Annoying Sound
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Honz, May 7, 2021.
  1. Oct 17, 2021 at 11:25 AM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    For those of you that have put these rubber washers in, where did you place the 2 rear-most washers? Top side of skid under the aluminum sleeve or top side of skid on the top side of the frame with the nut?
    edit: nevermind. Just read a few posts above. Sorry guys I’m slow sometimes :D
    jewsNbrews and AZBoatHauler like this.
  2. Oct 17, 2021 at 12:03 PM
    AZBoatHauler
    So.Arizona
    I went sandwiched between the top of the skid and the bottom of the crossmember.
    Bob_Wiley and boostedtrdpro like this.
  3. Oct 17, 2021 at 12:11 PM
    boostedtrdpro
    Jeremy
    Thanks man, done deal. Figured while I had it off doing suspension I’d just do it. Mine wasn’t popping, but you know sure as I put it back on it would start. Funny, those tapered washers on top of the cross member I didn’t know they were there and they fell off in the middle of my road doing a test drive. I ran them over and heard em ting off the road, I was like, I should grab those. Totally didn’t know what they were or where they went until visiting this thread. So thanks for the pics @Honz !
  4. Oct 18, 2021 at 1:26 PM
    TL TRDPro LR
    TL TRDPro LR New Member
    Troy
    SoCal/Idaho
    2021 TRD Pro Lunar Rock CM
    Took my ‘21 into the dealership on a Saturday after having the creek occur around 1k miles. Apparently Toyota Service Dept is now finally aware of the service bulletin that has been issued and as long as the Parts Dept has the part in stock (part number/description listed below) they will easily fix… No charge as covered under warranty and I want to say they billed .25hrs labor (which I think is the min) but I never saw the cost of the rear fasteners so I’m unable to tell you for sure the cost of those if you just wanted to pick up from parts and skip the 3hrs shopping at Costco while they repair. Appears this doesn’t happen to everyone at the same time, or at all in some cases - hope this helps as my truck no longer sounds like it’s been ridden hard!!
    jewsNbrews and boostedtrdpro like this.
  5. Oct 18, 2021 at 1:32 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I think you can only get them as part of the hardware kid listing in the diagram, and it's around $80...
  6. Oct 18, 2021 at 1:32 PM
    boostedtrdpro
    Jeremy
    Dammit! I put the spacers on upside down! For some reason I figured the cutout cup went face up towards the nut. Thanks for this though...haha
  7. Oct 18, 2021 at 1:40 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I just used some thick weather stripping foam that I had laying around and it worked like a charm and hasnt returned in 6+ months.
    drewpweinerMD likes this.
  8. Oct 18, 2021 at 1:46 PM
    white_pro21
    white_pro21 New Member
    2021 super white TRD PRO
    Does anyone know whether the new hardware is different from original?
    Please update us if the sound comes back and I hope not.
  9. Oct 18, 2021 at 10:18 PM
    TRDSnowInTX
    TRDSnowInTX New Member
    Ryan
    2021 Super White Tundra TRD Pro
  10. Sep 27, 2022 at 1:25 PM
    LR_PRO_PHD
    LR_PRO_PHD New Member
    Phil
    Long Island
    Soon to be ‘21 LUNAR ROCK PRO CREWMAX
    SnowimInTX,
    where exactly did you apply the tape?
    does it still eliminate the creaking sounds?
    thx
  11. Sep 27, 2022 at 1:33 PM
    TRDSnowInTX
    Ryan
    Just put a strip between the plate and the cross member of the frame. Hasn’t made a noise since.
  12. Jan 19, 2023 at 9:13 PM
    COTundra23
    COTundra23 New Member
    Is the orientation of those black square spacers important? Was reinstalling mine tonight and give the awkward angle I am not 100% they are in the right place
  13. Jan 19, 2023 at 9:14 PM
    COTundra23
    what is the purpose of the silver tubes over the bolts?
  14. Jan 24, 2023 at 4:15 PM
    TL TRDPro LR
    Troy
    SoCal/Idaho
    Not too sure. Mine starting making a small amount of creaking again recently but I need to take it in for an oil change next week so I will have them tighten or replace (if needed)
    COTundra23[QUOTED] likes this.
  15. Jan 24, 2023 at 4:18 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yes - the service manual shows the correct way. I’m pretty sure it’s with the fat apart to the middle of the crossmember with the countersink down.
    Those support the top spacers so that you don’t crush them when torquing down the nuts and bolts.
  16. Jan 25, 2023 at 4:12 AM
    COTundra23
    super helpful. Thank you!
    TRDFerguson[QUOTED] likes this.
