Android Headunit
Discussion in 'Audio & Video' started by bryanpwatson, Sep 1, 2017.
  1. Oct 10, 2018 at 6:59 PM
    #1681
    BayRunner
    2017 Tundra Platinum
    I'm studying the wires that came with the Tesla HU in prep for the install. In your pic you show the truck wire for the Satellite antenna that will not be used in the new HU. Is this a separate wire from the GPS antenna? I'm asking because I will attempt to also install the SiriusXM Onyx XM receiver. I can plug this into one of the HU aux inputs with a 3.5mm to RCA adapter but now need to figure out how to use the stock antenna. I would rather do this then try to run the cheap XM antenna.
  2. Oct 10, 2018 at 7:50 PM
    #1682
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Yes, the GPS and satellite radio antenna connections are separate on the truck... I could not even find the GPS antenna connection from the truck. I used the GPS antenna that came with the radio and screwed it into the gold colored connection on the back of the head unit and ran the “puck” through the back of the dashboard over the steering column and to the far left side A arm. The cord will wedge between the speaker cover and the dash plastic and you can set the GPS receiver up by the front windshield.
    If you are connecting a separate satellite radio receiver and antenna like you stated, I would assume you could connect it to the RCA Aux input connectors and find an adapter to connect your receiver to the gray satellite radio antenna plug. If there is no adapter for that gray plug to the Onyx I’d guess you would run the antenna that comes with the receiver. I can’t find a good picture of the Onyx plugs to tell if it will fit or not.
  3. Oct 10, 2018 at 7:56 PM
    #1683
    dud13
  4. Oct 10, 2018 at 7:59 PM
    #1684
    ZPMAN
    Minnesota
  5. Oct 10, 2018 at 7:59 PM
    #1685
    BayRunner
    Yes, the iDatalink ACC-SAT-TO2 includes an adapter cable for the XM Satellite receiver. This cable should be plug and play for the XM and then I can use one of the other cables in the iDatalink kit to splice to the GPS truck wire. This may work
  6. Oct 10, 2018 at 8:00 PM
    #1686
    dud13
  7. Oct 10, 2018 at 8:14 PM
    #1687
    ZPMAN
    Minnesota
    I am also curious about the front cam, I know that Phoenix makes this https://phoenixandroidradios.com/co...ar-camera-automatic-control-module-switch-box
    but I am thinking about trying out the 360° cam https://phoenixandroidradios.com/co...-hour-parking-monitor-loop-recording-g-sensor
    I'm on wife probation again after getting gears and Aurburn LSD.
    Alexstundra likes this.
  8. Oct 11, 2018 at 6:46 AM
    #1688
    dud13
    Ok. Here is a new one that happened this morning. My Bluetooth connection doesn’t play music anymore. The phone Bluetooth works making and receiving calls... but no music. Last night it worked fine, nothing changed since then. Startup this morning and nothing. Tried the following:
    - Turn truck and phone off and on again
    - Deleted Bluetooth connection from truck and phone and reconnected
    - Checked any kind of mute and volume settings
    It shows that it is playing, eg the “equalizer” bar bounces around. Just no sound.
    Running iPhone 7+, updates are current. No updates, setting changes, system changes on the phone or head unit from yesterday.
    Calling Phoenix as soon as they open. Hoping that someone here may know.
    JoshuaA likes this.
  9. Oct 11, 2018 at 7:18 AM
    #1689
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Thanks for being upfront with your problems. I want one of these as long as they’re not buggy, for the most part I can handle UI fixes and software updates. That’s not a good sign when nothing has changed. Can you still plug in a USB under the HU and it’ll play? How does Google Maps get on the screen? Is it running off the android app in the HU and just getting network connectivity from your iPhone?
  10. Oct 11, 2018 at 7:58 AM
    #1690
    dud13
    There are a few bugs. So far no show stoppers as everything I have ran into has/can be fixed. The jury is out on the Bluetooth music, but stay tuned. I think there is a setting somewhere that should provide an easy fix. I’ll try plugging it in to the USB and see what happens. Google maps can be mirrored from your phone screen or played through the app on the head unit. Be aware that you will need to pair your phone and use its data for it to work from the head unit unless you download the map for offline use.
    JoshuaA[QUOTED] likes this.
  11. Oct 11, 2018 at 9:29 AM
    #1691
    dud13
    Ok the Bluetooth streaming has been fixed. Talked to Phoenix and under the settings, go to sounds and make sure they are all turned up. Apparently there is a bug that causes them to turn all the way down or off somehow.
  12. Oct 11, 2018 at 9:44 AM
    #1692
    AK-in-MI
    AK-in-MI New Member
    Joey
    Michigan
    2015 Platinum Crewmax
    D.A.P. Tune Bilstien 6112/5160 33x12.50xr20 Toyo Open Country M/T 20x9 Fuel Coupler TRD Exhaust
    I had that issue a little while ago. It was showing on the eq but not playing. I made a phone call and it came through the bluetooth and then went back to my music and it started again. Not sure if it is just a glitch bit it has happened a couple times and when I made a call it reset.
  13. Oct 11, 2018 at 9:47 AM
    #1693
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Did you get a chance to ask them what’s the 6 small empty connector is for?
  14. Oct 11, 2018 at 11:34 AM
    #1694
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Thanks, which looks better? Android Google Maps or mirroring? How does it mirror?
  15. Oct 11, 2018 at 12:01 PM
    #1695
    dud13
    No. I forgot. Next time I call I will ask.
  16. Oct 11, 2018 at 12:01 PM
    #1696
    dud13
    Google maps on the radio. No mirror looks much better. I’ll take a video and upload it later tonight.
  17. Oct 11, 2018 at 12:14 PM
    #1697
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    :thumbsup:
  18. Oct 11, 2018 at 1:54 PM
    #1698
    maxcala
    maxcala New Member
    Max
    L.A.
    2014 Limited Crewmax
    Sorry for the delay @DarthMurdicide. I lost track on this conversation now. Been busy at work :-(
  19. Oct 11, 2018 at 1:57 PM
    #1699
    maxcala
    maxcala New Member
    Max
    L.A.
    Those are your AUX connections.
  20. Oct 11, 2018 at 6:29 PM
    #1700
    BayRunner
    Question on the truck wiring. Have the JBL HU and do not know what the grey wire is for that I am pointing to. The black wire just to the lower left and the black wire in the upper right is the GPS and XM Sat antenna wires. So what is the grey one?
  21. Oct 11, 2018 at 6:36 PM
    #1701
    maxcala
    maxcala New Member
    Max
    L.A.
    That's the USB from the truck. I plug that to my USB1 and I ran the USB2 to the glove box which I have a 2tb portable harddrive.
  22. Oct 11, 2018 at 6:45 PM
    #1702
    dud13
    You sure? Phoenix told me it was the sat radio antenna.... check my post #1678 on this thread.
  23. Oct 11, 2018 at 6:54 PM
    #1703
    maxcala
    maxcala New Member
    Max
    L.A.
    I wish I can show you my connections but busy with family. I'm sure and you should have an adapter that connects to the gray wire.
  24. Oct 11, 2018 at 7:19 PM
    #1704
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Sorry..you saying the lower left is the GPS and top right is the XM Sat Antenna?
  25. Oct 11, 2018 at 7:30 PM
    #1705
    BayRunner
    Have not sorted out which one is the GPS and which is the XM yet. Still trying to get the basic functionality going. The above post is correct in that the grey wire is the USB and the 2 black ones are the GPS/XM
  26. Oct 11, 2018 at 7:55 PM
    #1706
    dud13
    Ahh it’s cool. No worries at all def spend time with the fam. Much more important!!
  27. Oct 11, 2018 at 8:50 PM
    #1707
    BayRunner
    That helped.....Thanks!
  28. Oct 11, 2018 at 8:52 PM
    #1708
    BayRunner
    Just read on the Facebook group that, yes, this statement is correct. The lower left wire (in pic) which is a black wire with a foam wrap and a "white" connector is the GPS. The top right wire (in pic) which is the black wire with "black" connector is the XM antenna.
  29. Oct 12, 2018 at 6:25 PM
    #1709
    BayRunner
    Finished the install with the exception of the GPS and XM antenna. Everything is working as it should (that I've tested so far) and I'm fairly impressed with gen 2.
    Watt maker likes this.
  30. Oct 12, 2018 at 6:27 PM
    #1710
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    So what’s the fix to the Sirius
