Android Headunit
Discussion in 'Audio & Video' started by bryanpwatson, Sep 1, 2017.
  1. Nov 8, 2018 at 11:34 PM
    #1981
    ZPMAN
    Minnesota
    Earlier today I found a way to use a kinda hidden feature on the HU. When I was discovering the layout on the newly installed app Ulysse Speedometer, in the app you can pick wich app you want to run. I kept seeing the cam app and thought I'd give it a try knowing there is no front or rear cam on the tablet, but found it possible to get it to work off my front or rear cams. Now if I could just get the picture straight.
    https://youtu.be/h2StBVDumi8
  2. Nov 9, 2018 at 9:23 AM
    #1982
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    Ok. How do you turn my amp on? My volume is max out and is not as loud as it was with Gen1. I've try all of the different setting but this page everything is gray out.
  3. Nov 9, 2018 at 10:17 AM
    #1983
    ZPMAN
    Minnesota
    I my opinion for some reason I believe the first gen was louder than the 2nd gen w/dials, what sound system do you have?
  4. Nov 9, 2018 at 10:19 AM
    #1984
    209TRDPRO
    2016 Tundra TRD PRO
    Just lights for now
    standard on pro. Not premium JBL or anything. The loudness is almost 1/2 from the gen1. I remember being able to changing the volume setting and amp on this screen but had to do with certain combination of setting to open up this setting.
  5. Nov 9, 2018 at 10:37 AM
    #1985
    ZPMAN
    Minnesota
    Have you turned up the CUR VOLUME?
    209TRDPRO likes this.
  6. Nov 9, 2018 at 10:38 AM
    #1986
    209TRDPRO
    2016 Tundra TRD PRO
    Just lights for now
    Lol...yes sir.
  7. Nov 9, 2018 at 10:41 AM
    #1987
    ZPMAN
    Minnesota
    I can tell that my 2nd w/dials is not as loud as the 1st gen was but not much.
  8. Nov 9, 2018 at 10:42 AM
    #1988
    209TRDPRO
    2016 Tundra TRD PRO
    Just lights for now
    Is you amp setting turn on or off?
  9. Nov 9, 2018 at 10:44 AM
    #1989
    ZPMAN
    Minnesota
    One thing I have taken note of is that the 2nd gen does not get rebooted like the first gen did, that may be why things may take time to take effect.
  10. Nov 9, 2018 at 10:49 AM
    #1990
    ZPMAN
    Minnesota
    I don't believe I can turn on or off.
  11. Nov 9, 2018 at 11:33 AM
    #1991
    ZPMAN
    Minnesota
    Two thing's I would like to mention, in the first 24 hrs after installing the 2nd gen W/dials it was laggy and slow as shit doing anything, for some reason next day everything it was up to speed and I did not change anything (WTF?) The other is someone mentioned that they could not get sound out of one side (L or R). That did happen to me and could only get sound from all speakers from only the radio, only the passengers side speakers would work for anything else. I believe it was due to something I did messing with my internet connection. How I eventually restored all sound was going into settings, general and do a reset and had to do that twice and it did a shutdown and reboot and all sound was restored.
    One thing I miss on the 1st gen was with a turn of a key you could shut down and reboot to start fresh or apply new changes made.
    Please take all that have said with a grain of salt for I am no expert on anything unless I've had a few beers.
    TundraLuv likes this.
  12. Nov 9, 2018 at 3:24 PM
    #1992
    Cthulhu
    But still louder than the JBL Audio stock system, right? I’m assuming you have the JBL since you have a Platinum. Pretty much the main reason I’m getting the Phoenix HU is I’ve read it’s supposed to be louder than the stock JBL system...I sure do hope that’s still the case...
  13. Nov 9, 2018 at 3:43 PM
    #1993
    209TRDPRO
    2016 Tundra TRD PRO
    Just lights for now
    Mine isn't louder than Gen1. I still haven't figure it out yet. This thing got to many damn setting. I'm at max volume 40 right now. The gen1 would only be about 1/2 and its loud enough.
  14. Nov 9, 2018 at 4:10 PM
    #1994
    ZPMAN
    Minnesota
    Yes the 2nd gen with dials/buttons is louder than stock. Just remember to walk down the hill and not run.
    Fiestee23 likes this.
  15. Nov 9, 2018 at 4:20 PM
    #1995
    ZPMAN
    Minnesota
    I haven't worked on a non JBL but sounds like the HU amp is not working. I'm sure you did check that your set to low tundra right?
  16. Nov 9, 2018 at 8:38 PM
    #1996
    ZPMAN
    Minnesota
    Try scrolling up and down with the cur volume ajustment.
