Android Headunit
Discussion in 'Audio & Video' started by bryanpwatson, Sep 1, 2017.
  1. Feb 8, 2020 at 1:13 PM
    #2701
    CPdaddy
    CPdaddy Why am I so tired
    Tom
    Denver
    16 Tundra CrewMax Limited
    Boss 3" Lift, TRD Dual Exhaust, S&B Intake, TRD Rear Sway, 285/75r18 Nitto Ridge Grapplers on Fuel Beast Wheels, SPC upper control arm, Rough Country front bumper with LED bar and dual lights on each side, Rear bumper blackout covers, Go Rhino running boards, Morimoto XB Headlights, HIRev LED Tail Lights
    Hello. So I checked it out. I have the same unit as you. Under settings, then user settings scroll down and you should see the temp settings. Select that and then the save and reboot. I’ve included a screen shot.
  2. Feb 8, 2020 at 7:16 PM
    #2702
    BradWils
    BradWils New Member
    7” Procomp lift Procomp MX2.75 Coilovers SPC UCA’s Plus 3” Rear Shackle 35x12.50 R20 Duratracs Pro Com 20x9 0 offset rims Bora 1.5” wheel spacers OEM LED Headlight and Fog conversion LED interior lights TRD Pro Grill Borla Touring true dual exhaust AFE Magnum Force Stage 2 SI Pro Intake Bushwacker Fender Flairs Colour match door pulls, mirror caps and hood buldge Weather Techs Remote Start Factory Match Tint Toyota Bakflip Tonneau cover Line-X
    It was more than just that. I needed to have the Chinese version on.. same place you change from Tundra Lo to Tundra Hi. Then drop down box to Chinese and save and reboot, also needed to change the above post to C and the units toL/100km. All good now in C. Now to figure out the interior light to come on when the door opens
  3. Feb 10, 2020 at 8:05 PM
    #2703
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    Damn, I just installed my Phoenix 12.1 tonight, worked out a few minor bugs. Most importantly, the sound pops and cracks when I turn the volume up at all. I am hoping I don't have the same issue as @_SP_
    My truck is a 1794 so I have the upgraded JBL
    I have looked though the setting menus non-stop and nothing will get rid of the muddy sound and pop n crackle, its a PX6 4 64
    My current issues
    1) Snap crackle pop sound?
    2) Sound turns off when I put truck in reverse?
    3) Resolution on the back up screen is grainy?
    I have watched YouTube videos and searched, any help and or input would be appreciated.
  4. Feb 10, 2020 at 8:17 PM
    #2704
    CPdaddy
    Tom
    Denver
    Hey bud.. So there is a setting to keep the music on when in reverse. I think it's under user settings, then parking sound. I needed to pinch the rca connects a bit then the video quality was better on the backup camera. As for the popping sound, make sure the loudness is off. You can also adjust the gain on whatever you're playing. Might be under advanced, password is 666888 and look for the different levels. I think they generally start at 15, you can go way up on them. Under settings and equalizer you can shut off the loudness. Lastly, check the pins on the speaker connection and make sure they're on tight.
    Hope this helps. I eventually went away from the factory amp and installed a 5 channel and new components. Sounds amazing now, sub on the way.
    xD3x likes this.
  5. Feb 10, 2020 at 8:41 PM
    #2705
    TundraCoast
    Ian
    California
    1794 4x4
    CPdaddy,
    Thanks for the suggestions, I do have the "loudness" off in the EQ menu. I will roll the gain down, I had actually turned it up from 30-35 so that could be an issue. I did pinch the yellow video-in connector prior to installing, the pic just seems lower resolution then the factory unit, I'll play with it a little more. Are there any settings or adjustments for the back up camera?
    I'm thinking my sound issue has to be a simple setting, there is no way that is can crackle and pop when gently turning up the volume
  6. Feb 10, 2020 at 8:44 PM
    #2706
    CPdaddy
    Tom
    Denver
    Also, since you're using the factory amp, go to console ( I think) on the top bar then look at amp settings. Make sure the correct settings are in there. Amp switch to on, a few others are in there too.
  7. Feb 10, 2020 at 9:07 PM
    #2707
    TundraCoast
    Ian
    California
    1794 4x4
    Could you walk through how you adjusted the Cur, Im hoping this is the fix for my sound issue.
  8. Feb 10, 2020 at 9:11 PM
    #2708
    TundraCoast
    Ian
    California
    1794 4x4
    What are you guys running your BT Sound level gain qt?
