Android Headunit
Discussion in 'Audio & Video' started by bryanpwatson, Sep 1, 2017.
  1. Mar 3, 2019 at 12:45 PM
    #2341
    Cthulhu
    I had bought James’ single enclosure, but then decided I wanted two 10’s. So I used the dimensions of James’ box and looked at other boxes on the internet, and built my own. Gave the single box back to James since he’s been so good to the tundras.com community. Fitment is perfect, you just need to remove the jack accessory bag (not the actual jack) and hammer down the tab the bag clips to. The two vertical block strips on the side of each sub protects the sub. Very similar design to the box below.
    https://www.amazon.com/gp/aw/d/B075YFPRV1/ref=ppx_yo_mob_b_old_o0_img?ie=UTF8&psc=1
  2. Mar 3, 2019 at 12:47 PM
    #2342
    Cthulhu
    Can’t remember which, but that’s either for the satellite radio antenna or GPS antenna. Pretty sure it’s the satellite radio antenna, especially if you bought the adapter to use your existing GPS antenna.
    viha22[QUOTED] likes this.
  3. Mar 3, 2019 at 12:55 PM
    #2343
    Cthulhu
    Do you have the factory 8” JBL sub, or the 10” sub from James’ group buy? The 10” sub is definitely louder than the 8” factory sub, but it still wasn’t loud enough for my tastes, even with the Phoenix HU. Unfortunately there is no independent control for the sub with the Phoenix HU, that’s why I went with a separate JBL amp with a level control knob.
  4. Mar 3, 2019 at 1:11 PM
    #2344
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    I see.Yeah i have factory 6” sub.I quess thats my next to do mode is to replace the amp and a sub.Thanks
  5. Mar 3, 2019 at 10:05 PM
    #2345
    viha22
    viha22 MAGA
    WA
    So after driving my truck today and enjoying the new HU i park it and let sit for few hours before going to do some errands.Everything was fine .Now i start the truck and have no sound coming out of all speakers.All settings look good other than amp info audio settings not changeable (greyed out).
    Checked amp fuse under the hood and its not burned out.Wtf everything was fine when i turned off last time .Any thoughts guys? Also screen seems darker even with dimmer all the way up.
  6. Mar 4, 2019 at 3:20 AM
    #2346
    Cthulhu
    Weird. Did you try putting a paperclip or something in the RST hole on the left hand side and resetting the HU? If that doesn’t work, try pulling the HU out and making sure all connections are secure. The pins in those harnesses unfortunately are fragile and can either bend or get disconnected easily. I plugged all of my harnesses in/together, and before I put the HU back in the dash, I wrapped all the harnesses that connect together in electrical tape. The one connection that really gave me a headache was the GPS antenna. I hope this helps and that’s all it is, either a software glitch that necessitates a reset, or a bad connection.
  7. Mar 4, 2019 at 6:59 AM
    #2347
    viha22
    viha22 MAGA
    WA
    Thanks i will try that
  8. Mar 4, 2019 at 12:21 PM
    #2348
    TXTundra2722
    2015 Black Tundra
    Make sure you post this in the FB page too.... there are normally quick responses on there. I second on checking all connections behind the HU. I had one that never wanted to "click" into place
  9. Mar 4, 2019 at 10:41 PM
    #2349
    viha22
    viha22 MAGA
    WA
    Yep loose connection.As soon as i pulled HU out ,sound came back.Thanks
  10. Mar 4, 2019 at 10:43 PM
    #2350
    TXTundra2722
    2015 Black Tundra
    Glad you got it fixed! Did you tape all of the wires together this time that way if one gets loose, the rest keep in plugged in?
    viha22 likes this.
  11. Mar 5, 2019 at 5:14 AM
    #2351
    JPritch
    JPritch New Member
    Josh
    17 TSS Crewmax
    Does anybody else experience audio crackling when putting their truck into reverse and activating the backup cam? I get a slight scratchy effect when doing this. Not sure if this is common or if I may need to check my connections as well.
  12. Mar 5, 2019 at 7:10 AM
    #2352
    viha22
    viha22 MAGA
    WA
    Sure did.Thanks
  13. Mar 5, 2019 at 7:38 AM
    #2353
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    No but I find it momentarily cuts out when I put it in reverse or every so often when I leave Wi-Fi on and not hotspotting.