  17. Nov 10, 2018 at 12:12 PM
    #1997
    tundra26
    tundra26 New Member
    There maybe different brands but I think they all come from one supplier
  18. Nov 10, 2018 at 4:58 PM
    #1998
    Cthulhu
    Agreed, there are units out there that are exactly the same as the Phoenix HU, just with different brand names, but there are plenty of other Android-based units out there that are nothing like the Phoenix in form and/or function, made by companies such as Alpine and Kenwood.
  19. Nov 15, 2018 at 9:07 AM
    #1999
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I think you should create a new thread on its own for more answers, this one should really be titled Phoenix Android 12.1" Vertical Radio or something like that because that's what is being referred to and discussed here. Your post will end up buried.
    TundraLuv and Cthulhu like this.
  20. Nov 15, 2018 at 10:12 AM
    #2000
    Cthulhu
    Preach...Amen!!
  21. Nov 16, 2018 at 7:03 AM
    #2001
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    I'm selling or returning mine. If you want it for the group buy price + actual shipping or free pickup in Denver, PM me. Nothing wrong with it other than the issues everybody is working through that they insist are programming issues. I'm just no longer willing to deal with it. It's one with buttons/knobs. I'll post in the buy/sell/trade after I get it out of my car in the next couple hours.
  22. Nov 25, 2018 at 7:12 AM
    #2002
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    ZPMAN likes this.
  23. Nov 25, 2018 at 7:18 AM
    #2003
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Got my shipping notice today from Hong Kong.
    Cthulhu and JoshuaA like this.
  24. Nov 25, 2018 at 7:31 AM
    #2004
    Ragecage92si
    Ragecage92si New Member
    Josh
    17 blue TRD
    7" BDS lift kit,3” body, King 2.0’s, Mammoth Guards, Custom powder coating, Nitro 5.29, D.A.P. Tuned, Coachbuilder shims, Coachbuilder Steering kit, Wether Tech vent visors, and hood protector, spray in bed liner, Bakflip, Fuel wheels, 38” TOYO tires, Bushwacker fender flares, Dirty deeds exhaust , TDK front bumper, Rigid light bar/floods/spots. Husky fronts, Weather Tech rears, ESP under seat storage, PowerX2 battery, Android Tesla unit, AJT chrome delete, Horn Blasters, Custom switch cluster, Interior leds, Revere leds, 19 pro headlights, Rocklights, Custom MAYHEM projector
  25. Nov 25, 2018 at 7:58 AM
    #2005
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Yes, I check it out sometimes. Jodi says $550 group buy price won’t come around again. 15% off is for the 2007-13 Tundras, head unit for those not previously offered I think.
  26. Nov 25, 2018 at 6:18 PM
    #2006
    Cthulhu
    Me too, POW!!! (Rob Riggle style!)
    TundraLuv[QUOTED] likes this.
  27. Nov 26, 2018 at 3:59 PM
    #2007
    Emire221
    Emire221 New Member
    NJ
    Just ordered this for my second gen tundra been waiting for them to release it. Came out to $569 with the coupon.
    ZPMAN likes this.
  28. Nov 29, 2018 at 11:50 AM
    #2008
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Loving my new unit.. no issues at all. This is the 2nd gen with buttons on my 2017 SR5. Makes the sound so much better and get to have some fun with other apps! Digging it so far!
    xando, Cthulhu, Voyagermike and 3 others like this.
  29. Nov 30, 2018 at 12:28 PM
    #2009
    Cthulhu
    Hello team! I just installed my 2nd gen with knobs, and I have some questions hopefully someone can answer. I tried asking them on the FB page for Tundra Phoenix owners, but damn FB asked for a pic to verify my identity and I'm locked out until it does!! :mad:
    I have a 2018 Limited with the Premium Package. So, it comes with AUTO AC, and the factory unit has temperatures. I changed the unit to TUNDRA HI, saved and rebooted, and verified it was TUNDRA HI, but it still only shows HI and LO where I believe the temps should be. Before I was kicked off FB (hopefully only temporarily :fingerscrossed:), someone said that they still don't have the temps fixed for 2018's yet. Is that accurate, or is there another setting I need to go into to get temps to show?
    Also, I think I read here where someone else had @TundraTex's FRAC harness, and it worked. I can't seem to get mine to work. Can anyone give me wiring instructions on which male and female RCAs plug in together, and which male plugs into the back of the Phoenix HU? Also, are there settings I need to adjust to get the cameras working?
    Thanks in advance to anyone that can assist! :thumbsup:
  30. Nov 30, 2018 at 1:37 PM
    #2010
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    My truck is 2y older so software settings are different but wiring...
    Connections:
    Leftover plugs:3914A680-AA3F-4D9B-B040-21866D6EEF52.jpg