  9. Feb 10, 2020 at 9:20 PM
    #2709
    CPdaddy
    Tom
    Denver
    I had it at 25 with the factory amp. I tuned it way down with the aftermarket. I think I have it at 15 now. There was background static with the new amp. I didn't adjust the cur volume with mine, but from what i've read with the JBL, it needed to be turned down as well. Have you installed the aftermarket firmware update or joined the facebook group for the unit? I installed the updated firmware from one of the developers on the group and most of the issues I had went away.
  10. Feb 10, 2020 at 9:25 PM
    #2710
    CPdaddy
    Tom
    Denver
    Also, I use mine almost always with car play. I haven't even tried the BT. I know you can change the frequency settings on the BT as well. Might clean up the signal.
    here's the facebook group link. You have to request entry, but they'll get you in quickly.
  11. Feb 10, 2020 at 9:26 PM
    #2711
    TundraCoast
    Ian
    California
    1794 4x4
    I havent done either yet, just installed tonight got a few things sorted out. I was really looking forward to better sound than the stock unit.
  12. Feb 10, 2020 at 9:31 PM
    #2712
    TundraCoast
    Ian
    California
    1794 4x4
    Thank you for the tips and helpful input....I'll get o n the FB group and tinker further tomorrow
  13. Feb 11, 2020 at 2:45 AM
    #2713
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    GL with the unit. I found after spending over 5 hours playing with this thing it still sounded like crap with no Fader controls and poor backup quality keep in mind the PX6 is only 1024x768 resolution. I think the factory deck is close to that. When I put back in the factory deck I felt a sigh of relief ! it sounded like I changed all the speakers and amp. I could not believe how bad it sounded with the JBL amp. I really think that a MAJOR problem with this deck if you dont get it sorted out soon put in a return request if they dont answer file a credit dispute they answered that in 24 hours! I would rather spend the money on a Alpine Halo 9 made for for the tundra for 1400$ and get customer support if I need it and have CarPlay work! that's the whole reason I bought the android unit. I wish apple made a deck like this. But they just do car play.
    edit: also my loudness would come on all by itself sometimes. so check that not happening to you . I also spend 100$ on custom Firmware to try and help with sound. it did nothing but prettied up the UI. 1080p movies looked like crap. The best audio I was able to get out of it was a USB stick with 320kb encoded MP3's. they sounded the best over any music app even Amazon unlimited at highest quality settings. I never streamed music from my phone to the unit. I could never get a text to pop up on the screen. Very disappointed and I got the 4gb 64gb RoM unit and spent 988 with express shipping. I feel I got pulled over the coals. But I got 100% refund ad they send a prepaid label after the dispute. Before that not a peep of support. Ot return message FB YT support ticket ect.. and phone calls for over a week 3x a day during there hours. California
  14. Feb 11, 2020 at 3:02 AM
    #2714
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    You cant turn the amp off with JBL it just tuns it self back on. The only way to get it to stay off for longe than 1 second is to turn the volume to 0 and then turn the amp off. But as soon as the volume is raised with JBL system the amp comes back on and shows so on the units Display. Even with Custom FW. I wish it was that easy. I think that option is for another vehicle or when you connect the RCAs to an aftermarket amp. But being the unit comes with no instructions or literature who knows for sure.
  15. Feb 11, 2020 at 3:16 AM
    #2715
    TundraCoast
    Ian
    California
    1794 4x4
    Any idea how I can adjust the head-unit so that when I have the truck in reverse it doesn't turn off the music?
  16. Feb 11, 2020 at 3:21 AM
    #2716
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    in user setting there is an option to mute or turn down music in reverse. Mine just was default to turn it down a bit. It never turned it off 100% volume. I forget where the setting was. I was running custom FW and all the settings were in one place USER settings not scattered all over like before. I wish I could tell you exactly where that setting was. I use to take pics of the settings I changed and videos to remember what I changed and where it was it was so confusing before the custom FW.
  17. Feb 11, 2020 at 3:23 AM
    #2717
    TundraCoast
    Ian
    California
    1794 4x4
    Bummer to hear your experience, I called yesterday during biz hours no answer, I put in a support ticket today (will see if get a response). The poor sound quality is an instant deal breaker for every person who buys this unit if thats how its going to sound, how can this company even sell this product?
  18. Feb 11, 2020 at 5:01 AM
    #2718
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    Most people don't have the problems we have. I think its our JBL amp that gives us the POPs and poor sound. I don't know how they get away with no customer support at all though. Check out BBB here
  19. Feb 11, 2020 at 10:38 AM
    #2719
    TundraCoast
    Ian
    California
    1794 4x4
    Hey Tom, Do you recall what connector I need to check the pins on for the sound output, I notice when installing the 2 black multi-pin connector that they were hard to push in and no matter how hard I pushed, wasn't certain if the clips locked in place.
  20. Feb 11, 2020 at 10:48 AM
    #2720
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    My HVAC plug fell out many times. Its only the start of it.
  21. Feb 11, 2020 at 11:20 AM
    #2721
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    hey what sound is not working for you ? your HU sends the sound VIA the can bus cable the wide white cable with very small wires. If that were loose or unplugged you would not have sound at all in my.02
  22. Feb 11, 2020 at 3:10 PM
    #2722
    TundraCoast
    Ian
    California
    1794 4x4
    Update-
    I have the OEM Audio+ JBL enhancement system which has 2 subs with their own stand-alone amp, upgrade tweeters and speakers. The system also comes with “accoustic filters” that plug inline into the factory amp connectors under the pass seat. After adjusting any/all settings on the Android headunit from the suggestions of forum members,it dawned on me that those “filters” were the culprit of my sound issue. Took them out, set factory amp back to stock....adjusted Cur level up and the system is clean, clear, louder, sharper than before the Android unit. Sound is amazing. I guess now the fun begins figuring out all the cool features.
    Thanks to @JoshuaA for the tips, tricks and suggestions that’s helped me dial in my Android headunit
    Knob upgrades on the way, ordered sliver and black
    foliogrow likes this.
  23. Feb 15, 2020 at 7:27 AM
    #2723
    soylaprofecia
    soylaprofecia New Member
    Rex
    2016 TUNDRA SR5 CREWMAX 4X4
    S&M Cold Air Intake Gibson Metal Mulisha Exhaust Chrome Delete-UPOL Raptor Black-Front/Rear BUmper & Entire Front Grill Hood Buldge LED Light Bar 40" LED Light Bar Lower Bumper Opening Replaced all stock lights with LED Sprint Booster v3 Window Visors
    Selling mine here: https://www.ebay.com/itm/133334830804
    will sell it to anyone here for $500.00 plus shipping if interested. Just message me.
    Nothing wrong with unit at all. Enjoyed it very much, just went with an iPad setup, prefer Apple!
    Let me know if there are any questions.
    rhaliuk likes this.
  24. Mar 12, 2020 at 3:34 AM
    #2724
    JROD15
    JROD15 New Member
    john
    2019 Toyota Tundra
  25. Mar 17, 2020 at 5:19 AM
    #2725
    jakebrenner
    jakebrenner New Member
    Jake
    Indian Land, SC
    2015 TRD Pro
    Do you have an owner's manual? I just bought a used tundra and it came with this unit. I'm having issues with bluetooth phone calls, as the other party cannot hear me. Also, seems really busy and I'd like to simplify it. I don't like google maps, and would rather use waze. Sorry, I know i've bombarded you with a lot, hopefully you can give me some advice. Thanks!
  26. Mar 17, 2020 at 1:08 PM
    #2726
    supermotobobby
    supermotobobby New Member
    Bobby
    2022 Tundra Platinum 4x4
    No I don't sorry.
  27. Mar 18, 2020 at 8:46 AM
    #2727
    JROD15
    JROD15 New Member
    john
    2019 Toyota Tundra
    check you tube there is a lot of videos on these units, what year is your truck! I recently had to return my Tesla style unit it would not integrate well with my 2019 Tundra ,the vehicles collision system came on. do you know what Generation it is.
  28. Mar 18, 2020 at 11:53 AM
    #2728
    jakebrenner
    Jake
    Indian Land, SC
    2015 TRD Pro
    It's a 2015. No issues with interface, really. but i'm not sure I like not having knobs
  29. Mar 31, 2020 at 7:07 PM
    #2729
    CARLHEIZER
    CARLHEIZER New Member
    San Diego
    2019 TUNDRA 1794 EDITION
    LINE-X, BAK MX4 WITH BAK BOX, UPGRAGED SOUND SYSTEM BY OEM AUDIO + AND CERAMIC WINDOW TINT - ALL SIX WINDOWS.
    JROD15, can you explain what you mean about the vehicle collision system? You mean the TSS? If so, do you know why? I have a 2019 1794 with all that stuff. Thanks.
  30. Mar 31, 2020 at 8:09 PM
    #2730
    JROD15
    JROD15 New Member
    john
    2019 Toyota Tundra
    I installed a Phoenix Teska android radio in the truck and it did not interface well with the the system. My Airbag bag and collision system showed failures.
    Once I removed the radio and reset the system with an OBD ll reader it resolved my problem.
