Android Headunit
Discussion in 'Audio & Video' started by bryanpwatson, Sep 1, 2017.
  1. Mar 23, 2019 at 11:49 PM
    #2371
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    I have 2018 limited and my TPMS work without any modifications or settings changeimage.jpg
    Drk_Jdi likes this.
  2. Mar 24, 2019 at 10:12 AM
    #2372
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    I wanted to see if anyone had any answers to this as I am trying to find a replacement screen/digitizer for the 2nd Gen w/ buttons 12.1" screen. Does anyone know where I can get this replacement screen?
  3. Mar 25, 2019 at 4:13 AM
    #2373
    ZPMAN
    Minnesota
    Try here. http://www.fixmyowntv.com/lcd
  4. Mar 25, 2019 at 5:55 AM
    #2374
    g6t9ed
    Thanks for the link and reply. I already have the unit taken apart, I just need to know where to get a replacement screen. Unless I read your link incorrectly, it just provides general instructions on taking an LCD/LED apart.
    I did find a part number for what appears to be the display but all results lead to chinese links. I'm worried there isn't any locally or US sourced place where I can obtain just the screen. I already returned the unit once to Phoenix for repair. I didn't learn the first time and I've come to the conclusion that it's the yellow clips that are placed onto the top of the unit that are creating too much pressure when installing that causes the cracks.
  5. Mar 25, 2019 at 7:36 AM
    #2375
    TXTundra2722
    2015 Black Tundra
    How long did it take yours to crack? You did the mod at the bottom of the dash(removing material in the center) to help with this known issue?
  6. Mar 25, 2019 at 7:55 AM
    #2376
    g6t9ed
    The first time it occurred, it was after a little while this past January. That one was different as I noticed it started as a small crack at the top middle of the screen, about where the power icon is located on the default theme. The crack didn't really develop until I decided to mess with the unit and wanted to place the yellow tabs on the unit, thinking it would secure it in place. So, I didn't think that the tabs caused the issue as there was a small crack previously. This last time it occurred my radio antenna fell out at some point and again I wanted to place the yellow tabs to secure it after I put the antenna cable back in. Immediately, the crack developed when I applied pressure to the top corners of the unit and the crack developed at the same spot. So, this led me into thinking it was the amount of pressure that I applied caused by the tabs that created the cracks.
    I was unaware of any mod at the bottom of the dash or removal of material to mitigate this issue. I must've missed that either on here or in Facebook.
  7. Mar 25, 2019 at 9:24 AM
    #2377
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    From fb
    edwin729 and Tundra$ like this.
  8. Mar 25, 2019 at 12:23 PM
    #2378
    TXTundra2722
    2015 Black Tundra
    Yes, there are several discussions about removing material from your dash because of this exact issue.
  9. Mar 25, 2019 at 12:36 PM
    #2379
    g6t9ed
    Ah, I think I know what you are talking about. I had thought they resolved that by notching the unit's frame as I confirmed it looked to have been manually shaved when I inspected it upon receiving it. I guess it's not enough of a notch to correct exactly what I went through. Either case, it's a moot point until I can find a replacement screen.
  10. Mar 25, 2019 at 1:12 PM
    #2380
    TXTundra2722
    2015 Black Tundra
    They did notch it, but evidently(according to the install video that I used.) You still had to trim some off the dash. Hopefully you get this resolved without too much hassle
  11. Mar 25, 2019 at 1:30 PM
    #2381
    g6t9ed
    Yeah, that's what I get for not doing my due diligence and taking them at their word. Well, I'm going to try to take it to a cell phone and tablet repair shop and see if they can provide some kind of generic glass for this; fingers crossed. Thanks for your input.
    Update: Looks like both of the repair shops I went to gave me the same story - the only way to get it is through the manufacturer. Looks like a conversation with Phoenix is my only choice.
  12. Mar 25, 2019 at 5:19 PM
    #2382
    ZPMAN
    Minnesota
    I did replace a few laptop screens in the past but can't remember the site I used for the replacements.
    Maybe try here, https://m.repairsuniverse.com/lcdscreens.html
    g6t9ed[QUOTED] likes this.
  13. Mar 25, 2019 at 5:54 PM
    #2383
    ZPMAN
    Minnesota
    If you haven't seen this already, check post #1899 and #1920
  14. Mar 25, 2019 at 6:05 PM
    #2384
    TXTundra2722
    2015 Black Tundra
    I was wondering how you found that, but saw you originally posted those. I'm pretty sure I read over these threads when installing mine, nice work.
