Amp Research XL for Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by joeguam, Feb 23, 2017.
  1. Feb 23, 2017 at 7:00 PM
    joeguam
    joeguam [OP] New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    I am be the only one trying to inquire if AMP Research will make the XL version for the Tundra. I tried in another Tundra forum to see if others will help influence and spark the fire in the company to build a set for us Tundra owners.
    Email them to help the cause. CustomerService@AMP-Research.com
  2. Feb 23, 2017 at 7:14 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I think the main difference is the XLs put the step lower to help with lifted trucks. I don't know if they still offer them, but they used to sell optional extensions for the original power steps which accomplished the same thing.
    Edit: yep. here they are
  3. Feb 23, 2017 at 7:28 PM
    joeguam
    JOE
    It is more of a slider and power step combination
  4. Feb 23, 2017 at 7:39 PM
    joeguam
    JOE
  5. Feb 23, 2017 at 8:27 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    I want these!!!!
  6. Feb 23, 2017 at 8:38 PM
    joeguam
    JOE
    I have been trying to get AMP Research to produce it since July but to no avail. I can not blame them but if there is enough pressure. If the demand is higher then maybe it will happen.
  7. Feb 23, 2017 at 8:43 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    I don't see why they would hesistate. If most tundra owners don't see them then they probably aren't going to bother them about it. But I will lol
  8. Feb 23, 2017 at 8:46 PM
    geno0506
    geno0506 New Member
    Michael
    If I bought the regular AMP and only did the 2.50 or 3" lift would the XL benefit me or is the regular fine!
  9. Feb 23, 2017 at 9:04 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    Silly Amp would make them for Ford f150's, the platinum models comes with them from the factory as an option which I believe they are a Ford product. I would think amp would manufacture them for other makes instead.
  10. Feb 23, 2017 at 9:04 PM
    joeguam
    JOE
    I would not know exactly because I do not have one. The XL however will fit my desired needs but it is not produced yet.
    geno0506[QUOTED] likes this.
  11. Feb 23, 2017 at 9:06 PM
    geno0506
    geno0506 New Member
    Michael
    what if you get the extension arm kit listed in the link above!
  12. Feb 23, 2017 at 9:08 PM
    joeguam
    JOE
    That is my gut feeling as to why it is not in the priority list to produce it for Tundra. We are neglected by affiliation :(
  13. Feb 23, 2017 at 9:11 PM
    joeguam
    JOE
    The concept is a Rock Slider type integration. I am not inquiring because it extends lower but because it acts as a ROCK SLIDER.
    AnonVet likes this.
  14. Feb 23, 2017 at 9:14 PM
    joeguam
    JOE
    AMP Research™ has released the PowerStep XL™, an automatic, electric-powered running board designed for lifted trucks. The board has been integrated into a custom rocker rail, creating a seamless look while providing a 3” lower stepping surface than the original PowerStep™ that makes accessing lifted trucks easier.
  15. Feb 23, 2017 at 9:55 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    I have the regular ones (without the extensions) on 3/1. For me, its pretty dang perfect. Again, if you need them lower, you can add extensions to make them extend 2" lower.
    I'm a bit dubious as to the effectiveness of the "slider" part on the XL, beyond the cosmetic. Should you actually have to "use" the slider part, it would surely destroy the step part.
  16. Feb 24, 2017 at 12:04 AM
    geno0506
    geno0506 New Member
    Michael
    Thanks for the info!
  17. Feb 24, 2017 at 4:58 AM
    McReef
    McReef '17 Tundra TRD Pro Crewmax
    Eastern MA
    Those things are awesome!
  18. Feb 24, 2017 at 5:41 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i have the amp steps on my 8" lifted excursion and on my 6" lifted tundra. both with out extensions. the boards on the ford extend easily an inch to 1.5 lower then the boards on the tundra. i'd like them to go down further but when you add the extensions it causes them to hang lower when "tucked" and visually it looks dumb. i love the boards. one of the best mods i've done to both my trucks
  19. Feb 24, 2017 at 7:15 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    I sent them a nice email just a second ago and i'll post some feedback when they reply.
  20. Feb 24, 2017 at 7:17 AM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    I want badly...
    Can I get a discount on 2 sets? I have 2 Tundras..lol
  21. Feb 24, 2017 at 7:17 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    They don't even make them lol. We are trying to lobby for them.
  22. Feb 24, 2017 at 7:20 AM
    az1441
    Steeler Country
    lol I know
    I mean I may just get the non-XL
    How far down does the non XL extend?
  23. Feb 24, 2017 at 7:25 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    From the top of the door seal to the top of the step is 11 1/2"
    az1441 likes this.
  24. Feb 24, 2017 at 7:26 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Here's a reference
    az1441 likes this.
  25. Feb 24, 2017 at 7:31 AM
    az1441
    Steeler Country
    thanks for that...
    i would guess looking at this then from the lowest portion of the truck to the step it would be half...
    maybe 5-6 in?
  26. Feb 24, 2017 at 9:02 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Ya I would say that's a solid guess. I'll be honest, on a level, it's awesome on the back. Hell, even on a lift its nice on the back. And the wife wouldn't gripe at me for her vertical disability lol.
    az1441[QUOTED] likes this.
  27. Feb 24, 2017 at 9:06 AM
    az1441
    Steeler Country
    That would be plenty for my cement...
    My white one is about an inch taller
  28. Feb 24, 2017 at 9:09 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    What... you have 2 of them? where do I sign up.... I'll cook and clean but no reach around!!! I think it would look solid on the cement! I like to be different so I would probably take a set to the line-x dudes and have them done white then put them up. It would be badass.
  29. Feb 24, 2017 at 9:19 AM
    az1441
    Steeler Country
  30. Feb 24, 2017 at 10:24 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Like @bobeast said, I'm sure they beefed these up a bit to be "sliders" but I'd be too scared to smash my $3000 electric steps onto rocks. :confused:
