Amp wiring
Discussion in 'Audio & Video' started by Dannyo, Feb 14, 2019.
  1. Feb 14, 2019 at 7:45 AM
    Dannyo
    Dannyo [OP] New Member
    hey guys does anyone know the wiring diagram for the 2018 tundra with the stock amp. the wire colors seam to be different from what i have seen. I’m trying to add a line out converter for a amplifier and sub
  2. Feb 14, 2019 at 8:16 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Here you go sir...
  3. Feb 14, 2019 at 8:25 AM
    Dannyo
    My wiring looks different from your diagram
  4. Feb 14, 2019 at 8:28 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The colors are different, but the pin positions are the same. I put in an amp with high level inputs a few weeks ago and that diagram worked for me.
    Fireman/68W and 040Tundra like this.
  5. Feb 14, 2019 at 8:39 AM
    Dannyo
    OK thanks bud that wiring color threw me off
  6. Feb 14, 2019 at 9:52 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
  7. Feb 15, 2019 at 2:23 AM
    Dannyo
    TRDFerguson what 4 pins did you tap into
  8. Feb 15, 2019 at 8:21 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I did 3, 8, 9 and 10 on J145 and everything worked well. I had also tried tapping the output feeds for the rears but ended up doing weird things to the amp. Using the signal feeds is clean and shouldn't muck up the power to any of the stock woofers.
    Dannyo[QUOTED][OP] likes this.
  9. Mar 20, 2019 at 12:17 PM
    Chuckt127
    Chuckt127 New Member
    Chuck
    2018 tundra crewmax trd offroad
    Funny I'm running Into the same issue with colors. My colors are the same as yours dannyo.... good info
  10. Aug 26, 2019 at 4:36 PM
    Ob1
    Ob1 New Member
    I have a 2018 non JBL as well, and pin 3 of J144 is powered at all times. Whether radio on or off. Doesn't behave like a remote at all hence my amp is always on.
    This is frustrating.
    After removing both connectors and shooting the wires, wallah !!! No remote. Not one pin powers on an off with the radio.
    Anybody???
  11. Aug 26, 2019 at 4:39 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    What's your end goal here? And are you running a stock or aftermarket deck?
  12. Aug 26, 2019 at 9:59 PM
    Ob1
    Ob1 New Member
    Right now I'm still on the OEM radio. Unfortunately both of my amps are staying powered on as long as the key is turned, regardless of radio status. I did use pin 3 as the accessory remote. Funny thing is that my radio is always running when I'm driving anyway, thus I shouldn't care.
    But unfortunately I do.
  13. Jan 17, 2021 at 6:42 AM
    WardCo15
    WardCo15 New Member
    Cote
    2018 Tundra Crewmax TRD
    @TRDFerguson when you say it did weird things to the amp are you referring to the stock under seat amp? I am having an issue where I tapped into the speaker outputs and now my door speakers don’t work. Is this what happened to you? Will tapping the signal lines instead work?
  14. Mar 8, 2021 at 4:47 PM
    Miguel909_
    Miguel909_ New Member
    Anyone know how to add a 4 channel amp to 17 tundra dont mind cutting and splicing wires
    Vic4x4 likes this.
  15. Mar 8, 2021 at 5:17 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    There's no need to cut and splice wires, it's 2021, there's a harness for basically everything.
    Does your truck have the JBL or non-JBL stereo?
  16. Mar 8, 2021 at 5:30 PM
    Miguel909_
    Its the non jbl
  17. Mar 8, 2021 at 5:31 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    This will plug into both harnesses at the factory amp, giving you speaker level inputs into your aftermarket amp and the speaker outputs to the door speakers. The dash corner speakers and center channel speaker are powered directly off the head unit
    https://www.autoharnesshouse.com/41112.html
    Desolate likes this.
  18. Mar 8, 2021 at 5:32 PM
    AZBoatHauler
    So.Arizona
    Email James at tech12volt@gmail.com
    He will get you all the harness connections you need.
  19. Mar 8, 2021 at 5:35 PM
    Miguel909_
    Thank you
  20. Mar 8, 2021 at 5:45 PM
    Miguel909_
    One last question how will i get the speaker input “rca” signal from that harness
  21. Mar 8, 2021 at 5:45 PM
    Miguel909_
    Can i use a high to low converter to tap in
  22. Mar 8, 2021 at 5:47 PM
    AZBoatHauler
    So.Arizona
    You got it. You wire up a line out converter.
  23. Mar 8, 2021 at 5:49 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    A lot of amps will have high level inputs too. But a LOC is a sure way to do it.
  24. Mar 8, 2021 at 5:51 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    James @ Tech12Volts can definitely get you on the right path, additionally, I would strongly recommend spending a few hours and reading through the threads here to get you up to speed on the workings of the factory stereo components and general electrics of these trucks
  25. Mar 8, 2021 at 6:00 PM
    Miguel909_
    Thanks for the all the help
  26. Jul 17, 2021 at 9:54 PM
    Unholysinz
    Unholysinz New Member
    I see that the wiring diagram has output to speaker connections and signal to speaker connections what's the difference. Which cable would I use to plug into my lc7i?
  27. Jan 8, 2022 at 1:28 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Quick question have done many installs, but am perplexed by the onboard amp, do i need the harness below if I am replacing head unit and installing an aftermarket 5 channel amp? Been reading forum for a while, have yet to find a definitive answer...Thanks
    Toyota Factory Amp Upgrade harness
    Item Number: 4438
    [​IMG] [​IMG]
  28. Jan 8, 2022 at 2:14 PM
    Unholysinz
    People use the harness so they don't have to cut the factory harness off. That harness you posted makes it so you can wire straight into your amp. It has cables for input signal meaning the signal coming from the radio to the amp. And the other one is the output signal meaning those get wired into the ones that go to your speakers.
  29. Jan 8, 2022 at 2:19 PM
    Unholysinz
    Also depending on the amp some have high input and low output jacks. If you go with one that does not have high input Jacks you will need a LOC to convert your high input to low. I wanted to keep factory stereo so i used the LC7i. I you run after market then you can just run some RCAs to your amps.
  30. Jan 8, 2022 at 4:52 PM
    Roborob70
    Robert
    Thank you, thats all i wanted to know. shit between head unit speakers sub and amp, i'm in the hole a little over 3k. Aargggggh Toyota stock radio sucks wumpom !