  15. Mar 25, 2019 at 7:58 PM
    #2385
    g6t9ed
    Thanks for the link. Site looked promising but does not show any screens that would seem compatible with our unit.
    I'm definitely going to be doing this modification when I get the screen all settled. Thanks again.
  16. Mar 25, 2019 at 8:27 PM
    #2386
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I went and purchased a 7.1 fastboot unit with A/C buttons. Is anyone running an aftermarket amp, how did you connect it? I am going to get a plug and play amp from ********* soon, but i just dropped a $1500+ and was going to hold out and use my old pioneer mono amp.
  17. Mar 25, 2019 at 9:51 PM
    #2387
    TXTundra2722
    2015 Black Tundra
    I'm using an aftermarket amp from James. He sells the connectors to plug into the factory harness under the passenger seat. Only real work is running the power wire to the battery but that's cake
  18. Mar 26, 2019 at 6:29 PM
    #2388
    ZPMAN
    Minnesota
    If you can find the manufacturer's name and a part number you could try googling it, and maybe see if Phoenix might have one. Good luck.
  19. Mar 27, 2019 at 6:20 AM
    #2389
    g6t9ed
    Yeah, i took the unit apart and found the model number located on the back. The only thing google came up with was a few chinese sites that I had to have translated. One of the repair shops I went to confirmed that as well since he couldn't locate the part either. Yeah, I'm thinking, at least at this point in the game, Phoenix will probably be my best bet.
    ZPMAN[QUOTED] likes this.
  20. Mar 27, 2019 at 11:38 AM
    #2390
    Drk_Jdi
    Drk_Jdi New Member
    Jeremy
    Tacoma, WA
    2014 Platinum Crewmax Barcelona Red
    Belstien 5100's front to level Belstien 5112's rear w/ 1.5" block lift Tesla style Android radio Front windows tinted to match factory rears TRD shift knob - dark grey Color match mirror caps Color match handles Light bar in hood scoop
    Did you have to move a wire to have it turn on with ACC?
    I have looked through the forum and the FB group. Some one posted a picture showing a cut wire from the manufacturer, but I didn't see where to reconnect it, or how to power it on ACC.
  21. Mar 27, 2019 at 1:11 PM
    #2391
    motocrossman99
    motocrossman99 New Member
    Josh
    2019 Barcelona Tundra SR5
    I just bought my first truck 2 weeks ago. 2019 tundra. i should not have found this site i have already spent $$$ i would not have but this looks to sweet not to put in my truck.
    ZPMAN, Drk_Jdi and JoshuaA like this.
  22. Mar 28, 2019 at 6:54 PM
    #2392
    Dimetera413
    Dimetera413 New Member
    Do you mean the current temp on the driver info display behind the steering wheel or on the head unit?
  23. Mar 28, 2019 at 6:58 PM
    #2393
    TXTundra2722
    2015 Black Tundra
    No, he's talking about the temperature for the a/c and heat. Unless a fix was released, it doesn't display properly on the upper end models
    viha22 likes this.
  24. Mar 28, 2019 at 7:17 PM
    #2394
    viha22
    viha22 MAGA
    WA
    What he said ^^^^
  25. Mar 28, 2019 at 7:25 PM
    #2395
    Dimetera413
    Ohhhh got it. Thanks!
  26. Mar 31, 2019 at 12:35 PM
    #2396
    xando
    xando New Member
    Oregon
    Tundra TRD OFF ROAD 2015 crewmax/ silver metallic
    Hi @bsavoir ,
    did you buy it from “Phoenix” or from “Trinity Auto Solutions”?
  27. Mar 31, 2019 at 2:15 PM
    #2397
    Devildawg712
    Devildawg712 New Member
    Union City, Ca
    2020 Marine Corps Green Sequoia. (SEQUNDRA) Past~~ 17' Cement TRD PRO (FUNDRA)
    ^^they are the same company
    JoshuaA likes this.
  28. Mar 31, 2019 at 6:33 PM
    #2398
    xando
    xando New Member
    Oregon
    Oh, thanks. I was not aware...
    :sorry:
  29. Mar 31, 2019 at 8:19 PM
    #2399
    Devildawg712
    Union City, Ca
    Dont be, they dont broadcast that they are the same entity. Just another way for a company to expand I suppose. I've seen this many times in other car club/ forums I've been on. Their customer support/ service department (or single person) is who told me they are one in the same.
  30. Apr 1, 2019 at 7:30 PM
    #2400
    Tricky001
    Tricky001 New Member
    Rick
    Just installed the new version with buttons today , getting very slow network speeds. With home WiFi and hotspot choppy browsing YouTube cutting out anyone else having this issue? Tks.
