Another Stuck Filter Housing Thread
Discussion in '2.5 Gen Tundras (2014-2021)' started by Johnders2586, Feb 16, 2020.
  1. Feb 16, 2020 at 10:00 AM
    Johnders2586
    Johnders2586 [OP] New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Hey all,
    Went to do my first oil change today on the Tundra. I had read to stories about these caps being on tight. I prepared myself with an filter wench an new aluminum cap.. Well the dang tool broke in half trying to get the cap off... How the frig did you guys get this thing off without simply mangling it.. I left the old filter in for now an refilled it . Can't be down a vehicle dont have all day to screw with it .. I mean come on, I've been changing my own oil since I got my first car. This whole system is awful to deal with. Why!!!?????
  2. Feb 16, 2020 at 10:03 AM
    15whtrd
    15whtrd Mr. Blonde
    Who did the oil changes before you? The dealer? If so, I would take it back and tell them WTF you guys need to loosen this and put this one on for me while you’re in there. Or at least break it loose for you. Show them your tool. Luckily I never had a problem with mine. But if I did, I have a 24 inch pipe wrench or giant channel locks that I would give a go with. Back in the day, if one got stuck, you would hammer a screwdriver through it sideways, then use that as your wrench and leverage. Probably not a good idea to do with this particular housing, as you will probably damage the filter tube that you need to transfer to your new part.
    NewImprovedRon and Pinay like this.
  3. Feb 16, 2020 at 5:59 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Try the MotivX oil filter tool linked below. Use a 27mm socket on the hex with a breaker bar. Add a piece of pipe if necessary to extend the wrench handle. Got to wonder what that kind of torque does to your aluminum threads; hopefully the plastic thread fails first. When you reinstall the aluminum housing, specified torque is 18 ft-lb.
    https://www.amazon.com/dp/B00XTAGHU...+Tacoma,+Highlander,+Sienna,+Tundra,+and+More
    The MotivX tool is forged 6061-T5 aluminum. It looks identical to your APSG, but that's where the similarity ends. The Motivx is $10 more, and is #2 in Amazon oil filter tool sales. Amazon has 1790 reviews for the MotivX (4.8 stars, 89% of reviews give five star rating, 2% one star). Amazon has 23 reviews for the APSG (4.5 stars), and it has a high percentage of one star ratings (9%). One out of ten reviewers has a serious issue with the APSG tool. APSG seems to have a quality problem; one reviewer reported tool failure just like yours.
    Amazon now has forged alloy steel oil filter tools for this application if you've lost your confidence in aluminum.
    Sas likes this.
  4. Feb 16, 2020 at 6:02 PM
    Johnders2586
    Thanks for all the info I appreciate it. I was using just the 3/8 drive to turn it when it busted. Perhaps I should have used a socket an maybe it wouldnt have exploded..
  5. Feb 17, 2020 at 4:07 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I also have the MotivX oil filter tool and have not had any trouble using the internal drive on the tool. Make sure the tool slides fully on the cap and that you have the tool positioned so that you get all of the square lugs engaged.
  6. Feb 17, 2020 at 5:01 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    If you dont rub a film of new oil on the new filter before installing it, the next time will be F#%%^$ Hell.
    Ajkkane, 15whtrd and Creatures 1982 like this.
  7. Feb 17, 2020 at 5:29 AM
    JohnLakeman
    If you order the MotivX tool, you can use the 3/8" drive AFTER the current housing has been removed. Since you've already broken one (possibly faulty) tool, don't test fate: Use the 27mm hex drive to remove the existing housing.
    As @zombie said, apply a film of motor oil to the housing o-ring before installing the new filter housing. Be sure you install the housing o-ring properly in the filter housing groove. If you buy the Toyota oil filter, there are pictorial directions showing how to install the o-ring right on the side of the box.
  8. Feb 17, 2020 at 6:33 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Could you explain this a little more, please? Do you mean a little oil on the black rings, or do you mean the actual filter? If you mean the filter itself, how? I will be doing my first oil change since the free dealerships ended this coming weekend.
  9. Feb 17, 2020 at 6:45 AM
    tstieb
    tstieb New Member
    2014 CM TRD
    Had this issue recently and man it sucks. I asked for help here and someone suggested placing a piece of paper between your filter wrench and the housing. I tried it and it worked! So order the MotivX wrench and fold a piece of paper and place it on the housing then tap the wench on. This saved me when even a breaker bar wouldn't budge it before.
  10. Feb 17, 2020 at 6:48 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    :eek: Whoever put it back on needs to adjust their elbow torque wrench. Wow.
    +1 for the Motivx & get the drain tool as well while you're at it for cleaner oil changes.
    https://www.amazon.com/gp/product/B078RJ2L25/
    JohnLakeman likes this.
  11. Feb 17, 2020 at 8:17 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    The Rubber O-ring. :facepalm:
    Ronin73[QUOTED] likes this.
  12. Feb 17, 2020 at 9:09 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Somebody gots some muscles! :muscleflexing: LOL
    Having never seen this before, I guess the ratchet or extension inserted put forces on it to create the failure. A socket on the outside flats may have prevented that failure. That wrench looks like cast material, prolly not the best material for tools.
    Mine is more of a plate steel material, probably stamped from a press. I am thinking a whole lot less likely to split like that.
  13. Feb 17, 2020 at 9:21 AM
    JohnLakeman
    Like I tell my wife...It's not paranoia if they're actually out to get you. :D
    NewImprovedRon and Trooper2 like this.
  14. Feb 17, 2020 at 9:34 AM
    JohnLakeman
    The 3/8" drive corners are "notch" stress risers. Notice the tiny circular recesses at the corners; those are intended to spread the corner stress concentration to a larger area. The circular cutouts work to reduce the stress concentration, but there still has to be enough material to handle the stress where the drive corner is closest to the hex surface. MotivX designed the tool using the material properties of forged 6061-T5. APSG copied the design but...
    What I suspect as well. Grain structure looks very coarse to be a forged part.
    TheBeast and Trooper2[QUOTED] like this.
