Annoying map lights rattle
Discussion in '3rd Gen Tundras (2014+)' started by yoneytan, Jul 5, 2018.
  1. Jul 5, 2018 at 9:41 PM
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    I recently upgraded my sound system and am getting an annoying rattle from the map lights. Anyone have ideas how to quiet them down?
  2. Jul 6, 2018 at 10:17 AM
    yoneytan
    Asi
    14 CM
    Let me know what you did to quiet them down if it works. I’m thinking some foam pieces shoved in there might keep it from rattling.
    GNTundra and NewImprovedRon like this.
  3. Jul 6, 2018 at 4:25 PM
    Tundra Fan
    Tundra Fan Cotton Member
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum, Silver Sky Metallic
    I'm having the same issue with my rearview mirror. Rattle crazy.:annoyed:
    GNTundra likes this.
  4. Jul 10, 2018 at 8:51 AM
    yoneytan
    Asi
    14 CM
    GNTundra did you ever get rid of the rattle? I took off the map light panel and can't come up with a solution. Is there a way to take apart the entire assembly? I'm thinking if thats possible I could probably glue some fan on the sides of the clear light cover making it snug against the housing but from the looks of it the panel can't be taken apart.
  5. Jul 10, 2018 at 9:01 AM
    texasrho83
    texasrho83 Teacher in a Tundra
    Charles
    Conroe TX
    2016 DC MGM 4x4
    I've done a little..
    Are you referring to the entire headliner piece that houses the sunglass keeper? You can pull that whole piece down and take it apart. I installed blue LEDs for my interior lighting and didn’t pull the entire piece at the time but did the whole thing later for my CB install.
  6. Jul 10, 2018 at 9:55 AM
    yoneytan
    Asi
    14 CM
    I got the entire panel off but want to separate the black rear piece from the front part. What’s rattling is the light covers which are also used to turn the lights on/off. There’s a little bit of play in them which rattled when the bass hits.
  7. Jul 10, 2018 at 11:37 AM
    lbcdan
    lbcdan New Member
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Tint, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4,
    How hard was it to remove the panel? I have a bulb connector that got pushed up and I cant get it out.
  8. Jul 10, 2018 at 11:40 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    You can pull the clear plastic lenses out by themselves. Just take a small flathead screwdriver, or butter knife, and gently pry them out. I did mine like that.
  9. Jul 10, 2018 at 11:42 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    You need a T20 Torx Driver to undo the screws. I believe there are only 4-6
  10. Jul 10, 2018 at 12:14 PM
    fisherman951
    fisherman951 New Member
    Tony
    Riverside
    2017 crewmax 4x4
    Turn it up louder? :notsure:
  11. Jul 10, 2018 at 12:25 PM
    Trooper2
    Trooper2 Membrane
    2007 Tundra 5.7 L Double Cab TRD 4x2
    TSS 20 Wheels Pioneer 8100NEX N-Fabs Int LED's
    I used some Felt with sticky backs for furniture legs to quiet down all the compartment doors in our 07. The glove compartment(s), console, Anything with latching doors. Placed close to latches. There was a sheet with various precut circle sizes, 1/2", 3/8", 1/4" etc. Even cut some down as needed.
    The light covers / lenses are meant to move. Maybe you could fit a piece of felt in somewhere to take up any slack. Maybe try using clear/white velcro with sticky back, the soft side.
    texasrho83 likes this.
  12. Jul 10, 2018 at 12:27 PM
    yoneytan
    Asi
    14 CM
    Very easy tool 5 mins max. Pry out the panel in front of the sunglass holder and you’ll see to screws, take them out then two more in the sunglass holder. Once they’re out unplug the wires and done. Make sure to support the panel when removing the last screw.
