Another Effing Timing/Water pump ThReAd
Discussion in '1st Gen Tundras (2000-2006)' started by Smily, Feb 11, 2020.
  1. Feb 11, 2020 at 6:55 PM
    Smily
    Smily [OP] New Member
    2004 tundra v6 pain in arse suicide door
    Someone put a crappy stereo in it
    So here we are. Waiting for tax returns, making a list. Have 105k last belt was Conti cause the sticker on the pulley housing says 56k done.
    So I have skills. Wrenched for a paycheck as small engine tool mechanic.
    Haven't come across a straight up v6 gen1 timing/h2o pump thread.
    Anyone that has done this have a time estimate. Just asking cause looks like a pain in the ass cause of plenum removal.
    Might be over overthinking the whole thing but alas that's where y'all chime in..
    Thx
    mcharfauros likes this.
  2. Feb 11, 2020 at 6:58 PM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    Check 4runner threads maybe, 3.4? Or look up Timothy tho tool man videos
  3. Feb 12, 2020 at 12:45 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    3.4 timing belt on the tundra is the same as the tacos. just more room. look up the timmy videos on youtube and you'll be set. Its an easy t-belt to do. best part is, if you mess up timing it, you wont hurt anything! the 3.4 is non interference. but its hard to mess up.
  4. Feb 12, 2020 at 3:19 AM
    foxtrapper
    foxtrapper New Member
    2003 SR5
    This is a pretty good walk through:
    http://www.4x4wire.com/toyota/maintenance/timing_belt/
    There are also numerous youtube videos if you like those.
    It's more fiddly than the V8. Give yourself a whole weekend, so you're not frantic. Give yourself room, so do things like remove the radiator. Technically you don't have to, but the job is a whole lot harder without the room.
    The crankshaft mark is surprisingly hard to see and get aligned. The camshaft sprockets are quite visible, but you'll find things don't quite line up perfectly. I'd strongly suggest using a sharpie and or paint pen on the sprockets and belt, to make it easier. Mark your old belt and sprockets before your take it off. Put the same match marks on your new belt. Install the new belt lining up those marks.
    Starter motor, breaker bar, frame rail will take the crankshaft bolt off quite easily. Breaker bar and hammer will get the bolt back in and vaguely tight enough.
  5. Feb 12, 2020 at 4:41 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Yes, I'm not the only one. Just put alot of Red locktight on the bolt when installing. You could always just buy my V8, timing belt just done, comes with trans.
    Black Wolf likes this.
  6. Feb 12, 2020 at 4:51 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Pay a competent mechanic to do it right...money well spent.
  7. Feb 12, 2020 at 8:08 PM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    I thought the V6 was a chain... and the issue was head gaskets... V8 was timing belt and W/P...???
  8. Feb 12, 2020 at 9:11 PM
    empty_lord
    05 rollover special
    05-06 is a chain 4/0l
    earlier is a 3.4 with timing belt
  9. Feb 12, 2020 at 9:22 PM
    delz05
    BOSTON
    2005 Tundra Limited
    Work in progress...
    I thought so... The OP has an 04 notation in his signature...
    empty_lord[QUOTED] likes this.
  10. Feb 17, 2020 at 3:43 PM
    Smily
    Thanks for your input. I plan on doing it myself, done if a couple times in 18yrs with the Porsche I had. I'm just irritated that the plenum has to come off to start. I'm budgeting a Thursday and Friday to get it done with the weekend as a safety net lol. I was trying for a chain but the trucks were hard to come across.
