Another offset question....
Discussion in 'Wheels & Tires' started by cfred70, Jan 14, 2019.
  1. Jan 14, 2019 at 11:37 AM
    cfred70
    cfred70 [OP] New Member
    Craig
    Ohio
    2018 Tundra SR5 Crewmax
    Extang Solid Fold 2.0, 20% Tint, Black Emblem Overlays
    No lift, no level, stock SR5 suspension....would +18 offset work, running the trd wheels now that look to be +60....trying to push tires out closer to flush without having to do any cutting/mods.
  2. Jan 14, 2019 at 1:18 PM
    15whtrd
    15whtrd Mr. Blonde
    That would move the rim out about 1.65 inches. At a minimum you may have to remove the front forward mudflap. Maybe have to push in the fender liner a little bit with a heat gun or a screw. Not sure if it will rub the skid plate, but if it does you can either bend it or cut it.
  3. Jan 14, 2019 at 1:20 PM
    15whtrd
    15whtrd Mr. Blonde
    A guy at work has a 2016 crew max. It looks like it has TSS wheels which stick out a little more than factory. He has BF goodrich all terrain in the stock size. 275/65/18. They rub when he puts the truck in reverse and turns the wheel.
  4. Jan 15, 2019 at 4:41 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Are you staying with stock size tires? FYI, +18mm offset is going to put your further out than "flush". They are going to stick out pretty good without flares. I think @chphilo had some old pics as he was running that similar setup before.
    FWIW, my truck has +25mm offset with 275/70/18. My wheels are also 18x8.5 where most of the aftermarket wheels are 18x9. I had to remove the front, rear mud flaps.