    I tried wireless mirroring for the first time yesterday and I could see texts and email notifications coming in, turn the phone sideways and its in landscape mode on the screen. Not as nice a view as native apps but works.
  14. Mar 7, 2019 at 9:44 AM
    #2354
    Kbenoit1
    Kbenoit1 New Member
    Hi Guys, First post. Ive been lurking for a bit and read a bunch of this and other threads related to the tesla style radio.
    Have a few questions on it.
    First. My truck did not come with heated seats, but i am planning on adding them. It looks like the trucks with the heated seats can control them through the touch screen. Does anyone know if i add headted seats if i can control them with the touch screen without having the dual climate control ? I am assuming the wiring for the heated seats runs into the back of the unit.
    Second. Does the latest version with 7.1 fastboot support sirius or XM ?
  15. Mar 7, 2019 at 10:21 AM
    #2355
    TXTundra2722
    2015 Black Tundra
    I also am interested in if anyone has heard of or completed the heated seats mod. As far as I know and someone else can chime in if I'm wrong here, but to run satellite radio, you need another stand alone unit in addition to this.
  16. Mar 14, 2019 at 8:33 AM
    #2356
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Sorry for the late reply, I would not rely on the android HU to control your seat's heating/cooling in case the HU crashes. Ideally that should turn it all off, but you don't want it stuck on heat or cool. Or having to wait for a boot up to change your seat settings when you can use a physical button to do it right away, working HU or not.
    And none of the units have native Sirius/XM. You can install the app and hotspot which uses data. To get satellite feed, you would need to dongle an XM device like the Commander Touch which has the controller/display.
  17. Mar 15, 2019 at 7:50 PM
    #2357
    xando
    xando New Member
    Oregon
    Tundra TRD OFF ROAD 2015 crewmax/ silver metallic
    What’s the link ”trinity audio”?
    Voyagermike likes this.
  18. Mar 15, 2019 at 9:11 PM
    #2358
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
  19. Mar 16, 2019 at 11:39 PM
    #2359
    xando
    xando New Member
    Oregon
  20. Mar 17, 2019 at 6:46 AM
    #2360
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    ^ Enter JMTUNDRA71 at checkout in the Discount code box and click Apply, still works:
    Your 2015 should be a straightforward install and setup, go to fb for all your questions. Responses are immediate.
  21. Mar 17, 2019 at 9:43 AM
    #2361
    TXTundra2722
    2015 Black Tundra
    It's a super easy install.... takes more time to pop the factory hu out than it does to install this.
    JPritch and Voyagermike like this.
  22. Mar 20, 2019 at 1:02 PM
    #2362
    Tricky001
    Tricky001 New Member
    Rick
    Has anyone received this unit from this vendor? Just curious getting ready to pull the trigger
    ....tks
  23. Mar 20, 2019 at 2:46 PM
    #2363
    viha22
    viha22 MAGA
    WA
    If you are talking about Trinity than yes i bought mine through them and had it at my doorstep in little over a week .
  24. Mar 20, 2019 at 8:09 PM
    #2364
    Tricky001
    Rick
    Thank you..are you happy with it?
  25. Mar 20, 2019 at 9:00 PM
    #2365
    viha22
    viha22 MAGA
    WA
    It has its small quirks like current temp on limited and higher (2018 up) trims not displaying but overall im happy with it. Night and day compared to boring stock HU.
  26. Mar 20, 2019 at 10:04 PM
    #2366
    TXTundra2722
    2015 Black Tundra
    Same for me, but I love it
  27. Mar 22, 2019 at 8:41 PM
    #2367
    phatjoe
    phatjoe New Member
    2019 TRD Pro Voodoo Blue
    This is probably a stupid question but better safe than sorry....
    This 12.1" unit will work in a 2019 Tundra TRD Pro right? :confused:
  28. Mar 23, 2019 at 9:32 PM
    #2368
    xando
    xando New Member
    Oregon
    I’m about to pull the trigger on this one......
    Decisions, decisions!
    I’m wondering if a new version is coming up soon.
    Anyone knows?
  29. Mar 23, 2019 at 9:35 PM
    #2369
    xando
    xando New Member
    Oregon
    Thank you @JoshuaA .
    Very helpful, but you sir are a bad influence!
    :spending:
  30. Mar 23, 2019 at 9:58 PM
    #2370
    TXTundra2722
    2015 Black Tundra
    Has anyone on here connected any tpms up with this HU?
