nice, do you recall which one you put into for the one under the dash? I have a parking mode cable for mine down there so hopefully it is not the same fuse lol
  9. Oct 7, 2021 at 12:56 PM
    Legend33
    Legend33 New Member
    I don't remember. I'll will get a pics for you later today.
  10. Nov 3, 2021 at 11:26 AM
    fireman_pete
    fireman_pete New Member
    Pete
    2021 SR5 Trail Edition
    What plate is this that you used on top of the fuse block? I am looking to install a Trigger controller, plus circuit breaker and would prefer to mount to a plate instead of directly to the top of the fuse box.
    Thanks
  11. Nov 21, 2021 at 12:56 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    That's the power trays mount. I got one myself and so far cleans up all the wiring. There's another company that goes by name sdoffroadmt on IG and they make them as well.
    Occidentalis likes this.
  12. Nov 21, 2021 at 1:01 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    On another note, can anyone tell me how the programming works on the app? I'm trying to keep the whole switch pro sp9100 from turning on all my attached accessories/lights everytime I turn on the Tundra. And so far yesterday, I became the guy with a dead battery lol :anonymous:
  13. Nov 21, 2021 at 1:47 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
  14. Nov 21, 2021 at 1:51 PM
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Just put this in my truck today...
    Uhhhh.... and OhEmmBee like this.
  15. Nov 21, 2021 at 4:32 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    Well that's the thing. The LVD option is turned on and the Master Function in the settings is off.
  16. Nov 21, 2021 at 5:27 PM
    NoRcptn
    NorCal
    2017 Platinum
    Hmmm. We’ll then I’m at a loss. Although every time I’ve had a question I’ve called them and they pick up the phone and walk me through it. The customer service has been great in my experience. Maybe give them a call Monday morning and see what they say. Best of luck , I’m sure it’s something simple.
    OhEmmBee[QUOTED] likes this.
  17. Nov 21, 2021 at 9:23 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    I was just looking at this. Just purchased mine just 2 hours ago
    GREENwithENVY[QUOTED] likes this.
  18. Nov 21, 2021 at 9:24 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    Yeah I figured it was quite stumping.
  19. Nov 22, 2021 at 7:50 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    Well sir you are correct, I was just overlooking the option in the settings :anonymous:
  20. Nov 22, 2021 at 7:59 PM
    NoRcptn
    NorCal
    2017 Platinum
    That’s awesome! Glad it was simple and you have it figured out!
  21. Nov 22, 2021 at 8:00 PM
    Zachmo113
    Zachmo113 Beskar
    So Cal
    2019 MGM Limited OR 4x4
    I’ll second this. I made a couple stupid errors in wiring my system up. They stayed on the phone with me after they were closed, then called me back the next day to make sure everything was correct.
    Best customer experience I’ve ever had.
    Blowdart and OhEmmBee like this.
  22. Nov 22, 2021 at 8:07 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    Yeah just made a call and they were able to help. It wasn't the master control option in the switch configuration setting, it was the Master Control towards the bottom of the list on the app. The good news is that I got a new battery out of warranty that won't be draining pretty hard when I remote start my truck in the cold winter
  23. Nov 22, 2021 at 8:10 PM
    NoRcptn
    NorCal
    2017 Platinum
    What there’s two ? Damn. Good to know I haven’t used the app in quite a while. I’ll have to dig in to it.
  24. Nov 23, 2021 at 1:56 PM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    so when you mount it on fuzz box do you use rubber washers to help eliminate
    vibration ???
  25. Nov 23, 2021 at 2:57 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    which power tray mount works with Tundra? I checked their website and all I see is 4unner, tacoma, and FJ.
  26. Nov 23, 2021 at 6:24 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    It's in the app once after you tap on the "configure switches" The one I wasn't aware of was the one at the bottom of the app after you connect via Bluetooth.
    I wouldn't recommend it silicone epoxy be a better bet. After tightening it up that is just so it doesn't have a chance of water or humidity get in.
    This is the one I have mounted in my engine bay. Makes it look more organized as it should be and helps figuring out what wire is which if you need to move accessories around. On the PT website they also have a bundle kit. I'll send a picture of how mine is set up although I don't have much connected.
    https://www.powertrays.com/products...-powertray-05-current-tacoma-trd-off-road-pro
  27. Dec 8, 2021 at 5:38 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Are you sure that’s the right link for the one you have mounted? Says that one’s for the Tacoma. I called them today and they said that one won’t fit Tundra. Did you get it to fit behind the fuse box?
    Or did you mean to link the one that screws to the top of the fuse box? This one:
    https://www.powertrays.com/collections/powertrays/products/switch-pros-powertray-standoff
  28. Dec 8, 2021 at 5:40 PM
    Uhhhh....
    Dave
    7” BDS, 37s
    Where’d you pick that up from?
  29. Dec 8, 2021 at 8:45 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    Yeah the one I sent is the right one. Unfortunately the Tundras has a engine compartment that's more cramped and tightly packed than the Tacoma. I went with this option, drilled and mounted it on the top of the fuse box. The picture below is not my Tundra but very similar to what I have in my engine compartment. I would recommend getting epoxy too if you mount to the top of the fuse box.
    Uhhhh....[QUOTED] likes this.
  30. Dec 8, 2021 at 10:13 PM
    NIOSH
    NIOSH New Member
    2021 1794 CrewMax Army Green
    ELKA, 35", Harrop, lockers w 4.88
    Love a the pics and details you guys have done. I installed the rcr12 about 6 months ago and didn't use fuses for any of the outputs. I curious why you are adding fuses on a MOSFET design that turns off when overload.
