Another squeaky tundra.
Discussion in 'Suspension' started by BarcelonaSX, Feb 18, 2020.
  1. Feb 18, 2020 at 2:57 AM
    BarcelonaSX
    BarcelonaSX [OP] New Member
    2019 Barcelona red SR5 SX
    Bilstein 6112 front coilovers @2.5”. Bilstein 5100 rear shocks with toytec shackles @1”. 20x9. Xd grenade wheels with 295/60/20 ridge grapplers. Tinted windows. Gibson single side dual exhaust.
    I. I’ve looked at most of your threads on the subject. 6000 miles ago I lifted the rear with shackles. 1.5”. Toytecs. Everything was great. Drive it for 4000+ miles like that. Then I decided to drop it to 1”. I wanted to take more rake out of it. Looks great. It just squeaks like hell. And it’s not every bump. It comes on and stays on. Then stops for a while. Stays more consistent on the highway. So. I’ve already trimmed the bed bolts. So that’s not it. I’ve siliconed the leafs. I’ve loosened the shackles. Tightened the shackles. Any ideas,?? I kept the factory bushings because they only had 3000 miles on them. Also they didn’t make a noise when I had them at 1.5”. I’m ready to order new bushings but Incase I missed something. I’m open to suggestions. Thanks.
  2. Feb 18, 2020 at 5:19 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I would bet it will be lower ball joints.
  3. Feb 18, 2020 at 5:42 AM
    BarcelonaSX
    Truck has 9000 miles on it. 6 months old. I’ll drive it through the window at the dealership if it’s the ball joints. Plus it’s in the rear.
    15whtrd likes this.
  4. Feb 18, 2020 at 6:29 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Gotcha. Didn't realize it was the rear. Did you check the spare tire?
  5. Feb 18, 2020 at 6:31 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The shackles are rubbing on a bed bolt. This is a common issue at 1” height setting. Mine did it do. Hit the edge of the bolt with a dremel and not a peep since.
    joonbug and 15whtrd like this.
  6. Feb 18, 2020 at 6:34 AM
    15whtrd
    15whtrd Mr. Blonde
    You should upgrade those leafspring bushings. The stock bushings are shit. They have splines that grab the shackle and prevent it from articulating.
    PeakIT, Tundra234 and BarcelonaSX[OP] like this.
  7. Feb 18, 2020 at 6:56 AM
    BarcelonaSX
    Yes I’ve had the tire out. Still did it. I’m guessing it’s gota be the rubber bushings.
  8. Feb 18, 2020 at 7:34 AM
    Danman34
    Danman34 New Member
    Danny
    It’s not the bushings. It’s the shackle rubbing on a bed bolt. I promise you.
  9. Feb 18, 2020 at 7:34 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    x2 what @Danman34 said - at 1" the TT shackles will rub on the bed bolts. I had my TT shackles set at 1" and this is where it rubbed:
    joonbug, BarcelonaSX[OP] and Danman34 like this.
  10. Feb 18, 2020 at 7:51 AM
    BarcelonaSX
    Like I was saying. I already trimmed the bed bolt.
  11. Feb 18, 2020 at 7:58 AM
    BarcelonaSX
    I already cut the bolts down. Still makin noise.
    sr5shark[QUOTED] likes this.
  12. Feb 18, 2020 at 8:39 AM
    Danman34
    Danman34 New Member
    Danny
    How much did you trim them? Mine didn’t start making noise till about 3 weeks after install. I guess bushings settled or compressed to their final resting spot with load and the shackles started hitting. Maybe you didn’t trim enough.
    I did replace the oem bushings with poly though. But the noise was only attributed to the bed bolt hitting.
    glowblue and sr5shark like this.
  13. May 24, 2020 at 5:56 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    @Danman34 did you have to take the shackle off to trim the bed bolts? I looked at mine and at a minimum I’d need to remove the spare tire to get room.
  14. May 24, 2020 at 6:11 AM
    My truck was squeaking like crazy. It stopped when I removed the spare to put my shackles in. The tire now lives in the bed...lol.
  15. May 25, 2020 at 6:33 PM
    Danman34
    Danman34 New Member
    Danny
    No. Didn’t need to take shackles off. Just removed spare tire so I could get under there comfortably.
